Right, I get all that and all the ways to get DV working in an mp4 or ts container. I was just curious how people were starting with a remuxed mkv that still had both BL and EL tracks since I had assumed most people were using MakeMKV to create their mkv remuxes. I'm guessing the full folder decrypted backup is made in MakeMKV first and then the mkv remux is made with mkvtoolnix where you can preserve both video tracks?trumpet205 wrote: Mon Apr 06, 2020 4:25 pmYou are only getting HDR10/HDR10+ out of DV UHD disc if you open them with MakeMKV.shawnc22 wrote: Mon Apr 06, 2020 3:10 pm When you guys are talking about ripping the EL track out of mkv remuxes, I'm guessing you guys used something other than makemkv (e.g. mkvtoolnix?) to make the initial mkv? It's just that I've never seen the EL track being listed when opening a DV disk in makemkv, and all of the mkvs I've made with mkv only has one video track (unless I'm doing something wrong).
DV UHD disc has two video tracks, standard 4K HEVC with HDR10/HDR10+ and a 1080p HEVC called EL (enhancement layer).
Because .mkv has no defined way of storing DV MakeMKV will not touch the EL. So every .mkv generated from DV disc with MakeMKV will be HDR10/HDR10+ only. Everything you see here is people making a completed disc backup then mux it into .mp4, .ts, or .m2ts under different DV profiles.
kazuma
how did you do that with a mkv file without stutters? i have a C9 to, but i'm doing something wrong i think. can you tell me the steps? with m2ts i don't have any issues with the tool of grencola.deadchip12 wrote: Mon Apr 06, 2020 2:08 pmI just followed the exact steps stated in the original post, except instead of .m2ts file I use .mkv remux. Oh and 1 more thing: I don't include the ac3 audio in the demuxing, just the 2 video layers, but I'm not sure if that matters.tr000 wrote: Mon Apr 06, 2020 11:59 amCould you walk me through your process? Perhaps I'm coming at it wrong.deadchip12 wrote: Mon Apr 06, 2020 10:22 am
I make DV MP4 from remuxed .mkv all the time and it works fine on my c9. I no longer use the .m2ts structure because for some films the main video is split into multiple files.
PS: nobody using dvdfab anymore?
Grencola
cheers, you're welcome!tr000 wrote: Mon Apr 06, 2020 3:07 pm Hey Grencola, I use your tool very frequently as well, thanks for all your work on it.
eac3to has troubles with hdr10+ and dv mix, which 1917 has. tsmuxer works fine with hdr10+, but I noticed it would hang more on framerate issues where eac3to would correct it and complete the process properly. kind of a mixed bag, really..tr000 wrote:
However, there have been times where the tool has produced errors where manual demuxing with TSMuxer and putting it through MP4muxer has worked. For example, with 1917, the tool kept putting out only a 30 minute file for whatever reason. But the file I manually made worked.
Was it Transformers: The Last Knight by chance? because that has an FEL dv layer. here's a quick incomplete list of what each movie has: https://forum.blu-ray.com/showthread.php?t=276448tr000 wrote:
I don't think we are having the same issues. For one, I use Profile 5 because my TV doesn't support other profiles afaik. Second, I have tried turning the .mkv and raw BluRay of the same movie, Transformers for example, and only the mp4 made from the Blu-ray m2ts worked on my TV, the one from the mkv remux didn't play. No idea what the issue could be, but my TV just won't play mp4s made from a remux.
daddy
On windows you just need the mp4muxer.exe file4knewbie wrote: Mon Apr 06, 2020 3:33 pm Hello everyone, my first ever 4k TV (LG C9) is coming this week and I wanted to prepare some DV movies to be ready when it arrives.
However I just can't seem to get mp4base working. I'm using Windows 10 x64 on both my pcs and I've been trying many things for the past 2 days but nothing has worked, I've tried to build the solution for windows x86 and amd64 on VS 10 SP1 and every other version of VS that has come out since then on both of my pcs and I always get the exact same error "Invalid solution configuration"
Correct me if I'm wrong but the only thing to do before being able to run the soft is to build it by going to its directory and writing the devenv line, right ?
Thank you very kindly for your help
https://github.com/DolbyLaboratories/dl ... master/bin
There is a new version 1.0.1 date from 6 march
Usage: mp4muxer arg [options]
Args: [Options] Descriptions:
--help,-h = Shows the help information.
--version,-v = Shows the version information.
--input-file,-i <file.ext> [--media-lang <language>]
[--media-timescale <timescale>]
[--input-video-frame-rate <framerate>]
= Adds elementary stream (ES) file.ext with
media language, timescale, and framerate(only for video,such as 23.97 or 30000/1001).
Supports H264, H265, AC3, EC3, and AC4.
--output-file, -o <file.mp4> = Sets the output file name.
--overwrite = Overwrites the existing output .mp4 file if there is one.
--mpeg4-timescale <arg> = Overrides the timescale of the entire presentation.
--mpeg4-brand <arg> = Specifies the ISO base media file format brand in the format.
