DVD Audio Extractor
twosheds
DVD Audio Extractor
Post by twosheds »
Hidden in the preferences is an option to have makemkv unencrypt discs for other programs i.e. VLC
Could DVD Audio Extractor (https://www.dvdae.com) be added to the list? :D
Re: DVD Audio Extractor
THAT would depend on DVD Audio Extractor; if they implement using linked libraries for the decryption in the same way VLC and Kodi do, then the same technique should work. If not... probably not.
Ezatoka
Post by Ezatoka »
Couldn't you just rip the movie with MakeMKV and then extract the Audio Streams from it?
