Could DVD Audio Extractor (https://www.dvdae.com) be added to the list?
DVD Audio Extractor
twosheds
DVD Audio Extractor
Hidden in the preferences is an option to have makemkv unencrypt discs for other programs i.e. VLC
Re: DVD Audio Extractor
THAT would depend on DVD Audio Extractor; if they implement using linked libraries for the decryption in the same way VLC and Kodi do, then the same technique should work. If not... probably not.
Ezatoka
Couldn't you just rip the movie with MakeMKV and then extract the Audio Streams from it?
