Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB'
imfergus
Post by imfergus »
hello all.
i pulled a drive from an old blu-ray player so i could try and rip some blu-rays gifted by someone.
however, makemkv is throwing me errors (as per thread title):
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
dvdfab seems to be able to read the contents fine, and can output, but i would like to use makemkv.
any advice would be greatly appreciated
imfergus
Re: Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB'
Post by imfergus »
anybody?
i searched all i can, but the fact that Dvd-Fab can read the discs implies its not hardware.
BlueMac77
Post by BlueMac77 »
imfergus wrote:
Thu Apr 02, 2020 11:43 am
anybody?
Can you indicate what OS are you on and how is your blu-ray connected to your PC. Are you using the latest version of MakeMKV
imfergus
Post by imfergus »
BlueMac77 wrote:
Thu Apr 02, 2020 6:13 pm
certainly.
windows 10 version 1909 OS Build 18363.720.
drive has been tried via sata directly, and via a sata-usb adapter (modified to fit the non-standard drive).
MakeMKV Beta Version 1.15.0(x64-release)
also
Ubuntu 18.04.4 LTS
using a usb adapter
MakeMKV v1.15.0 Linux(x64-release) (built following the instructions on this forum)
the drive itself appears to work perfectly since DVD-Fab managed to extract all the files from the blu-ray i ripped, but its done it in a very simplistic way, and its honestly a very clunky piece of software.
BlueMac77
Post by BlueMac77 »
@iimfergus. Since your using the latest version of MakeMKV, not sure why you’re getting the Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD” Years ago I once encountered a similar Scsi error message, the solution I did was to get a newer version of MakeMKV and that solved the problem. It’s likely the AACS version on the disc is quite new and the old version of MakeMKV app is not updated in reading newer AACS version.
imfergus
Post by imfergus »
BlueMac77 wrote:
Mon Apr 06, 2020 5:20 pm
it happens whatever blu-ray disc i put into the drive.
i have tried:
District 9
Transformers Revenge of the Fallen
Star Trek II Wrath of khan
and the first one i tried: an anime blu-ray set by the name of "Rokka - Braves of the Six Flowers"
all produce the same result.
i tried testing again, and received this:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:9'
Saved AACS dump file as <user>/.MakeMKV/MKB_v12_Star_Trek_II_The_Wrath_of_Khan_099A.tgz
Grauhaar
Post by Grauhaar »
Because you have and SCSI Interface protokoll problem, I think the drive from an old Blu-ray payer does not understand the commands.
Good Luck :)
BlueMac77
Post by BlueMac77 »
imfergus wrote:
Sun Apr 12, 2020 1:07 pm
i have tried:
District 9
Sorry, I could not think of other possible solutions to your problem. On my end I didn't have major issues with MakeMKV on various optical drive brands. I also have an old Pioneer blu-ray BDR-2007 from 2011 and a Sony DVD 2006 that still works fine with MakeMKV
imfergus
Post by imfergus »
Grauhaar wrote:
Sun Apr 12, 2020 1:35 pm
it has a standard sata interface, is read as a standard sata drive, and was able to read the discs with another application (DVD-Fab).
saturn2888
Post by saturn2888 »
I got a bunch of errors just now like this when reading the "Hook" Ultra HD Blu-ray disc. It read the titles just fine though.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8749314048'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '8749314048'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8749314048'
All of my other discs work fine, but this one does not work. My drives are all ASUS 5.25" USB Blu-ray 16x and flashed with the LG firmware 1.02.
Is it possible this could happen with a counterfeit disc? I just bought a bunch of movies on Amazon yesterday and started ripping them today. "Hook" came in a different-looking black case than the others. The corners are rounder on the right-side of the box. I'm wondering if that's related or if it's just how Tri-star puts out movies.
saturn2888
Just noticed this same issue with the Ultra HD Blu-ray of Grease. The Blu-ray seems to be reading fine.
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom2' at offset '7798910976'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '7798910976'
Failed to save title 0 to file G:/Disc-Rips/Grease/Grease_t00.mkv
Not sure what's going on here.
saturn2888
Also wasn't able to rip Forrest Gump Ultra HD Blu-ray:
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '19674034176'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '19674034176'
Failed to save title 0 to file G:/Disc-Rips/Forrest Gump/Forrest Gump_t00.mkv
