Ripping Dolby Atmos into MKV
Re: Ripping Dolby Atmos into MKV
#106 Post by SamuriHL » Tue Apr 14, 2020 12:45 am
Yea, it's the 7.1 TrueHD track. It contains the ATMOS extensions. And as mentioned, mediainfo usually can tell you, as well.
cipher
#107 Post by cipher » Tue Apr 14, 2020 11:29 pm
Phew, I just noticed this issue on my Zootopia and Frozen II copies and was trying to figure out if it was a software issue (MakeMKV or MKVTOOLNX) or hardware issue (Denon receiver, Shield Streamer etc). I wish I had noticed it earlier as I'm now wondering how many titles are affected.
A couple of questions after reading through this thread:
1) Why does this seem to happen largely or exclusively on Disney discs? Given the prevalence of Dolby Atmos why isn't this being reported in larger numbers on other non-Disney titles?
2) Does this issue only occur on UHD discs with Dolby Atmos or are Blu-rays with Dolby Atmos also seeing this issue?
#108 Post by SamuriHL » Wed Apr 15, 2020 1:10 am
Disney loves to seamless branch their titles and use high bitrate ATMOS tracks (god bless them) which tends to contribute to this issue. And here's the thing, even if you don't see the symptoms of this issue on other titles, it's technically there. It has to do with how ATMOS frames are put into an MKV container.
cipher
#109 Post by cipher » Wed Apr 15, 2020 5:42 am
Thanks for the explanation, SamuriHL.
It doesn't sound like we'll be able to retroactively fix our MKV's by running them through another remux when a fix is rolled out so we're likely looking at remuxing from the discs again. Also, given the reason for the issue I'm assuming this is also occurring on Blu-ray's that contain an Atmos track and not just on UHD's.
#110 Post by SamuriHL » Wed Apr 15, 2020 4:41 pm
I'd guess that's likely on BD's but I don't know since I've not tested any. Yes, when this was fixed in CloneBD I went back and re-ripped all my ATMOS titles. Yes, that's a pain on the ass. But for me, I want to make sure I have the best quality MKV's on my NAS so it was worth the effort. My current ripping process is to create unprotected folder backups with MakeMKV and then process that with CloneBD to create the MKV's. This has been working for every disc I've thrown at it.
#111 Post by mike admin » Wed Apr 15, 2020 5:47 pm
This is (supposedly) fixed in 1.15.1
#112 Post by SamuriHL » Wed Apr 15, 2020 6:46 pm
Fantastic! That's going to make a lot of people happy for sure. A good one to test on is Incredibles 2. Will try to get to it later today if no one else has gotten to it yet.
spl147
#113 Post by spl147 » Wed Apr 15, 2020 6:56 pm
will the fix work on already processed mkv's? or do we need to re rip the disc?
#114 Post by Woodstock » Wed Apr 15, 2020 7:06 pm
What's processed is processed - this would be for ripping either from a disk or a backup.
#115 Post by mike admin » Wed Apr 15, 2020 7:59 pm
This is unfortunately correct. MakeMKV was (rarely, but still) dropping wrong audio frames on segment boundaries, so MKV files are bad (with clicks on scene change) but backups are good.
jayper
#116 Post by jayper » Wed Apr 15, 2020 8:56 pm
This is phenomenal news. I have some backups handy that I can test with. Thanks so much, Mike!
EDIT: I just generated a new MKV for a title that I had previously had dropout issues with and things seem to be all good!
cipher
#117 Post by cipher » Wed Apr 15, 2020 11:01 pm
That's great news, Mike!
#118 Post by mike admin » Thu Apr 16, 2020 11:19 am
I can speak about particular MakeMKV bug that was causing this - the frame loss was caused by a specific (very unusual) sync frame configuration at the start of a seamless segment. Shame is that MakeMKV had a code to explicitly handle this scenario - only the code was buggy :(
So It could be very well that this sync frame configuration is just a disney "feature"
#119 Post by SamuriHL » Thu Apr 16, 2020 12:48 pm
Thanks for the explanation and the fix. This is really great news as atmos has really become the standard these days.
spl147
#120 Post by spl147 » Thu Apr 16, 2020 1:15 pm
Is there a list of affected titles?
