I have met the same issue, the workaround is finding the correct m2ts file in the bdmv/stream folder. DO NOT USE bluray protocol.Sgt Hartman wrote: ↑Fri Apr 10, 2020 12:08 pmDoes any of you got the error message in ffmpeg
bd_open() failed
bluray:: I/O error
while launching ffmpeg -i bluray: D:\your_uhd_bluray_foler\ -map 0:0 -c copy D:\output\BL.hevc -map 0:1 -c copy D:\output\EL.hevc
ffmpeg -i d:\your.m2ts.file.path .....other parameter.....
