Angryunibrow
#2086
Post
by Angryunibrow » Fri Apr 10, 2020 5:09 pm
jcdr428 wrote: ↑Fri Apr 10, 2020 4:50 pm
jcdr428 wrote: ↑Thu Apr 09, 2020 8:29 pm
badrobot wrote: ↑Thu Apr 09, 2020 7:39 am
And, according to the help information of Dolby’s open source mp4muxer, Profile 4 has HDR compatibility?
--dv-profile <arg> = Sets the Dolby Vision profile. This option is MANDATORY for
DoVi elementary stream: Valid profile values are:
4 - dvhe.04, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: SDR/HDR.
5 - dvhe.05, BL codec: HEVC10; EL codec: N/A; BL compatibility: None.
7 - dvhe.07, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: Blue-ray HDR10.
8 - dvhe.08, BL codec: HEVC10; EL codec: N/A; BL compatibility: SDR/HDR.
9 - dvav.09, BL codec: AVC; EL codec: N/A; BL compatibility: SDR/HDR
mp4muxer profile 6 has been removed on 12 Feb 20. The latest document DolbyVisionProfilesLevels_v1_3_2_2019_09_16.pdf mentions BL compatibility with SDR (VUI 1,1,1) only. I've asked Dolby mp4muxer developper on Github to clarify compatibility with CTA HDR10, and whether the document would be revised accordingly.
Answer from Dolby: "Profile 4 is a Dolby Vision specific dual layer format where the base layer is SDR ( BT.1886, ITU-R BT.709, YCbCr 4:2:0) and then the enhancement layer contains the Dolby Vision data. So its is only cross compatible with SDR and not HDR10. That is why the current profile and levels doc was updated to reflect that."
So Profile 6 is the only profile (besides 5 & 7) that we can create from the tools we have, but are not "officially" supported from Dolby anymore.
And we would need exoplayer to add this back in, and also Plex to make sure they use it to be fully compatible?
MastaG
#2087
Post
by MastaG » Fri Apr 10, 2020 5:14 pm
Okay.. I couldn't let go of Gemini Man on my LG C8.
It appears that when I use Dolby Lab's mp4muxer version 1.0.0 (v1.0.1 is broken) and I mux both the base and enhanced layer separately using --dv-profile 7 and ac3 audio. It DOES indeed play when I turn off all processing options on my TV (motion blah, noise reduction blah etc..).
It still stutters a very tiny bit though..(probably because the movie is 60fps).
But I can't achieve the same when I 'blend' both layers using yusesope's tool in mode 1 (BL+EL+RPU).
I tried to mux the resulting hevc with both mp4muxer (profile 4) and the latest tsmuxer nightly (which gives it profile 6).
In both muxes it skips every one-two seconds.
That makes me wonder whether the BL+EL+RPU 'merged' videos somehow differ from dual layer (profile 7) muxes.
Because I would imagine that blending them together with yusesope's tool would make it easier for the TV to decode since it's a single track..
#2088
Post
by shawnc22 » Fri Apr 10, 2020 6:01 pm
MastaG wrote: ↑Fri Apr 10, 2020 5:14 pm
Have you also tried muxing yusecope's resulting hevc in profile 7 with mp4muxer?
MastaG
#2089
Post
by MastaG » Fri Apr 10, 2020 6:53 pm
shawnc22 wrote: ↑Fri Apr 10, 2020 6:01 pm
Good one!
I haven't with v1.0.0, good one
I'll try and report back.
Grencola
#2090
Post
by Grencola » Fri Apr 10, 2020 7:01 pm
mrhollywood wrote: ↑Fri Apr 10, 2020 2:26 pm
Forgive me if this has already been mentioned, but if profile 5 is single layer, then wouldn't it work in MKV format without any modifications? As far as I have read the only thing preventing DV in MKV is the lack of handling multiple layers. MKV is a lot for convenient for use over TS.
technically yes, but mkvtoolnix needs to add the proper dv descriptors first similar to what tsmuxer has done. right now it makes an mkv fine but loses the dv data in process.
ragico
#2091
Post
by ragico » Fri Apr 10, 2020 7:09 pm
@MastaG
I remember Yusesope recommended to me tu use profile 5, about 40 pages back.
Sgt Hartman
#2092
Post
by Sgt Hartman » Fri Apr 10, 2020 7:23 pm
FYI, seems like DV has been triggered also for Elephant Man!
Angryunibrow
#2093
Post
by Angryunibrow » Fri Apr 10, 2020 8:48 pm
Grencola wrote: ↑Fri Apr 10, 2020 7:01 pm
Who do we talk too to make that happen
tr000
#2095
Post
by tr000 » Sat Apr 11, 2020 12:32 am
This is basically just what mp4muxer does (for an mp4), that's why the actual .exe is so small.
badrobot
#2096
Post
by badrobot » Sat Apr 11, 2020 12:44 am
Sgt Hartman wrote: ↑Fri Apr 10, 2020 12:08 pm
Does any of you got the error message in ffmpeg
bd_open() failed
bluray:: I/O error
while launching ffmpeg -i bluray: D:\your_uhd_bluray_foler\ -map 0:0 -c copy D:\output\BL.hevc -map 0:1 -c copy D:\output\EL.hevc
I have met the same issue, the workaround is finding the correct m2ts file in the bdmv/stream folder. DO NOT USE bluray protocol.
ffmpeg -i d:\your.m2ts.file.path .....other parameter.....
If the moive contains more than one m2ts file, use tsmuxer to merge those m2ts files first.
I am not a native English speaker.
Sorry for my bad English.
Angryunibrow
#2097
Post
by Angryunibrow » Sat Apr 11, 2020 12:55 am
tr000 wrote: ↑Sat Apr 11, 2020 12:32 am
No Atmos in .mp4 so a profile 5 mkv with Atmos would be ideal.
Grencola
#2098
Post
by Grencola » Sat Apr 11, 2020 1:00 am
Pretty much, though with .ts / .m2ts now working with dv I'm not sure we need mkv. I suppose PGS subtitles and proper chapter support is handy to some people (pgs to srt is such a simple conversion, and who even uses chapters?
Grencola
#2099
Post
by Grencola » Sat Apr 11, 2020 1:01 am
Angryunibrow wrote: ↑Sat Apr 11, 2020 12:55 am
use tsmuxer to make a .ts file with atmos.
#2100
Post
by shawnc22 » Sat Apr 11, 2020 1:08 am
Grencola wrote: ↑Sat Apr 11, 2020 1:00 am
I still use chapters! to the point of digging up an old plex metadata plugin to add them onto ts files during the import process
