Hi all,
Have run into a few troublesome discs on my Asus drive, so I've purchased an LG BU40N to try. A little confused on what to do assuming the drive comes with the newest factory firmware. It sounds like I need to cross flash it to a different drive and then downgrade. Which drive though?
Is it the general consensus that the BU40N tends to have fewer issues than other drives?
Info on flashing LG BU40N
Re: Info on flashing LG BU40N
You should post what Makemkv reports about your firmware since there are several versions of MK firmware for this type of drive. We'll see then.
filmgeek47
Do not crossflash itfilmgeek47 wrote: ↑Mon Apr 06, 2020 7:14 pmHi all,
Sorry to hijack but I thought this might less annoying than starting a new thread.
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO7JCR84725
Firmware date: 2119-05-08 11:46
Highest AACS version: 68
Which MK fw should I use?
That question was answered here now:jamisonia wrote: ↑Wed Apr 08, 2020 9:40 pmSorry to hijack but I thought this might less annoying than starting a new thread.
Revision: 1.03
https://www.makemkv.com/forum/viewtopic ... 16&t=21910
The OP created a whole new post for this again for some odd reason anyways.
