1. Does anyone have an example of an mplayer command which will playback a Bluray (either vc-1/h.264/mpeg2) MakeMKV stream using VDPAU with 6ch Dolby TrueHD/DTS-HD decoding (falling back to regular DD, DTS) AND forced (english) subtitles.
Bonus points if you can mix the centre channel into the fronts for 4.1 (mplayer pan command does this it seems)
2. Can I just confirm the correct MakeMKV commandline to stream a Bluray disc and is there a way to automatically stream the main title (i.e longest) If not, how do I determine the correct title for the main feature?
						mplayer command for BluRay stream with HD audio and VDPAU
				thecapsaicinkid
				thecapsaicinkid
Re: mplayer command for BluRay stream with HD audio and VDPA
Here's my full command, mplayer needed the cache command to play smoothly.
One problem, mplayer crashes if I attempt to seek, should this work?
makemkvcon stream disc:0 --cache=128 --minlength=4800Code: Select all
mplayer -fs -demuxer lavf -vo vdpau:hqscaling=1 -vc ffmpeg12vdpau,ffh264vdpau,ffvc1vdpau,ffwmv3vdpau, -vfm ffmpeg, -ao pulse -ac fftruehd,ffdca,ffeac3,ffac3,fflpcm, -afm ffmpeg, -alang en -slang en -forcedsubsonly -channels 6 -af volnorm -cache 8192 -dvd-device /dev/dvd1 http://localhost:51000/stream/title0.ts
					Last edited by thecapsaicinkid on Sat Nov 06, 2010 7:57 pm, edited 1 time in total.
				thecapsaicinkid
Any ideas why mplayer can't seek? It reports the file is 'not seekable'.
mplayer can't seek in web streams.
