Star Wars 4Ks
Re: Star Wars 4Ks
You don't get a response. The title key will simply appear in the next download of the hashed keys.
Re: Star Wars 4Ks
Episode 3 Revenge of the Sith didn't work for me. Dump file submitted.
The rest worked.
The rest worked.
Re: Star Wars 4Ks
Many thanks to everybody here. I'm patiently awaiting the arrival of mine as UPS had a little issue and my delivery date is now unknown, but that's to be expected with everything going on. The positive in this is that by the time it does arrive, the work everyone here has been doing will help ensure it rips successfully. So thanks again all!
Re: Star Wars 4Ks
I was able to successfully do Episode 1, but I kept getting the same error. When I went to the file with the AV/sync issue there definitely is a stutter there and a little audio "pop". Is this a dirty disc issue or just an outright defective disc issue?
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 2125824, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 5031936, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 5965824, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 9394176, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 9775104, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 11464704, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 12324864, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 12718080, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 12730368, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 13578240, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 14807040, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 15624192, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 15661056-15667200, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 16527360, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 17369088, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 17381376, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 18843648, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 20729856, attempting to work around
The source file '/BDMV/STREAM/00091.m2ts' is corrupt or invalid at offset 23721984, attempting to work around
The source file '/BDMV/STREAM/00062.m2ts' is corrupt or invalid at offset 8251392, attempting to work around
The source file '/BDMV/STREAM/00062.m2ts' is corrupt or invalid at offset 29589504, attempting to work around
The source file '/BDMV/STREAM/00063.m2ts' is corrupt or invalid at offset 11304960, attempting to work around
The source file '/BDMV/STREAM/00063.m2ts' is corrupt or invalid at offset 13848576, attempting to work around
The source file '/BDMV/STREAM/00063.m2ts' is corrupt or invalid at offset 14333952, attempting to work around
The source file '/BDMV/STREAM/00063.m2ts' is corrupt or invalid at offset 15028224, attempting to work around
The source file '/BDMV/STREAM/00063.m2ts' is corrupt or invalid at offset 15581184, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 7471104, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 14856192, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 15003648, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 18186240, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 19593216, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 21866496, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 22548480, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 22941696, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 25896960, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 27131904, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 27144192, attempting to work around
The source file '/BDMV/STREAM/00090.m2ts' is corrupt or invalid at offset 27998208, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 11378688, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 20269056, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 21657600, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 22505472, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 24600576, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 25847808, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 29411328, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 30498816, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 31746048, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 35936256, attempting to work around
The source file '/BDMV/STREAM/00074.m2ts' is corrupt or invalid at offset 35948544, attempting to work around
AV sync issue in stream 0 at 0:54:05.033 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:05.075 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:05.116 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:54:05.158 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:05.200 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:05.242 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:05.283 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:54:05.325 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:05.367 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:05.408 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:05.450 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:54:05.492 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:05.533 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:05.575 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:05.617 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:54:05.659 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:05.700 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:05.742 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:05.784 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:54:05.825 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:05.867 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:05.909 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:05.992 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:06.034 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:06.076 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:06.117 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:54:06.159 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:54:06.201 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:54:06.243 : video frame timecode differs by -41.713ms
AV sync issue in stream 0 at 0:54:06.284 : video frame timecode differs by -41.711ms
AV sync issue in stream 1 at 0:54:04.992 with duration of 42.5ms : 51 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 0 at 0:54:24.511 : video stream has 33 frames with invalid timecodes
AV synchronization issues were found in file 'Star Wars- The Phantom Menace_t08.mkv' (title #9)
Forced subtitles track #5 turned out to be empty and was removed from output fileRe: Star Wars 4Ks
Those are read errors. And I've seen reports of some people having to get replacements for these foolish discs so try cleaning the disc but know that there may be some defective ones out there.
I'm still waiting for UPS to ship mine, as well. I don't see that happening for at least a few more days. SIGH.
Re: Star Wars 4Ks
I just tried Rogue One and it told me it couldn't find the key, then I switched my DNS from FIOS to Google, restarted MakeMKV and it started working.Jango8 wrote: ↑Tue Mar 31, 2020 4:52 amLooks like I found the culprit.
I am using a Unifi USG router. I have some Geo blocking in place. The Russian Federation was blocked. the keys pulled by Make MKV are coming from an IP located in Russia. I removed the block on Russia and restarted and now my rips are working.
Hope this helps some
Re: Star Wars 4Ks
Redundant information, but Phantom Menace went, Attack of the Clones did not.
Submitted Attach of the Clones Key.
Re: Star Wars 4Ks
So, for what it's worth, I've had multiple discs in this set that have had this problem so far. All the discs looked perfectly clean, and I went through an embarassing amount of technical troubleshooting before I finally decided to just wipe the discs down with a microfiber cloth.
Suddenly, they're reading just fine.
So, I don't know what they did at the factory, but I'm guessing there's some sort of fine layer of gunk that my terrible eyes just can't see on them. Try giving the discs a (careful, but thorough) cleaning.
wooferocau
Re: Star Wars 4Ks
So,
Rougue One
A New Hope
Empire Strikes Back
Return of the Judi
which of the 4 main file contents is the English Intro ?
Thanks..
Rougue One
A New Hope
Empire Strikes Back
Return of the Judi
Thanks..
Re: Star Wars 4Ks
Good morning to all! When each disc decrypts there are 4 copies of the movie with 4 different languages. How can you tell which one is the English one?
Thanks in advance for any help!
Re: Star Wars 4Ks
The source file name that ends in 800 is English. 00800 is the most common one on Disney-distributed disks.
Re: Star Wars 4Ks
Yeah, I'm getting 4 different playlists in the most recent download version of MakeMKV. This is for Attack of the Clones as an example in the order displayed. All are English language and this is the Best Buy bundled version.
Source file name: 00802.mpls
Segment map: 59,63,64,66,67,69,70,72,73,75,76,78,79,81,82,84
Source file name: 00803.mpls
Segment map: 60,63,64,66,67,69,70,72,73,75,76,78,79,81,82,84
Source file name: 00801.mpls
Segment map: 58,63,64,66,67,69,70,72,73,75,76,78,79,81,82,84
Source file name: 00800.mpls
Segment map: 61,63,65,66,68,69,71,72,74,75,77,78,80,81,83,84
Any ideas?
Any ideas?
Re: Star Wars 4Ks
Bugman I feel your pain. I have the same set and since I cant play the discs to see which playlists are which language. Im diving in and assuming its mpls 800 like most discs with multi-language options, lol. I wish you luck too.
Re: Star Wars 4Ks
As the poster above you said, the english version with the english hardcoded subs for alien dialogue is 800
