Can't Rip Oscar (Sylvester Stallone)
Kentinator
Post by Kentinator »
Can't rip this dvd with makemkv. I've attached the log. There is only one rip option and I know this issue isn't related to a dirty disc as I can successfully rip the ISO and have tried to use makemkv using the digital iso file. Any ideas?
MakeMKV_log.txt
(3.15 KiB) Downloaded 644 times
Re: Can't Rip Oscar (Sylvester Stallone)
If you haven't already, enable Expert mode, which will allow you to de-select the closed caption subtitles.
After you open the DVD, click on the little triangle in the left menu next to the title you want to rip. Find the CC subtitles and uncheck the box next to them.
Try the rip again. If it works, you have found one of those DVDs that advertises Closed Captioning, but has no CC's.
Kentinator
Thank you Woodstock!!! Just unchecked the Closed Caption subtitles like you suggested and it ripped perfectly without a hitch! Good piece of information for ripping in the future too!
