#1921 Post by shawnc22 » Mon Mar 30, 2020 5:34 pm
MastaG wrote:
Mon Mar 30, 2020 5:21 pm
yeah, so profile 4 stutters on LG :)
Now if profile 6 works on both the Shield (also playing the Atmos track) and LG.. then -mode 1 with profile 6 in TS should be the golden combination.
I don't know if it's as simple as saying that prof 4 is no good on the LG. The same Joker sample file that I had previously made in prof 4 played back perfectly with no stutter, it was just the full movie that was stuttering. Plus this official LG sample here: https://4kmedia.org/lg-dolby-comparison-uhd-4k-demo/ is a profile 4 TS with a BL+EL+RPU single track, and that plays back just fine, too
jcdr428
#1922 Post by jcdr428 » Mon Mar 30, 2020 7:35 pm
@shawnc22 thanks for the confirmation on profile 6 working. The patch is pending merge in the official tsMuxer.
Mediainfo must match the following:
Profile 4: BL+EL+RPU, SDR compatible
Profile 5: BL+RPU, (Unspecified colorspace)
Profile 6: BL+EL+RPU, HDR10 compatible
Profile 7: track 1 HDR10 or HDR10+ compatible, track 2 HDR10 compatible
Profile 8: BL+RPU, HDR10 or HLG or SDR compatible
jcdr428
#1923 Post by jcdr428 » Mon Mar 30, 2020 7:42 pm
shawnc22 wrote:
Mon Mar 30, 2020 5:13 pm
Interesting findings as my previous remux of the full joker movie that was prof 4 did stutter on my B9, so seemingly the stutter issue on the LG internal player is related to DV profiling. Also interesting that the Shield is able to play these since it's been mentioned in that past that profile 6 is not supported. As far as my eyes can tell, there is no discerning difference between the profile 6 vs 4 DV remuxes. Not sure what the best step is moving forward, since profile 6 has pretty much been deprecated? I had to go back to a 2016 version of the dolby profiles pdf to even find a mention of it.
- Profile 4: BL+EL+RPU, SDR or (Unspecified colorspace)
- Profile 5: BL+RPU, (Unspecified colorspace)
- Profile 6: BL+EL+RPU, HDR10/+ compatible
- Profile 7: track 1 HDR10/+ compatible, track 2 HDR10 compatible
- Profile 8: BL+RPU, HDR10/+ or HLG or SDR compatible
Edit: Dolby are cutting all compatibility with other HDR formats, so indeed they don't advertise compatibility with former profile 6. And profile 8 is already in "Annex I: Profiles not supported for new applications" in the latest DolbyVisionProfilesLevels_v1_3_2_2019_09_16.pdf
mulucy
#1924 Post by mulucy » Mon Mar 30, 2020 10:24 pm
I am sure others have reported this, but using the "yusecope tool 0.0.3 rev01 -mode 2" with the Tsmuxer 11f852a version produces profile 08.06 in TS container. I was expecting to get a Profile 5.
edit:
It has nothing to do with the Yusecope tool or revision ( experimented a little more ). It's the Tsmuxer, it defaults to profile 4 with a dual-layer and profile 8 with a single layer. Is there a way to choose the profile level before remuxing it? BTW, when playing the profile 4 Black Panther on my Apple 4K ( it only supports the profile 5 AFAIK ), it plays the file as HDR10. I thought the Profile 4 only had backward compatibility with SDR only.
badrobot
#1925 Post by badrobot » Tue Mar 31, 2020 1:14 am
If we have to choose BL+RPU format to rip UHD Blyray disks, I think Profile 5 is a better choice, because apple tv 4k only supports Profile 5, the DVDFab also produces Profile 5 when user chooses BL+RPU.
If we choose Profile 8, maybe only shield tv 2019 support this Profile?
I am not a native English speaker.
Sorry for my bad English.
Angryunibrow
#1926 Post by Angryunibrow » Tue Mar 31, 2020 2:03 am
Can also confirm the 2019 shield and LG C8 plays the Profile 6 files just fine. I did not watch an entire movie but testing 2 movies worked just fine.
Edit: 1917 studders on the LG C8 but plays fine on the shield. (profile 6)
Now if we can just get Nvidia to fix the color issues on the shield playing back Dolby Vision we might get somewhere :)
#1927 Post by shawnc22 » Tue Mar 31, 2020 4:24 am
Ah I guess we did speak too soon. I just tried 1917 as well and it is indeed still stuttering on the LG internal player (fine on the Shield still). For what it's worth, the stuttering when compared to the DV prof 4 video does not seem as severe?
jcdr428
#1928 Post by jcdr428 » Tue Mar 31, 2020 5:40 am
@mulucy it is an old version of tsMuxer, right ? Try my fork bb51a5f : it contains correct profiles 2 to 8. The commit is pending merge with the official tsMuxer.
badrobot
#1929 Post by badrobot » Tue Mar 31, 2020 6:57 am
In the scenario of ripping an UHD DoVi Bluray Disk, according to your commit, single track BL+EL+RPU will result in profile 6, and single track BL+PRU will result in profile 8, is that right?
