@shawnc22 does FEL stutter as well with profile 4 ?
Yep, all the remuxes I've made in profile 4 have all stuttered on the LG internal player, regardless of MEL/FEL. I still think the sample size is a bit small to conclusively say the stuttering in profile 6 videos is caused by MEL/FEL. I have only tested 2 of each for full length titles.
The player probably does not detect the FEL condition. The way FEL is triggered in the RPU of profile 7 and of profile 4/6 seems to be different. So it is not as simple as copying the EL/RPU from the second track to the first.shawnc22 wrote: ↑Tue Mar 31, 2020 8:14 pmYep, all the remuxes I've made in profile 4 have all stuttered on the LG internal player, regardless of MEL/FEL. I still think the sample size is a bit small to conclusively say the stuttering in profile 6 videos is caused by MEL/FEL. I have only tested 2 of each for full length titles.
This is what the Dolby documentation says:
Edit: if anyone is interested in parsing RPU information https://patentimages.storage.googleapis ... 9132A1.pdf
Ah that does seem like a plausible explanation.  I personally have never gotten profile 7 files to work on my B9, but people previously in this thread have reported that dual track dual layer profile 7 mp4 remuxes made with mp4muxer play without issue on their LG C# internal players.  If anyone with a C# TV can try a mp4 prof7 remux of an FEL movie, that would be helpful.
Eg in the RPU patent:
"rpu_type specifies the type of this RPU and must be 2 for the BDA Ultra HD Blu-ray Option-A HDR coding system."
"rpu_format specifies further information related to the prediction and coding process given rpu_type. The value of rpu_format must remain the same for the entire sequence. For BDA Ultra-HD Blu-ray, rpu_format must be set to 0."
"vdr_rpu_profile and vdr_rpu_level specify the profile and the level constraints that the Dolby Vision reference processing conforms to, and must be 1 and 0, respectively, for BDA Option-A HDR."
"For BDA Ultra-HD Blu-ray, vdr_seq_info_present_flag must be set to 0."
"chroma_resampling_explicit_filter_flag must be equal to 0 for Ultra-HD Blu-ray."
etc. etc.
These values/RPUs are valid for profile 7 but may not be for other profiles.
So somebody must parse the RPU metadata for profile 7 and profile 4/6 and analyse the difference.
etc. etc.
				Angryunibrow
I just watched Knives Out which is FEL on the LG C8.shawnc22 wrote: ↑Tue Mar 31, 2020 8:36 pmAh that does seem like a plausible explanation. I personally have never gotten profile 7 files to work on my B9, but people previously in this thread have reported that dual track dual layer profile 7 mp4 remuxes made with mp4muxer play without issue on their LG C# internal players. If anyone with a C# TV can try a mp4 prof7 remux of an FEL movie, that would be helpful.
This was Profile 7 with DTS-HD MA 7.1 audio.
Zero issues.
Angryunibrow wrote: ↑Tue Mar 31, 2020 8:57 pmI just watched Knives Out which is FEL on the LG C8.
Zero issues.
 So the best option is still to keep profile 7, until RPU info has been checked to be fully compliant.
 So the best option is still to keep profile 7, until RPU info has been checked to be fully compliant.Re: Dolby Vision now possible through MP4 Mux.
Made with separate tracks in mp4muxer without going through yusecope's tool first, right?Angryunibrow wrote: ↑Tue Mar 31, 2020 8:57 pmI just watched Knives Out which is FEL on the LG C8.shawnc22 wrote: ↑Tue Mar 31, 2020 8:36 pmAh that does seem like a plausible explanation. I personally have never gotten profile 7 files to work on my B9, but people previously in this thread have reported that dual track dual layer profile 7 mp4 remuxes made with mp4muxer play without issue on their LG C# internal players. If anyone with a C# TV can try a mp4 prof7 remux of an FEL movie, that would be helpful.
Zero issues.
				Angryunibrow
Agree, I just wish my TV could play Atmosjcdr428 wrote: ↑Tue Mar 31, 2020 9:00 pmAngryunibrow wrote: ↑Tue Mar 31, 2020 8:57 pmI just watched Knives Out which is FEL on the LG C8.