--mpeg4-comp-brand <arg> = Specifies the ISO base media file format compatible brand(s),
in the format of a comma separated list, for example mp42,iso6,isom,msdh,dby1.
--output-format <arg> = Sets the output file format or the specification to which the
output file must conform. Valid values include 'mp4' and 'frag-mp4'.
'mp4' is the default value.
--mpeg4-max-frag-duration <arg> = Sets the maximum fragment duration in milliseconds.
By default, the max duration is 2s.
--dv-profile <arg> = Sets the Dolby Vision profile. This option is MANDATORY for
DoVi elementary stream: Valid profile values are:
4 - dvhe.04, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: SDR/HDR.
5 - dvhe.05, BL codec: HEVC10; EL codec: N/A; BL compatibility: None.
7 - dvhe.07, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: Blue-ray HDR10.
8 - dvhe.08, BL codec: HEVC10; EL codec: N/A; BL compatibility: SDR/HDR.
9 - dvav.09, BL codec: AVC; EL codec: N/A; BL compatibility: SDR/HDR.
--dv-bl-compatible-id <arg> = Sets the Dolby Vision base layer compatible ID, if the profile index is 8, this option must be set by user.
mp4muxer usage examples:
To create an audio-only .mp4 file with EC-3 audio:
mp4muxer -o output.mp4 -i audio.ec3 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1
To multiplex AC-4 audio and H.264 video:
mp4muxer -o output.mp4 -i audio.ac4 -i video.h264 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1
To multiplex Dolby vision BL+EL+RPU into a .mp4 file :
mp4muxer -i ves_bl_el_rpu.264 -o single_track_output.mp4 --dv-profile 0 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 --overwrite
To multiplex Dolby vision BL+EL+RPU file into a .mp4 file with EC-3 audio track:
mp4muxer -i ves_bl_el_rpu.265 -i audio.ec3 -o output.mp4 --dv-profile 8
--dv-bl-compatible-id 2 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 --overwrite
Note: For the Dolby vision profile 8, dv-bl-compatible-id is necessary.This seems to be a new option: --dv-bl-compatible-id <arg>
tr000
I'll look into modifying your tool, perhaps to use TSMuxer. So far I've just changed it from profile 7 to profile 5, but I have a couple improvements I could make. Will post it when I get around to it.Grencola wrote: Mon Apr 06, 2020 6:51 pmcheers, you're welcome!tr000 wrote: Mon Apr 06, 2020 3:07 pm Hey Grencola, I use your tool very frequently as well, thanks for all your work on it.eac3to has troubles with hdr10+ and dv mix, which 1917 has. tsmuxer works fine with hdr10+, but I noticed it would hang more on framerate issues where eac3to would correct it and complete the process properly. kind of a mixed bag, really..tr000 wrote:
However, there have been times where the tool has produced errors where manual demuxing with TSMuxer and putting it through MP4muxer has worked. For example, with 1917, the tool kept putting out only a 30 minute file for whatever reason. But the file I manually made worked.Was it Transformers: The Last Knight by chance? because that has an FEL dv layer. here's a quick incomplete list of what each movie has: https://forum.blu-ray.com/showthread.php?t=276448tr000 wrote:
It was the 2007 film, but it was just an example. That's been true of every .mkv movie I've tried, either just black or stutters on my TV.
Grencola
sure, change it however you wishtr000 wrote: Tue Apr 07, 2020 12:04 am I'll look into modifying your tool, perhaps to use TSMuxer. So far I've just changed it from profile 7 to profile 5, but I have a couple improvements I could make. Will post it when I get around to it.
tr000
Ooo, that sounds interesting. Could you share the latest version?Grencola wrote: Tue Apr 07, 2020 3:19 amsure, change it however you wishtr000 wrote: Tue Apr 07, 2020 12:04 am I'll look into modifying your tool, perhaps to use TSMuxer. So far I've just changed it from profile 7 to profile 5, but I have a couple improvements I could make. Will post it when I get around to it.let me know if you need to make an srt subtitle along side the mp4, or want to choose the audio track, as I've already made those versions.
4knewbie
daddy wrote: Mon Apr 06, 2020 11:32 pmOn windows you just need the mp4muxer.exe file4knewbie wrote: Mon Apr 06, 2020 3:33 pm Hello everyone, my first ever 4k TV (LG C9) is coming this week and I wanted to prepare some DV movies to be ready when it arrives.
