LG BD570
jejecham
Re: LG BD570
#16 Post by jejecham » Fri Sep 10, 2010 10:55 am
I just add to my previous comment that my mkv were made from DVD not BR DVD, so only 2 ref frames might be enough. However, still no solution for my audio track change problem.
Bornung
Re: LG BD570
#17 Post by Bornung » Tue Sep 28, 2010 6:25 pm
I also have a LG BD 570 :roll:
It can play mkv's without any problems ( Video H264 and Audio ACC ) if you wanna have subtitles to the movie, you need to put them outside the matroska container.
I use handbrake for the video/audio encoding ( to create a mkv file )
Then i use subrip to rip and convert into a srt file.
So i end up with 2 files. Eks (Testing.mkv and Testing.srt).
It works perfekt :mrgreen:
Cheers to all developers for this great piece of software, keep up the good work. :D
Bob K
Re: LG BD570
#18 Post by Bob K » Sat Oct 30, 2010 6:03 am
What program do you recommend for reading a video file to see all of its settings? I have an MKV file that will play on WMP12 but will not stream through the WMP12 DLNA to the BD570. VLC says the Codec is H264-MPEG-4 AVC (part10) (avc1) and audio is DTS Audio (dts). Other MKVs in that format seem to stream just fine.
On a different note, I thought the whole purpose of a DLNA server like WMP12 was to have WMP12 do the transcoding and then deliver a signal that the BD570 could use. Any idea why I can view this file on WMP12 on my computer but not on the BD570?
skittle
Re: LG BD570
#19 Post by skittle » Sat Oct 30, 2010 7:10 am
Use 'mediainfo'
Please post the text output here.
Bob K
Re: LG BD570
#20 Post by Bob K » Sat Oct 30, 2010 7:45 am
Wow. Mediainfo is a great program! Here are the file details:
General
Complete name : F:\Movies on WD120\Movie1.mkv
Format : Matroska
File size : 7.95 GiB
Duration : 1h 42mn
Overall bit rate : 11.1 Mbps
Encoded date : UTC 2010-10-14 06:58:10
Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 42mn
Bit rate : 9 586 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.193
Stream size : 6.71 GiB (84%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-6 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9586 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Codec ID : A_DTS
Duration : 1h 42mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 1.08 GiB (14%)
skittle
Re: LG BD570
#21 Post by skittle » Sat Oct 30, 2010 8:33 am
This is a somewhat known issue with hardware players and a new default mkvmerge feature. To fix:
in Mkvmerge(gui)set the "Compression" option on the "Extra Options" tab for all tracks to "None". Do not leave blank, you have to set it to "None".
Bob K
Re: LG BD570
#22 Post by Bob K » Sat Oct 30, 2010 4:31 pm
Thank you. What setting in my text details indicates that problem so that I know what to look for next time?
Also, can I "fix" this file by running it through makemkv or RipBot264?
skittle
Re: LG BD570
#23 Post by skittle » Sat Oct 30, 2010 10:23 pm
Muxing mode : Header stripping"
No, you can only reprocess it with mkvmerge(gui) (note that ripbot and most other x264 gui's use mkvtoolnix too)
http://www.bunkus.org/videotools/mkvtoolnix/
Btw, im not sure what happens if you try to reprocess it after header compression/removal. You may need to remux from the source files with header intact.
ikalinin
Re: LG BD570
#24 Post by ikalinin » Tue Dec 14, 2010 2:37 pm
HEY HEY.. sorry to bring back this thread from the dead.. but I just got the BD570, and love it.. only problem is that on DATA CDs or DVD, you can only forward at one speed.. and it happens to be the slowest speed.. :( any way to fix this?? are there options?
