Knives Out - US Retail
Re: Knives Out - US Retail
FYI, I broke out my really old computer that has an internal LG bluray drive and was able to read the disc, so all is good.
The initial post is correct, 0628, for amazon disc; I checked with procmon as well.
Title information
Name: Knives Out (English)
Source file name: 00628.mpls
Duration: 2:10:13
Chapters count: 16
Segment count: 15
Segment map: 510,505,513,512,502,506,504,519,507,518,520,509,508,503,515
File name: Knives Out_t208.mkv
makemkv suggested :
Title information
Comment: FPL_MainFeature
Source file name: 00180.mpls
Duration: 2:10:22
Chapters count: 17
Segment count: 15
Segment map: 510,501,513,512,502,506,504,519,507,518,520,509,508,503,515
File name: Knives Out-FPL_MainFeature_t01.mkv
Not much of a difference, 505 to 501. Close Mike. Thanks.
Title information
Duration: 2:10:13
Chapters count: 16
Segment count: 15
makemkv suggested :
Title information
Duration: 2:10:22
Chapters count: 17
Segment count: 15
I have been backing up my movies for some time now and depending on posts, such as these, to define which title to rip. I have decided that I want to venture out of this habit and learn how to generate this information myself. Would anyone be able to point me toward a good source of information to do this? Thank you in advance for the information.ChrisCaPWN wrote: ↑Sat Feb 22, 2020 1:11 amRental version is 00234.mpls
Name: Knives Out Source file name: 00234.mpls Duration: 2:10:13 Chapters count: 16 Size: 28.3 GB Segment count: 15 Segment map: 506,511,519,505,513,510,502,514,507,509,504,516,518,508,515 File name: Knives Out_t90.mkvCode: Select all
6:34:19.9765545 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\02797.m2ts SUCCESS 6:34:25.3467140 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\03340.m2ts SUCCESS 6:34:42.8799731 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\03340.m2ts SUCCESS 6:34:42.8802004 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\02797.m2ts SUCCESS 6:35:06.8384315 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00506.m2ts SUCCESS 6:35:07.8909582 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00511.m2ts SUCCESS 6:35:52.3120919 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00519.m2ts SUCCESS 6:35:54.9246648 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00505.m2ts SUCCESS 6:36:25.9009886 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00513.m2ts SUCCESS 6:36:27.0010794 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00510.m2ts SUCCESS 6:36:45.1229902 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00502.m2ts SUCCESS 6:36:46.3064175 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00514.m2ts SUCCESS 6:37:25.7124633 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00507.m2ts SUCCESS 6:37:27.3484069 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00509.m2ts SUCCESS 6:38:13.0941563 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00504.m2ts SUCCESS 6:38:14.6584158 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00516.m2ts SUCCESS 6:38:34.6663677 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00518.m2ts SUCCESS 6:38:35.7495252 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00508.m2ts SUCCESS 6:38:58.4501001 PM PowerDVDMovie.exe 6624 CloseFile G:\BDMV\STREAM\00515.m2ts SUCCESS
moviechamp1859
can confirm 00234.mpls for redbox version. i ripped and watched the entire movie to confirm as well.
ChrisCaPWN
Check out this post by unab0mb. It's a very detail step by step on the process. Hope it helps!cwshore wrote: ↑Sun Mar 08, 2020 2:41 pmI have been backing up my movies for some time now and depending on posts, such as these, to define which title to rip. I have decided that I want to venture out of this habit and learn how to generate this information myself. Would anyone be able to point me toward a good source of information to do this? Thank you in advance for the information.ChrisCaPWN wrote: ↑Sat Feb 22, 2020 1:11 amRental version is 00234.mpls
https://www.makemkv.com/forum/viewtopic.php?t=16251Re: Knives Out - US Retail
To add to the long list of replies for Redbox version, I watched the "main feature" 225 after ripping it and it's definitely wrong. 234 seems to be the right call.
therapy80301
Though it looks like a retail copy from DVD.com, only rental 00234.mpls/Knives Out_t111.mkv correlates and it does not work for me. It goes out of sequence at 32:24. This disc does not have 628 nor any segment maps starting with 510. They're all 506 for the first segment. New segment map perhaps for DVD.com?Title information
Duration: 2:10:13
Chapters count: 16
Segment count: 15
File name: Knives Out_t111.mkv
My computer is not capable of playing blu-rays or doing logging with powerdvd.