Usage: mp4muxer arg [options] Args: [Options] Descriptions: ----- -------------------- ------------------------------------------------------- --help,-h = Shows the help information. --version,-v = Shows the version information. --input-file,-i <file.ext> [--media-lang <language>] [--media-timescale <timescale>] [--input-video-frame-rate <framerate>] = Adds elementary stream (ES) file.ext with media language, timescale, and framerate(only for video,such as 23.97 or 30000/1001). Supports H264, H265, AC3, EC3, and AC4. --output-file, -o <file.mp4> = Sets the output file name. --overwrite = Overwrites the existing output .mp4 file if there is one. --mpeg4-timescale <arg> = Overrides the timescale of the entire presentation. --mpeg4-brand <arg> = Specifies the ISO base media file format brand in the format. --mpeg4-comp-brand <arg> = Specifies the ISO base media file format compatible brand(s), in the format of a comma separated list, for example mp42,iso6,isom,msdh,dby1. --output-format <arg> = Sets the output file format or the specification to which the output file must conform. Valid values include 'mp4' and 'frag-mp4'. 'mp4' is the default value. --mpeg4-max-frag-duration <arg> = Sets the maximum fragment duration in milliseconds. By default, the max duration is 2s. --dv-profile <arg> = Sets the Dolby Vision profile. This option is MANDATORY for DoVi elementary stream: Valid profile values are: 4 - dvhe.04, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: SDR/HDR. 5 - dvhe.05, BL codec: HEVC10; EL codec: N/A; BL compatibility: None. 7 - dvhe.07, BL codec: HEVC10; EL codec: HEVC10; BL compatibility: Blue-ray HDR10. 8 - dvhe.08, BL codec: HEVC10; EL codec: N/A; BL compatibility: SDR/HDR. 9 - dvav.09, BL codec: AVC; EL codec: N/A; BL compatibility: SDR/HDR. --dv-bl-compatible-id <arg> = Sets the Dolby Vision base layer compatible ID, if the profile index is 8, this option must be set by user. mp4muxer usage examples: --------------------------------------------------- To create an audio-only .mp4 file with EC-3 audio: mp4muxer -o output.mp4 -i audio.ec3 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 To multiplex AC-4 audio and H.264 video: mp4muxer -o output.mp4 -i audio.ac4 -i video.h264 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 To multiplex Dolby vision BL+EL+RPU into a .mp4 file : mp4muxer -i ves_bl_el_rpu.264 -o single_track_output.mp4 --dv-profile 0 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 --overwrite To multiplex Dolby vision BL+EL+RPU file into a .mp4 file with EC-3 audio track: mp4muxer -i ves_bl_el_rpu.265 -i audio.ec3 -o output.mp4 --dv-profile 8 --dv-bl-compatible-id 2 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 --overwrite Note: For the Dolby vision profile 8, dv-bl-compatible-id is necessary.
Worked to perfection thank you so much, I wish developers would put this kind of precious info in their Readme files for beginners like me. I also had to download the latest TsMuxer nightly to be able to demux Knives Out because the stable one had issues with the mpls playlist. I hope my C9 can read my hard earned profile 7 mp4 correctly
Grencola
subs: https://bit.ly/2Xdgfz2tr000 wrote: Tue Apr 07, 2020 3:25 am Ooo, that sounds interesting. Could you share the latest version?
choose audio: https://bit.ly/2XmgCHo
I made them over a year ago and can't remember any bugs they had as it's been so long, but I vaguely recall thinking I had to tweak something though
deadchip12
Here you go.kazuma wrote: Mon Apr 06, 2020 5:19 pmhow did you do that with a mkv file without stutters? i have a C9 to, but i'm doing something wrong i think. can you tell me the steps? with m2ts i don't have any issues with the tool of grencola.deadchip12 wrote: Mon Apr 06, 2020 2:08 pmI just followed the exact steps stated in the original post, except instead of .m2ts file I use .mkv remux. Oh and 1 more thing: I don't include the ac3 audio in the demuxing, just the 2 video layers, but I'm not sure if that matters.tr000 wrote: Mon Apr 06, 2020 11:59 am
https://youtu.be/VifZNt5N6yU
deadchip12
Here are my steps in case you want to recheck:tr000 wrote: Mon Apr 06, 2020 3:01 pmmust be down to my TV then. I have a TCL.deadchip12 wrote: Mon Apr 06, 2020 2:08 pmI just followed the exact steps stated in the original post, except instead of .m2ts file I use .mkv remux. Oh and 1 more thing: I don't include the ac3 audio in the demuxing, just the 2 video layers, but I'm not sure if that matters.tr000 wrote: Mon Apr 06, 2020 11:59 am
ah...I see, so these mkv remuxes that still have both bl and el tracks intact are scene releases
tr000
The only difference between our workflows is I use profile 5, and my TV is different. So it's definitely something to do with that, because otherwise I do exactly what you do. I just downloaded a remux of Jumanji, I'll try to see if I can somehow get DV working.deadchip12 wrote: Tue Apr 07, 2020 4:41 amHere are my steps in case you want to recheck:tr000 wrote: Mon Apr 06, 2020 3:01 pmmust be down to my TV then. I have a TCL.deadchip12 wrote: Mon Apr 06, 2020 2:08 pm
@tr000, if your tv only supports profile 5, i would suggest merging the bl and el tracks into a single track single layer file using yusecope’s tool in mode 2. then mix the resulting hevc file with mp4muxer like you’ve been doing.
kamus
I've used both, no luck with either sadly.Grencola wrote: Fri Mar 20, 2020 3:40 am are you using mkv remux or m2ts? had a few remuxes that stuttered, all m2ts have been fine though. I don't own a B9 but many others who do have no problems. you can try yusesope's tool and make a bl+el-rpu hevc then run that through mp4 muxer via profile 7.
