Post by shawnc22 » Tue Mar 31, 2020 9:01 pm
Angryunibrow wrote: Tue Mar 31, 2020 8:57 pm
shawnc22 wrote: Tue Mar 31, 2020 8:36 pm Ah that does seem like a plausible explanation. I personally have never gotten profile 7 files to work on my B9, but people previously in this thread have reported that dual track dual layer profile 7 mp4 remuxes made with mp4muxer play without issue on their LG C# internal players. If anyone with a C# TV can try a mp4 prof7 remux of an FEL movie, that would be helpful.
I just watched Knives Out which is FEL on the LG C8.
This was Profile 7 with DTS-HD MA 7.1 audio.
Zero issues.
Made with separate tracks in mp4muxer without going through yusecope's tool first, right?
Angryunibrow
Post by Angryunibrow » Tue Mar 31, 2020 9:02 pm
jcdr428 wrote: Tue Mar 31, 2020 9:00 pm
Angryunibrow wrote: Tue Mar 31, 2020 8:57 pm I just watched Knives Out which is FEL on the LG C8.
Zero issues.
:) So the best option is still to keep profile 7, until RPU info has been checked to be fully compliant.
Agree, I just wish my TV could play Atmos :)
I'm converting all Atmos to DTS-HD MA 7.1 and it streams the core DTS so its something I guess.
Angryunibrow
Post by Angryunibrow » Tue Mar 31, 2020 9:03 pm
shawnc22 wrote: Tue Mar 31, 2020 9:01 pm
Zero issues.
Correct, this was mp4muxer and mp4box. - the old fashion way from a month ago :)
ragico
Post by ragico » Tue Mar 31, 2020 9:05 pm
shawnc22 wrote: Tue Mar 31, 2020 8:36 pm If anyone with a C# TV can try a mp4 prof7 remux of an FEL movie, that would be helpful.
Yes, I did many mp4 and all play perfectly in LG C8 via plex/emby webOS apps, Some titles: First Man, Gemini man, BlacKkKlansman, Mission Impossible - Fallout, Mission Impossible - Rogue Nation, The Deer Hunter, Transformers, and many more.
Angryunibrow
Post by Angryunibrow » Tue Mar 31, 2020 9:10 pm
Zero issues.
@jcdr428
If I use the latest tsmuxer I can drop in the BL.hevc and EL.hevc and then the blu-ray playlist to select the Atmos and make a correct Profile 7 .ts with Atmos correct?
I know if will not play on my TV, but I can select the core .ac3 file and in theory it should be just fine.
This I would prefer right now because I have no issues playing them and I know i'm playing the movie with out alteration in its true form.
I shouldn't need any other tool in this case right?
Post by shawnc22 » Tue Mar 31, 2020 9:17 pm
Angryunibrow wrote: Tue Mar 31, 2020 9:10 pm
Zero issues.
@jcdr428
I think that should be the expectation and worth a try, but if I'm remembering correctly, I believe that @RESET_9999 has said in the past that those prof 7 .ts files made straight from the original m2ts will only play on the x700 or oppo. If that is the case, then there's a question of what's being done different between mp4muxer and tsmuxer to create prof 7 dual track files.
Angryunibrow
Post by Angryunibrow » Tue Mar 31, 2020 9:22 pm
shawnc22 wrote: Tue Mar 31, 2020 9:17 pm
@jcdr428
You know what I did try this and it only played HDR, I remember now - I've done so many tests I can't keep track.
I do not think the LG player can do DV in .ts, I even tried .m2ts for the hell of it and that was also only HDR
I would love Profile 7 with Atmos to play on my TV, even if I could only use the core .ac3 right now.
HDMI 2.1 Earc will solve that someday and it would be nice to have a full profile 7 with Atmos working.
I made the comment that tsmuxer was assigning profile 7.05, while mp4muxer was profile 7.06 - I do not know if that matters.
Maxoumax6
Post by Maxoumax6 » Tue Mar 31, 2020 9:41 pm
Hi guys,
Just a test. I've dowloaded this BD https://www.demo-world.eu/2018/08/30/do ... arch-2018/
I used ffmpeg to get the BL and EL files, then used yusesope's tool (v. 0.0.3) with "-mode 2" option.
