Star Wars 4Ks
tcoble33
Re: Star Wars 4Ks
#16 Post by tcoble33 » Mon Mar 30, 2020 11:24 pm
Hmmm... I just popped in the first disc and am getting this error:
Do I need to update something or make some other adjustment?
Jango8
Re: Star Wars 4Ks
#17 Post by Jango8 » Mon Mar 30, 2020 11:26 pm
I submitted 4K dumps yesterday but mine still do not rip.
Getting this error also: The volume key is unknown for this disc - video can't be decrypted
Swaps
Re: Star Wars 4Ks
#18 Post by Swaps » Mon Mar 30, 2020 11:35 pm
Episode one? I'm working backwards. I'll update when I get there.
Re: Star Wars 4Ks
#19 Post by SamuriHL » Mon Mar 30, 2020 11:49 pm
If you're getting a volume key error, send the dump that's generated to svq at makemkv.com so the title key can be added.
My set just shipped finally. I can't wait to get it!
tr0n9h
Re: Star Wars 4Ks
#20 Post by tr0n9h » Mon Mar 30, 2020 11:54 pm
anyone getting this error when trying rogue one 4k
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '35979264'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '35985408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00072.m2ts' at offset '35985408'
Re: Star Wars 4Ks
#21 Post by Woodstock » Tue Mar 31, 2020 12:43 am
Those are typical read errors, with the drive trying very hard to read a marginal sector. Try cleaning the disk. Yes, even though it is brand new.
tcoble33
Re: Star Wars 4Ks
#22 Post by tcoble33 » Tue Mar 31, 2020 1:20 am
Jango8 wrote: Mon Mar 30, 2020 11:26 pm I submitted 4K dumps yesterday but mine still do not rip.
Funny, so far I've just gotten this error for Phantom Menace. Episodes 2 and 3 seem to be fine. Maybe it's just an issue with the dump for the first disc?
Re: Star Wars 4Ks
#23 Post by Woodstock » Tue Mar 31, 2020 3:12 am
Are you also getting this error?
If you have disabled contacting the web server for updates, or your have software preventing contacting it, you can't get the latest key file.
Sometimes it's as simple as making sure your using a DNS server that doesn't block portions of the internet. Read the start and end of the "sticky" topic about this error message.
Swaps
Re: Star Wars 4Ks
#24 Post by Swaps » Tue Mar 31, 2020 4:37 am
Just finished 1-7, 9, and Rogue One. If a disc won't decrypt, submit dump.
Jango8
Re: Star Wars 4Ks
#25 Post by Jango8 » Tue Mar 31, 2020 4:52 am
Looks like I found the culprit.
I am using a Unifi USG router. I have some Geo blocking in place. The Russian Federation was blocked. the keys pulled by Make MKV are coming from an IP located in Russia. I removed the block on Russia and restarted and now my rips are working.
Hope this helps some
whoopcrap
Re: Star Wars 4Ks
#26 Post by whoopcrap » Tue Mar 31, 2020 6:15 pm
Swaps wrote: Tue Mar 31, 2020 4:37 am Just finished 1-7, 9, and Rogue One. If a disc won't decrypt, submit dump.
What did you just finish? Actually ripping them or creating keys?
My 1 and 3 won't decrypt, 2 did though.
tcoble33
Re: Star Wars 4Ks
#27 Post by tcoble33 » Tue Mar 31, 2020 6:36 pm
I've successfully ripped episodes/discs 2 - 9, but am still getting the "unknown volume key" / "failed to open disc" error for ep. #1 - Phantom Menace. Anyone else having trouble with that disc?
I'd gladly submit a dump, but have no idea how to do that. Can anyone provide a step-by-step for the Mac version? Thx.
whoopcrap
Re: Star Wars 4Ks
#28 Post by whoopcrap » Tue Mar 31, 2020 6:41 pm
tcoble33 wrote: Tue Mar 31, 2020 6:36 pm
Thats strange, mine kept failing for 3. Is there something I can try to see if were getting different sets of keys maybe?
logic
Re: Star Wars 4Ks
#29 Post by logic » Tue Mar 31, 2020 7:59 pm
I'm seeing the same issue with disc 1; I've submitted an AACS dump for it.
For future reference, if you look at the makemkv log down in the bottom of the window, you should see a line like "Saved AACS dump file as /home/esm/.MakeMKV/MKB20_v72_Star_Wars-_The_Phantom_Menace_3BF4.tgz". You'll want to email svq at makemkv.com with the file attached.
tcoble33
Re: Star Wars 4Ks
#30 Post by tcoble33 » Tue Mar 31, 2020 8:06 pm
logic wrote: Tue Mar 31, 2020 7:59 pm I'm seeing the same issue with disc 1; I've submitted an AACS dump for it.
Thanks for the feedback. If you get a good response to your dump file submission, please let us know what you learn. In the meantime, I'll work on capturing and submitting one as well.
