Aussie ..The Rise Of Skywalker...
wooferocau
Dump submitted...
wooferocau
Re: Aussie ..The Rise Of Skywalker...
Still no luck..
wooferocau
Have to resort to the old faithfull Oppo 203 this time round...
wooferocau
All working now....Thanks....
Jango8
My Aussie version will not rip. Other movie 4K discs rip perfectly. Any solutions?
Nowhere near enough information. "Does not rip" doesn't tell us if it's a decryption issue (email the dump) or a read error (clean the disc).
Jango8
I submitted the dump via email yesterday for 9 x SW movies.
Here is the log error message:
MakeMKV v1.15.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\XXXXXXXXXXX/MakeMKV_log_1.txt
DEBUG: Code 0 at sMvU$A}zJ$@KgUtt:121275849
Backing up disc into folder "D:/THE_PHANTOM_MEANCE"
Using LibreDrive mode (v05 id=067EFCA8EA7E)
Downloading latest HK to C:\Users\XXXXXXXXXXX/.MakeMKV ...
DEBUG: Code 0 at sMvU$A}zJ$@KgUtt:213135665
Saved AACS dump file as C:\Users\XXXXXXXXXXX/.MakeMKV/MKB20_v72_THE_PHANTOM_MEANCE_AE06.tgz
DEBUG: Code 0 at Ol~"E_@BEikMd^~p:29396092
DEBUG: Code 0 at NR&;1u{bv^'(x Y{l)B:121273411
DEBUG: Code 0 at >=1ji=7|kY2WOH"D3Xr^:29396713
Backup failed
Backup failed
You need to fix this part; otherwise, you can't get the keys that have been generated.Automatic HK downloading is disabled or failed.
Jango8
Why do other 4K discs work then? I can do GOT S08 and Dark Knight series no problems at all.
Probably because you already have them in the most recent hash key file you received; it's only newer disks that you would need to have the latest one.
Check your DNS; if you're not using Google as one of your DNS servers, you may be getting bogus results for the domain that MakeMKV uses, due to "content filtering". And some software will block access to the domain. But, until you can connect and download the latest HK file, you won't be able to decrypt the disk.
iamsmith
Doesn't seem like aussie Rise of Skywalker is in the database, at least the one I forced download of just now.
Did you have any success with the dump file?
