So Profile 6 is the only profile (besides 5 & 7) that we can create from the tools we have, but are not "officially" supported from Dolby anymore.jcdr428 wrote: ↑Fri Apr 10, 2020 4:50 pmAnswer from Dolby: "Profile 4 is a Dolby Vision specific dual layer format where the base layer is SDR ( BT.1886, ITU-R BT.709, YCbCr 4:2:0) and then the enhancement layer contains the Dolby Vision data. So its is only cross compatible with SDR and not HDR10. That is why the current profile and levels doc was updated to reflect that."jcdr428 wrote: ↑Thu Apr 09, 2020 8:29 pmmp4muxer profile 6 has been removed on 12 Feb 20. The latest document DolbyVisionProfilesLevels_v1_3_2_2019_09_16.pdf mentions BL compatibility with SDR (VUI 1,1,1) only. I've asked Dolby mp4muxer developper on Github to clarify compatibility with CTA HDR10, and whether the document would be revised accordingly.badrobot wrote: ↑Thu Apr 09, 2020 7:39 amAnd, according to the help information of Dolby’s open source mp4muxer, Profile 4 has HDR compatibility?
--dv-profile <arg> = Sets the Dolby Vision profile. This option is MANDATORY for DoVi elementary stream: Valid profile values are: 4 - dvhe.04, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: SDR/HDR. 5 - dvhe.05, BL codec: HEVC10; EL codec: N/A; BL compatibility: None. 7 - dvhe.07, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: Blue-ray HDR10. 8 - dvhe.08, BL codec: HEVC10; EL codec: N/A; BL compatibility: SDR/HDR. 9 - dvav.09, BL codec: AVC; EL codec: N/A; BL compatibility: SDR/HDR
And we would need exoplayer to add this back in, and also Plex to make sure they use it to be fully compatible?
