jcdr428
#2056 Post by jcdr428 » Wed Apr 08, 2020 4:41 pm
badrobot wrote: Wed Apr 08, 2020 1:07 pmthat’s not good for me, because shield tv pro 2019 does not support DoVi Profile 6.
Dovi Profile 6 has been deprecated by dolby.
@badrobot It's already been confirmed that Profile 6 is working on Shield. In any case BL+EL+RPU HDR10 tracks are profile 6 according to Dolby, we just can't have tsMuxer produce non-compliant files with incorrect profile simply because one STB would not accept a profile.
Angryunibrow
#2057 Post by Angryunibrow » Wed Apr 08, 2020 4:43 pm
shawnc22 wrote: Wed Apr 08, 2020 4:01 pm
Sgt Hartman wrote: Wed Apr 08, 2020 3:08 pm
badrobot wrote: Wed Apr 08, 2020 2:34 pm
yes , I have tried it today.
I also tried 1917 with profile 6 on Shield (using Plex) and seemed to work more or less fine (even if my eye still notice some lack of fluidity in the playback). What did you use?
did you turn on frame rate matching in the plex settings? I've also noticed that frame rate matching sometimes doesnt work with the new exoplayer, and I eventually had to revert back to the old plex player to get it working.
May I ask how you are verifying if the new vs old player in Plex is matching frame rate?
jcdr428
#2058 Post by jcdr428 » Wed Apr 08, 2020 4:44 pm
badrobot wrote: Wed Apr 08, 2020 3:21 pm profile 6 is out of official guarantee.
shield supports profile 4,5,8
Edit: And profile 8 will also be deprecated very soon. Dolby is cutting all compatibility with HDR10 in favour of proprietary IPT colourspace. This does not mean that these profiles are "out of official guarantee". As far as I know, all SoC reading profile 5 also read profile 8, and all SoC reading profile 4 also read profile 6 as they have similar RPU structure.
#2059 Post by shawnc22 » Wed Apr 08, 2020 4:54 pm
Angryunibrow wrote: Wed Apr 08, 2020 4:43 pm
Sure, if you have a Denon AVR, you can download the companion smartphone app and look at the input signal info. With the exoplayer, I was constantly getting 4k:60hz even when I had match frame rate turned on. Once I reverted back to the old player, it was back to playing at 4k:24hz. Another option is to look at the LG service menu during video playback. You can find more info on how to access it here: https://www.avsforum.com/forum/40-oled- ... st58698658
Angryunibrow
#2060 Post by Angryunibrow » Wed Apr 08, 2020 4:58 pm
shawnc22 wrote: Wed Apr 08, 2020 4:54 pm
Awesome
I do not have a Denon receiver, but I sure will check out the hidden menu on my TV when I get home - thanks for this!
Sgt Hartman
#2061 Post by Sgt Hartman » Wed Apr 08, 2020 5:29 pm
shawnc22 wrote: Wed Apr 08, 2020 4:01 pm did you turn on frame rate matching in the plex settings? I've also noticed that frame rate matching sometimes doesnt work with the new exoplayer, and I eventually had to revert back to the old plex player to get it working.
It was already off, I tried also with the old player but I still get such effect. It doesn't occur always at the same point of the movie so it might be that it's a player issue. I'd like to test it with another player but I don't know any other able to read DV on Shield.
kazuma
#2062 Post by kazuma » Wed Apr 08, 2020 5:54 pm
kazuma wrote: Wed Apr 08, 2020 1:37 pm what's the difference between all profiles? (5,6,7?)
nobody?
Grencola
#2063 Post by Grencola » Wed Apr 08, 2020 6:57 pm
kazuma wrote: Wed Apr 08, 2020 5:54 pm
nobody?
https://lmgtfy.com/?q=Dolby+vision+profiles
mulucy
#2064 Post by mulucy » Wed Apr 08, 2020 7:02 pm
Grencola wrote: Wed Apr 08, 2020 6:57 pm
nobody?
That question has been probably asked at least 50-60 times before including me lol
#2065 Post by shawnc22 » Wed Apr 08, 2020 7:08 pm
Sgt Hartman wrote: Wed Apr 08, 2020 5:29 pm
No, you have to try turning it on to see if it helps with the hitchy playback. I did notice the intro title screen was having some slight stutters when using exoplayer with the matching frame option on (not working properly though when checked, avr still showed 4k:60hz). When I switched to the old player with the option still turned on, the hitch went away and my avr was properly reporting 4k:24hz.
kazuma
#2066 Post by kazuma » Wed Apr 08, 2020 10:14 pm
mulucy wrote: Wed Apr 08, 2020 7:02 pm
nobody?
maybe you can tell me? the google link is to general. when i search for it in the topic i have 30 pages.. :(
Sgt Hartman
#2067 Post by Sgt Hartman » Wed Apr 08, 2020 10:26 pm
shawnc22 wrote: Wed Apr 08, 2020 7:08 pm No, you have to try turning it on to see if it helps with the hitchy playback. I did notice the intro title screen was having some slight stutters when using exoplayer with the matching frame option on (not working properly though when checked, avr still showed 4k:60hz). When I switched to the old player with the option still turned on, the hitch went away and my avr was properly reporting 4k:24hz.
Dude,
You really gave me some nice hints in here, this could be a real game changer for me. I tried all the combinations you listed and, as you said, old exoplayer + refresh rate switching on is definitely the winner. Before all playing was set on 60 Hz, but in this way going "down" to 24 Hz it was really smooth!
One other thing that I noticed in these days, closing/re-opening Plex to play files seems to help in having smoother playbacks, keeping the app always on seems to affect the quality of the view.
Thanks again pal!
#2068 Post by shawnc22 » Wed Apr 08, 2020 11:12 pm
The only caveat with this is I don't know if the old player has the same level of dolby vision support as the new exoplayer. I know DV gets triggered and all, but I've never tried doing any kind of picture quality comparisons. You can always get exoplayer to play at 24hz, though, by manually changing the output refresh rate of the shield in its display settings to 24hz.
Grencola
#2069 Post by Grencola » Wed Apr 08, 2020 11:13 pm
kazuma wrote: Wed Apr 08, 2020 10:14 pm https://lmgtfy.com/?q=Dolby+vision+profiles
just click the first link (it's a pdf) that google shows, and scroll down to page 8.
Sgt Hartman
#2070 Post by Sgt Hartman » Thu Apr 09, 2020 6:00 am
shawnc22 wrote: Wed Apr 08, 2020 11:12 pm The only caveat with this is I don't know if the old player has the same level of dolby vision support as the new exoplayer. I know DV gets triggered and all, but I've never tried doing any kind of picture quality comparisons. You can always get exoplayer to play at 24hz, though, by manually changing the output refresh rate of the shield in its display settings to 24hz.
Well, that could be an interesting test to be performed, even if, at he same time, a blind test done simply with your eyes should be more "ethical" to see if you really spot any difference; at the end we use those to watch :D
