Jojo Rabbit can't be decrypted
mizu_ger
Post by mizu_ger »
I have the Canadian version of the Jojo Rabbit UHD. It's not decrypting and I'm getting the following error:
Saved AACS dump file as C:\Users\***/.MakeMKV/MKB20_v72_Jojo_Rabbit_B0F7.tgz
DEBUG: Code 0 at Ol~"E_@BEikMd^~p:29396092
DEBUG: Code 0 at Ol~"E_@BEikMd^~p:29395172
I've submitted the dump file, but I'm a bit worried by the LibreDrive comment in the error message. Is it just a matter of waiting for the disk to be added the has table or something else?
Re: Jojo Rabbit can't be decrypted
Post by d00zah »
What drive do you have? All the 'known' UHD friendly drives are LibreDrive compatible.
See links in my sig for a list.
mizu_ger
Post by mizu_ger »
I have the Asus BC-12D2HT. It's ripped plenty of discs without a problem so far.
Post by d00zah »
If it's been working, that's strange. Any msgs in the log regarding a failed/incomplete svq update? A change to your env which might block server access? Is it repeatable?
mizu_ger
Post by mizu_ger »
Still not working. I ntoiced that the private_data.tar file has not been updated since april 1st, een though i've tried this disk a number of times. Could makemkv be having problems accessing the latest keys? I am not sure how to check this. The debug log doesn't show anything.
Post by d00zah »
If that were failing, you'd see something like this in the output:
MakeMKV v1.14.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\User/MakeMKV_log.txt
Downloading latest SDF to C:\Users\User/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
DEBUG: Code 99 at %.rR&vsq2cI<A6cT:29407040
MIGHT require the following be checked in the 'General' preferences tab:
- Log debug messages
- Expert mode
Lengthy discussion of the DNS issue here:
https://www.makemkv.com/forum/viewtopic.php?f=1&t=17848
mizu_ger
Post by mizu_ger »
Thanks for the replies.
It's working now. Tar file updated and file decrypted without a problem. Patience :D