Zero issues.So the best option is still to keep profile 7, until RPU info has been checked to be fully compliant.
I'm converting all Atmos to DTS-HD MA 7.1 and it streams the core DTS so its something I guess.
				Angryunibrow
Correct, this was mp4muxer and mp4box. - the old fashion way from a month agoshawnc22 wrote: ↑Tue Mar 31, 2020 9:01 pmMade with separate tracks in mp4muxer without going through yusecope's tool first, right?Angryunibrow wrote: ↑Tue Mar 31, 2020 8:57 pmI just watched Knives Out which is FEL on the LG C8.shawnc22 wrote: ↑Tue Mar 31, 2020 8:36 pmAh that does seem like a plausible explanation. I personally have never gotten profile 7 files to work on my B9, but people previously in this thread have reported that dual track dual layer profile 7 mp4 remuxes made with mp4muxer play without issue on their LG C# internal players. If anyone with a C# TV can try a mp4 prof7 remux of an FEL movie, that would be helpful.
Zero issues.
Yes, I did many mp4 and all play perfectly in LG C8 via plex/emby webOS apps, Some titles: First Man, Gemini man, BlacKkKlansman, Mission Impossible - Fallout, Mission Impossible - Rogue Nation, The Deer Hunter, Transformers, and many more.
				Angryunibrow
@jcdr428jcdr428 wrote: ↑Tue Mar 31, 2020 9:00 pmAngryunibrow wrote: ↑Tue Mar 31, 2020 8:57 pmI just watched Knives Out which is FEL on the LG C8.
If I use the latest tsmuxer I can drop in the BL.hevc and EL.hevc and then the blu-ray playlist to select the Atmos and make a correct Profile 7 .ts with Atmos correct?
I know if will not play on my TV, but I can select the core .ac3 file and in theory it should be just fine.
This I would prefer right now because I have no issues playing them and I know i'm playing the movie with out alteration in its true form.
I shouldn't need any other tool in this case right?
I think that should be the expectation and worth a try, but if I'm remembering correctly, I believe that @RESET_9999 has said in the past that those prof 7 .ts files made straight from the original m2ts will only play on the x700 or oppo. If that is the case, then there's a question of what's being done different between mp4muxer and tsmuxer to create prof 7 dual track files.Angryunibrow wrote: ↑Tue Mar 31, 2020 9:10 pm@jcdr428jcdr428 wrote: ↑Tue Mar 31, 2020 9:00 pmAngryunibrow wrote: ↑Tue Mar 31, 2020 8:57 pmI just watched Knives Out which is FEL on the LG C8.
				Angryunibrow
shawnc22 wrote: ↑Tue Mar 31, 2020 9:17 pmI think that should be the expectation and worth a try, but if I'm remembering correctly, I believe that @RESET_9999 has said in the past that those prof 7 .ts files made straight from the original m2ts will only play on the x700 or oppo. If that is the case, then there's a question of what's being done different between mp4muxer and tsmuxer to create prof 7 dual track files.Angryunibrow wrote: ↑Tue Mar 31, 2020 9:10 pm@jcdr428
You know what I did try this and it only played HDR, I remember now - I've done so many tests I can't keep track.
I do not think the LG player can do DV in .ts, I even tried .m2ts for the hell of it and that was also only HDR
I would love Profile 7 with Atmos to play on my TV, even if I could only use the core .ac3 right now.
HDMI 2.1 Earc will solve that someday and it would be nice to have a full profile 7 with Atmos working.
I made the comment that tsmuxer was assigning profile 7.05, while mp4muxer was profile 7.06 - I do not know if that matters.
Hi guys,
Just a test. I've dowloaded this BD https://www.demo-world.eu/2018/08/30/do ... arch-2018/
I used ffmpeg to get the BL and EL files, then used yusesope's tool (v. 0.0.3) with "-mode 2" option.
I used Ts (git-2ff96ce) to remux that with the "e-ac3 dolby digital with dolby atmos" track. The TrueHD track is not played by the internal player of the TV.
I manage to trigger both DolbyVision and DoblyAtmos on my LG C8 and that's cool!
Seems to be that BL+RPU profile 5 works smoothly on C8.
