badrobot
Post
by badrobot » Sat Apr 11, 2020 12:44 am
Sgt Hartman wrote: ↑Fri Apr 10, 2020 12:08 pm
Does any of you got the error message in ffmpeg
bd_open() failed
bluray:: I/O error
while launching ffmpeg -i bluray: D:\your_uhd_bluray_foler\ -map 0:0 -c copy D:\output\BL.hevc -map 0:1 -c copy D:\output\EL.hevc
I have met the same issue, the workaround is finding the correct m2ts file in the bdmv/stream folder. DO NOT USE bluray protocol.
ffmpeg -i d:\your.m2ts.file.path .....other parameter.....
If the moive contains more than one m2ts file, use tsmuxer to merge those m2ts files first.
I am not a native English speaker.
Sorry for my bad English.
Angryunibrow
Post
by Angryunibrow » Sat Apr 11, 2020 12:55 am
tr000 wrote: ↑Sat Apr 11, 2020 12:32 am
Grencola wrote: ↑Fri Apr 10, 2020 7:01 pm
mrhollywood wrote: ↑Fri Apr 10, 2020 2:26 pm
Forgive me if this has already been mentioned, but if profile 5 is single layer, then wouldn't it work in MKV format without any modifications? As far as I have read the only thing preventing DV in MKV is the lack of handling multiple layers. MKV is a lot for convenient for use over TS.
technically yes, but mkvtoolnix needs to add the proper dv descriptors first similar to what tsmuxer has done. right now it makes an mkv fine but loses the dv data in process.
This is basically just what mp4muxer does (for an mp4), that's why the actual .exe is so small.
No Atmos in .mp4 so a profile 5 mkv with Atmos would be ideal.
Grencola
Post
by Grencola » Sat Apr 11, 2020 1:00 am
Pretty much, though with .ts / .m2ts now working with dv I'm not sure we need mkv. I suppose PGS subtitles and proper chapter support is handy to some people (pgs to srt is such a simple conversion, and who even uses chapters?
![Laughing :lol:](./images/smilies/icon_lol.gif)
Grencola
Post
by Grencola » Sat Apr 11, 2020 1:01 am
Angryunibrow wrote: ↑Sat Apr 11, 2020 12:55 am
use tsmuxer to make a .ts file with atmos.
Post
by shawnc22 » Sat Apr 11, 2020 1:08 am
Grencola wrote: ↑Sat Apr 11, 2020 1:00 am
I still use chapters! to the point of digging up an old plex metadata plugin to add them onto ts files during the import process
Grencola
Post
by Grencola » Sat Apr 11, 2020 1:13 am
shawnc22 wrote: ↑Sat Apr 11, 2020 1:08 am
oh wow!
tr000
Post
by tr000 » Sat Apr 11, 2020 1:19 am
Yeah, just throw it in TSMuxer like Grencola said.
I agree, even the atrocious Roku Media Player plays .ts files. Though, It doesn't change much for me since it doesn't do DTS or True-HD, just E-AC3.
Angryunibrow
Post
by Angryunibrow » Sat Apr 11, 2020 1:26 am
tr000 wrote: ↑Sat Apr 11, 2020 1:19 am
I use a shield, but the Plex app on LG TV's will not play a .ts DV file. So mkv would help others
tr000
Post
by tr000 » Sat Apr 11, 2020 1:28 am
Angryunibrow wrote: ↑Sat Apr 11, 2020 1:26 am
Why not use LG's native player (via DLNA)? My ancient LG BH4120s plays .ts files so I'd think the current TVs would as well.
Angryunibrow
Post
by Angryunibrow » Sat Apr 11, 2020 1:29 am
tr000 wrote: ↑Sat Apr 11, 2020 1:28 am
Not with Dolby Vision.
tr000
Post
by tr000 » Sat Apr 11, 2020 6:09 am
So after 10+ hours of agonizing labor, Jumanji did not work through any method in mkv form or m2ts form. I will begrudgingly watch it in HDR10.
Post
by shawnc22 » Sat Apr 11, 2020 6:13 am
tr000 wrote: ↑Sat Apr 11, 2020 6:09 am
are you referring to the first or second one? only the first one has dolby vision, the sequel is hdr10 only
tr000
Post
by tr000 » Sat Apr 11, 2020 6:15 am
shawnc22 wrote: ↑Sat Apr 11, 2020 6:13 am
The first one.
Sgt Hartman
Post
by Sgt Hartman » Sat Apr 11, 2020 6:44 am
badrobot wrote: ↑Sat Apr 11, 2020 12:44 am
Noted, thanks mate!
DaMacFunkin
Post
by DaMacFunkin » Sat Apr 11, 2020 7:39 am
Plays M2TS though.