Any ideas?
ChrisCaPWN
Check the segment map to see if all of the segments are the same. If they are not, there is going to be issues with proper playback. If it is the same, it's definitely correct.Though it looks like a retail copy from DVD.com, only rental 00234.mpls/Knives Out_t111.mkv correlates and it does not work for me. It goes out of sequence at 32:24. This disc does not have 628 nor any segment maps starting with 510. They're all 506 for the first segment. New segment map perhaps for DVD.com?
Any ideas?
If it is different, and you have no playback options on your computer, your only option is to go line by line checking the segment maps to find the one that is correct as listed.
For curiosity, can you run your decrypted folder through GetMPLS and see what playlist is recommended? If the wrong one is recommended (and will probably be), any different m2ts files will be highlighted blue in the playlist/segment window.ChrisCaPWN wrote: ↑Thu Apr 02, 2020 2:02 amCheck the segment map to see if all of the segments are the same. If they are not, there is going to be issues with proper playback. If it is the same, it's definitely correct.Though it looks like a retail copy from DVD.com, only rental 00234.mpls/Knives Out_t111.mkv correlates and it does not work for me. It goes out of sequence at 32:24. This disc does not have 628 nor any segment maps starting with 510. They're all 506 for the first segment. New segment map perhaps for DVD.com?
Any ideas?
therapy80301
Well, the segment map from my 234.mpls matches those from other 234.mpls segment maps whether they be the same title (111) as mine or different (90). Weird.ChrisCaPWN wrote: ↑Thu Apr 02, 2020 2:02 amCheck the segment map to see if all of the segments are the same. If they are not, there is going to be issues with proper playback. If it is the same, it's definitely correct.Though it looks like a retail copy from DVD.com, only rental 00234.mpls/Knives Out_t111.mkv correlates and it does not work for me. It goes out of sequence at 32:24. This disc does not have 628 nor any segment maps starting with 510. They're all 506 for the first segment. New segment map perhaps for DVD.com?
Any ideas?
therapy80301
Well, the segment map from my 234.mpls matches those from other members' 234.mpls segment maps whether they be the same title (111) as mine or different (90). Weird.ChrisCaPWN wrote: ↑Thu Apr 02, 2020 2:02 amCheck the segment map to see if all of the segments are the same. If they are not, there is going to be issues with proper playback. If it is the same, it's definitely correct.
therapy80301
Norton doesn't like GetMPLS. Do you, the creator, promise it's safe?MartyMcNuts wrote: ↑Thu Apr 02, 2020 3:08 amFor curiosity, can you run your decrypted folder through GetMPLS and see what playlist is recommended? If the wrong one is recommended (and will probably be), any different m2ts files will be highlighted blue in the playlist/segment window.
Does Norton like anything these days!!therapy80301 wrote: ↑Thu Apr 02, 2020 8:43 amNorton doesn't like GetMPLS. Do you, the creator, promise it's safe?MartyMcNuts wrote: ↑Thu Apr 02, 2020 3:08 amFor curiosity, can you run your decrypted folder through GetMPLS and see what playlist is recommended? If the wrong one is recommended (and will probably be), any different m2ts files will be highlighted blue in the playlist/segment window.
Yes it is safe.
therapy80301
Yeah I watched the whole movie, and just now I checked again. No issue like that.therapy80301 wrote: ↑Fri Apr 03, 2020 9:08 pmAre you sure this map doesn't have an out of order segment at 32:06? Where it cuts to a short segment of Captain America being interrogated by James Bond?
