DVD Audio Extractor
twosheds
DVD Audio Extractor
Post by twosheds » Tue Apr 07, 2020 12:42 pm
Hidden in the preferences is an option to have makemkv unencrypt discs for other programs i.e. VLC
Could DVD Audio Extractor (https://www.dvdae.com) be added to the list? :D
Re: DVD Audio Extractor
Post by Woodstock » Tue Apr 07, 2020 12:51 pm
THAT would depend on DVD Audio Extractor; if they implement using linked libraries for the decryption in the same way VLC and Kodi do, then the same technique should work. If not... probably not.
Ezatoka
Post by Ezatoka » Wed Apr 08, 2020 10:45 am
Couldn't you just rip the movie with MakeMKV and then extract the Audio Streams from it?
