Sherlock Holms (Dont work with MakeMKV but with other BluRay ripper) *SOLVED*
Noop187
Post by Noop187 »
Hi there,
Im fairly new to ripping Bluray disc.
My blurays disc is a integrated Asus driver, info fraom MakeMKV pasted below.
OS device name: E:
Manufacturer: Slimtype
Product: BD E DS4E1S
Revision: EA2B
Serial number: xxxxxxxx
Highest AACS version: 27
Ive tried to run the newest MakeMKV install and ripp one of the titles with the subtitles that i want.
Everyhing seems to work beside some status_device_error and Medium errors, but the whole operation failes after a while.
As a controll, I downloaded and tested another software (AnyMP4 Blu-ray ripper). Everything worked perfectly.
So i know my bluray disc gets noticed by the internal Asus driver.
I dont wish to use this software as i want to use MakeMKV and support the community. (buy a full license ASAP as i get it to work)
Is it anything im missing, are doing wrong or anything?
Ive inserted a snipp from the log. The "operation successfully completed" is after the titles are read and completed.
Saving 1 titles into directory C:/BluRay-RIP
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4718592'
DEBUG: Code 3221225628 at )71vN$q_,zgve5)N6K:29394758
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00461.m2ts' at offset '4718592'
DEBUG: Code 100864261 at )71vN$q_,zgve5)N6K:29394758
DEBUG: Code 0 at &{v}+MJ mVD\u'n8Q'92:29395011
DEBUG: Code 0 at (M/i",,""j##aj|5U?fM:29394068
DEBUG: Code 0 at &{v}+MJ mVD\u'n8Q'92:29394459
DEBUG: Code 2304 at &{v}+MJ mVD\u'n8Q'92:29393286
DEBUG: Code 0 at DIa=ZiW94BU9$P2_HZ>H:29399680
DEBUG: Code 6 at TsH[>BvG:0V<up`AKTU:121264004
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00460.m2ts' at offset '909127680'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '909127680'
DEBUG: Code 443910 at &{v}+MJ mVD\u'n8Q'92:29393286
DEBUG: Code 0 at q>~&\fO?bx/1wwub#=RMw:213136608
DEBUG: Code 0 at O]NK-FfHH<GRC4aUfLlh:29394022
DEBUG: Code 0 at O]NK-FfHH<GRC4aUfLlh:213140932
DEBUG: Code 0 at O]NK-FfHH<GRC4aUfLlh:213141438
DEBUG: Code 0 at O]NK-FfHH<GRC4aUfLlh:121271502
DEBUG: Code 0 at g21d+(mhO{zDl@Rb:29395908
DEBUG: Code 0 at 5*atu325v(agyTvrn:213132698
DEBUG: Code 0 at 5*atu325v(agyTvrn:213132146
DEBUG: Code 0 at 5*atu325v(agyTvrn:29393769
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 1 to file C:/BluRay-RIP/Sherlock Holmes- A Game of Shadows_t01.mkv
Encountered 22 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Sherlock Holms (Dont work with MakeMKV but does with other BluRay ripper)
The error messages are consistent with the drive finding an area it can't read, and trying so hard to read it that the operating system thinks it has gone off-line. Cleaning the disk will probably make this go away.
Start here: viewtopic.php?f=8&t=15055
Noop187
Re: Sherlock Holms (Dont work with MakeMKV but with other BluRay ripper) *SOLVED*
Post by Noop187 »
Tanks alot Woodstock, that was apparently the issue all along.
Got a little thrown off since i manage to get another ripper du execute without problems.
Tried again after following your post, everything worked without any problems. I'll go ahead and rip a couple more tonight and purchase a full license. Thanks again.
Sorry for not reading the entire post, thought my issue was non-related due to a little difference in error message :)
I added a SOLVE tag to the subject so others can benefit, if they skim through the sticky post as i did... :)