I used Ts (git-2ff96ce) to remux that with the "e-ac3 dolby digital with dolby atmos" track. The TrueHD track is not played by the internal player of the TV.
I manage to trigger both DolbyVision and DoblyAtmos on my LG C8 and that's cool!
Seems to be that BL+RPU profile 5 works smoothly on C8.
Post by shawnc22 » Tue Mar 31, 2020 9:43 pm
Putting a couple sample mediainfos here for reference in regards to prof 7 files (all made with joker sample tracks):
-Made with mp4muxer. Reported working on LG C# internal players
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 23 s 773 ms
Bit rate                                 : 32.3 Mb/s
Bits/(Pixel*Frame)                       : 0.162
Stream size                              : 91.5 MiB (100%)
Encoded date                             : UTC 2020-03-23 23:05:44
Tagged date                              : UTC 2020-03-23 23:05:44
Maximum Content Light Level              : 992 cd/m2
Maximum Frame-Average Light Level        : 120 cd/m2
Codec configuration box                  : hvcC
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Bit rate                                 : 64.1 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.001
Stream size                              : 186 KiB (0%)
-Made with bb51a5f build of tsmuxer
Video #1
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL / SMPTE ST 2086, HDR10 compatible
Duration                                 : 23 s 648 ms
Video #2
Have you tried build bb51a5f to see if that makes a difference since it looks like it's no longer being labeled as 07.05? If still the same result, could the issue be caused by the BL track in the TS file having the DV tag while the mp4 file does not?
jcdr428
Post by jcdr428 » Tue Mar 31, 2020 10:01 pm
Angryunibrow wrote: Tue Mar 31, 2020 9:22 pm I made the comment that tsmuxer was assigning profile 7.05, while mp4muxer was profile 7.06 - I do not know if that matters.
@Angryunibrow it should be 7.06... I'll fix it. However the level is only related to pixel rate, marking 7.05 does not make any difference if your SoC can play 7.06 pixel rates. The most obvious reason why the TS plays on Blu-ray players only is the HDMV (Blu-ray) descriptors. Standard ETSI descriptors might allow DV but would remove compatibility with PGS, ac3/eac3 and ac3/TrueHD.
Angryunibrow
Post by Angryunibrow » Tue Mar 31, 2020 10:06 pm
jcdr428 wrote: Tue Mar 31, 2020 10:01 pm
That's right I remember you mentioning that.
Oh well, can't have it all I guess.
MastaG
Post by MastaG » Wed Apr 01, 2020 8:10 am
shawnc22 wrote: Tue Mar 31, 2020 9:43 pm Putting a couple sample mediainfos here for reference in regards to prof 7 files (all made with joker sample tracks):
Video #1
Codec ID                                 : hev1
Video #2
Codec ID                                 : hev1
Video #1
Video #2
So if I understand correctly we still didn't get single track video with full EL layer (profiel 04 or 06) to work on LG C# without stuttering?
kazekami20
Post by kazekami20 » Wed Apr 01, 2020 8:53 am
Hi! Can anyone explain the correct steps for the Nvidia Shield 2019 whith lg C9?
Many thanks!
oldirtydog
Post by oldirtydog » Wed Apr 01, 2020 1:50 pm
kazekami20 wrote: Wed Apr 01, 2020 8:53 am Hi! Can anyone explain the correct steps for the Nvidia Shield 2019 whith lg C9?
Many thanks!
And please tell the all steps :) i have a C9 and think to buy panasonic ub4500 with Atmos and Dolby Vision,to play with Vision because on my PC only HDR...and the C9 not playing losseles audio...
Post by shawnc22 » Wed Apr 01, 2020 3:18 pm
MastaG wrote: Wed Apr 01, 2020 8:10 am So if I understand correctly we still didn't get single track video with full EL layer (profiel 04 or 06) to work on LG C# without stuttering?
Correct, that is my understanding as well from the latest tests we have done.
