How much a subtitle or audio track take?
AMAGON
Post by AMAGON » Mon Mar 30, 2020 5:01 pm
Did a search prior, not much info I found on my end to say the least, but just wondering how much space generally a subtitle or audio track usually take up if anyone knows.
Re: How much a subtitle or audio track take?
Post by Woodstock » Mon Mar 30, 2020 5:35 pm
Varies greatly with the track. Subtitle tracks are usually very small, relative to video, but "lossless" audio tracks can be as much as 10% of the overall file.
AMAGON
Post by AMAGON » Mon Mar 30, 2020 5:54 pm
Noted, with regards with subtitle, are talking about 50mbs< worth?
Post by Woodstock » Mon Mar 30, 2020 7:24 pm
Much less, most of the time.
Just ran two tests, taking a file I just ripped.
Original, everything in it: 4,932,229KB
Remove both PGS subtitle tracks: 4,929,665KB
PGS included, lossless audio removed: 4,224,229KB
The test with audio removed the DTS-HD MA tracks, leaving just the DTS tracks. The file was episode 1 of an anime, about 25 minutes long.
AMAGON
Post by AMAGON » Tue Mar 31, 2020 12:43 am
Alright, cool to knows, thanks for checking this!
Chetwood
Post by Chetwood » Tue Mar 31, 2020 5:25 am
You can use TSMuxer to extract the sub from the m2ts or MKVCleaver to extract it from the MKV to see how large it is. It's usually pointless to skip it cause it's so small.
Ezatoka
Post by Ezatoka » Wed Apr 01, 2020 10:25 am
I've seen DTS-HD MA tracks taking as much as 1.5 to 2GB, per language on a BluRay