If it’s correct, it will lose compatibility to popular tvbox, shield 2019 supports DoVi 4,5,8, apple tv only Dovi 5. Full compliance to Dolby Specification maybe ideal, but consider what we can buy from market, is it safer to stay at profile 4 and 5 ?
sorry for my bad english.
mulucy
#1930 Post by mulucy » Tue Mar 31, 2020 9:20 am
Here is the version I been using it 11f852a. It does profile 4 and 8 based on what I have been getting from Black Panther UHD Blu Ray. I think profile 5 for single layer BL+RPU is more universal since it's supported by Apple TV and Fire TV as well.
I will try the linked version above. Is there an option to choose the profile before remuxing it?
DaMacFunkin
#1931 Post by DaMacFunkin » Tue Mar 31, 2020 10:19 am
I would also like to know if it possible to choose the profile before muxing, thanks.
MastaG
#1932 Post by MastaG » Tue Mar 31, 2020 10:30 am
So I tested @jcdr428 PR: https://github.com/justdan96/tsMuxer/pull/269
It now gives me profile 06.
Gemini Man:
$ mediainfo Gemini\ Man\ 2019.ts
General
Complete name                            : Gemini Man 2019.ts
File size                                : 75.4 GiB
Duration                                 : 1 h 57 min
Overall bit rate                         : 92.2 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Bit rate                                 : 86.6 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Bits/(Pixel*Frame)                       : 0.174
Stream size                              : 70.8 GiB (94%)
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 5180 cd/m2
Maximum Frame-Average Light Level        : 1577 cd/m2
Audio #1
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 944 kb/s
Stream size                              : 536 MiB (1%)
Audio #2
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : 135
Stream size                              : 375 MiB (0%)
1917
$ mediainfo 1917\ 2019.ts
General
Complete name                            : 1917 2019.ts
File size                                : 70.3 GiB
Overall bit rate                         : 84.6 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                                 : 6
Bit rate                                 : 79.9 Mb/s
Bits/(Pixel*Frame)                       : 0.402
Stream size                              : 66.4 GiB (95%)
Maximum Frame-Average Light Level        : 168 cd/m2
Audio
Codec ID                                 : 131
Maximum bit rate                         : 7 158 kb/s
Stream size                              : 381 MiB (1%)
It does trigger DV but I still get the same stuttering on my LG C8.
Now I didn't test 1917 earlier so I never had it working before, but Gemini Man was working great using an older rev of TsMuxer which would give it profile 08.
In all test-cases I was using "mode 1" BL+EL+RPU.
Perhaps it's not the profile version that causes the stuttering but something else?
I'll revert back to an older rev of TsMuxer and retry both movies.
Grencola
#1933 Post by Grencola » Tue Mar 31, 2020 1:17 pm
Profile 8 works great on Fire TV. Not sure about Apple TV though since I don't have one to test.
mulucy
#1934 Post by mulucy » Tue Mar 31, 2020 1:41 pm
I have not tried the Fire TV 4K yet, but Apple TV 4K, using the Infuse Pro, recognizes as HDR10. BTW, which media player are you using to play DV files on Fire TV?
yusesope
#1935 Post by yusesope » Tue Mar 31, 2020 1:45 pm
Wow how many posts! :shock:
This is better than Game of Thrones (I hope it will not end like the eighth season :lol: )!
Thank you for your efforts @jcdr428! You're doing a great job!
Now you bring the profiles back to life from the realm of the dead ... the nickname "j" stands for "Jesus", doesn't it?
I had discarded it (profile 6) because I thought it was no longer usable!
But a confirmation seems necessary: ​​some kind soul can post the EXOPLAYER LOG of the Shield when a dvhe.06 file is playing?
Maybe there is a problem with the way you handle "stream_type". For example, the now well-known LG demo (BL+EL+RPU Single PID, dvhe.04) should present a stream_type = 0x24 and not 0x06 after being muxed with tsMuxeR despite color_description_present_flag = 0 and chroma_location_info_present = 0.
Finally, I join people who ask for the possibility to choose the most congenial DV profile: the dvhe.05 files obtained with my tool (or with DVDFab) are not standard at all (we are well aware of that) but there are devices (Apple TV, Fire Stick 4K) which can only play this type of file!
If you don't listen to this request, you force these people to use a longer procedure (mp4muxer + MP4Box) or to give money for a paid software!
It makes no sense to use my tool with the -mode switch set to 1 (BL+EL+RPU) and then expect tsMuxer to return a profile 8 file.
Profile 8 cannot contain the EL layer!
The version of tsMuxeR you are referring to was bugged: it has been corrected starting from THIS problem report!
Do you want a profile 8? Use the "-mode 2" switch!
To try to understand why the 4/6 profile does not work on your TV it would be useful to examine the LOGS of the PLEX client.
