jcdr428
Post by jcdr428 »
shawnc22 wrote: Mon Mar 30, 2020 3:48 pm @jcdr, I can recompile tsmuxer and give prof 6 a try. will report back with results
Thanks @shawnc22 . Or you can try this W64 build bb51a5f from my fork. Single tracks created from Blu-rays should be profile 6.
    // cf. "http://www.dolby.com/us/en/technologies/dolby-vision/dolby-vision-profiles-levels.pdf"
    int profile;
    if (m_sps->bit_depth_luma_minus8 == 2)
        if (!isDVBL)  // dual HEVC track
            profile = 7;
        else if (m_hdr->isDVEL && (V3_flags & HDR10))
            profile = 6;
        else if (m_hdr->isDVEL)
            profile = 4;
        else if (m_sps->colour_primaries == 2 && m_sps->transfer_characteristics == 2 &&
                 m_sps->matrix_coeffs == 2)  // DV IPT color space
            profile = 5;
        else
            profile = 8;
    else  // 8-bit
            profile = 3;
        else
            profile = 2;
Angryunibrow
Post by Angryunibrow »
jcdr428 wrote: Mon Mar 30, 2020 4:22 pm
    int profile;
            profile = 7;
            profile = 6;
            profile = 4;
            profile = 5;
        else
            profile = 8;
    else  // 8-bit
            profile = 3;
        else
            profile = 2;
Curious if this will play on the shield, I think not because the devs said profile 4 MEL, 5,8 and 9 are only supported.
We support profile 4 MEL (minimum enhancement layer). Also single layer profiles 5,8.9.
DaMacFunkin
Post by DaMacFunkin »
Anybody??
A way to remove HDR10+ without removing Dolby Vision?
Cheers.
Angryunibrow
DaMacFunkin wrote: Mon Mar 30, 2020 4:40 pm Anybody??
Cheers.
No way that I am aware of
pargo
Post by pargo »
Angryunibrow wrote: Mon Mar 30, 2020 4:26 pm
    int profile;
            profile = 7;
            profile = 6;
            profile = 4;
            profile = 5;
        else
            profile = 8;
    else  // 8-bit
            profile = 3;
        else
            profile = 2;
Does that mean that profile 4 isn't the best choice for Shield because it doesn't have FEL? And we should use profile 5 if possible? Sorry if I'm misunderstanding, still trying to get this all figured out :D
MastaG
Post by MastaG »
Thank you guys for all the answers.. so I need to set mode 2 to get profile 5, got it :)
@shawnc22 No the internal player of my C8 does not support TrueHD/Atmos.
But I'm storing it for preservation reasons.
For playback I must select the AC3 core track or E-AC3 5.1.
What I meant to say is that.. before I was able to produce .ts files with -mode 1 hevc that would play fluent on my C8.
Even the 60fps Gemini Man was OK.
Just using the 0.0.3 tool to create a mode 1 hevc file from the BL/EL and then use TsMuxer to mux it into a transport stream.
See my success story: https://www.makemkv.com/forum/viewtopic ... 295#p86295
It would say:
Dolby Vision, Version 1.0, dvhe.08.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
The latest TsMuxer will say:
Dolby Vision, Version 1.0, dvhe.04.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
So it seems 04 will cause stutters every 1 or 2 seconds while 08 works fine?
Or it's caused by the difference between yusesope's 0.0.3 and 0.0.3_rev1 tool.
Post by shawnc22 »
Just tested the following using yusecope's tool v0.0.3 and tsmuxer build edited to force all profiles to 6 (sorry @jcdr, saw your build too late, but resulting file should be same in this scenario):
Joker sample file that's been used extensively here before with no audio track:
- Plays on B9 internal player, triggers DV
- Plays on 2019 Shield, triggers DV
Full Joker movie remuxed with Atmos audio:
- Plays on B9 internal player (no stutter), triggers DV, and no audio support message (as expected)
- Plays on 2019 Shield, triggers DV and Atmos audio
Here is the resulting mediainfo from the full movie remux:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 1 min
Bit rate                                 : 53.7 Mb/s
Bits/(Pixel*Frame)                       : 0.270
Stream size                              : 45.7 GiB (94%)
Maximum Content Light Level              : 992 cd/m2
Maximum Frame-Average Light Level        : 120 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 158 kb/s
Stream size                              : 558 MiB (1%)
Number of dynamic objects                : 15
Interesting findings as my previous remux of the full joker movie that was prof 4 did stutter on my B9, so seemingly the stutter issue on the LG internal player is related to DV profiling. Also interesting that the Shield is able to play these since it's been mentioned in that past that profile 6 is not supported. As far as my eyes can tell, there is no discerning difference between the profile 6 vs 4 DV remuxes. Not sure what the best step is moving forward, since profile 6 has pretty much been deprecated? I had to go back to a 2016 version of the dolby profiles pdf to even find a mention of it.
MastaG
Post by MastaG »
shawnc22 wrote: Mon Mar 30, 2020 5:13 pm Just tested the following using yusecope's tool v0.0.3 and tsmuxer build edited to force all profiles to 6 (sorry @jcdr, saw your build too late, but resulting file should be same in this scenario):
Video
Audio
Codec ID                                 : 131
yeah, so profile 4 stutters on LG :)
Now if profile 6 works on both the Shield (also playing the Atmos track) and LG.. then -mode 1 with profile 6 in TS should be the golden combination.
Post by shawnc22 »
MastaG wrote: Mon Mar 30, 2020 5:21 pm yeah, so profile 4 stutters on LG :)
I don't know if it's as simple as saying that prof 4 is no good on the LG. The same Joker sample file that I had previously made in prof 4 played back perfectly with no stutter, it was just the full movie that was stuttering. Plus this official LG sample here: https://4kmedia.org/lg-dolby-comparison-uhd-4k-demo/ is a profile 4 TS with a BL+EL+RPU single track, and that plays back just fine, too
jcdr428
Post by jcdr428 »
shawnc22 wrote: Mon Mar 30, 2020 5:34 pm I don't know if it's as simple as saying that prof 4 is no good on the LG. The same Joker sample file that I had previously made in prof 4 played back perfectly with no stutter, it was just the full movie that was stuttering. Plus this official LG sample here: https://4kmedia.org/lg-dolby-comparison-uhd-4k-demo/ is a profile 4 TS with a BL+EL+RPU single track, and that plays back just fine, too
@shawnc22 thanks for the confirmation on profile 6 working. The patch is pending merge in the official tsMuxer.
Mediainfo must match the following:
Profile 4: BL+EL+RPU, SDR compatible
Profile 5: BL+RPU, (Unspecified colorspace)
Profile 6: BL+EL+RPU, HDR10 compatible
Profile 7: track 1 HDR10 or HDR10+ compatible, track 2 HDR10 compatible
Profile 8: BL+RPU, HDR10 or HLG or SDR compatible
jcdr428
Post by jcdr428 »
shawnc22 wrote: Mon Mar 30, 2020 5:13 pm Interesting findings as my previous remux of the full joker movie that was prof 4 did stutter on my B9, so seemingly the stutter issue on the LG internal player is related to DV profiling. Also interesting that the Shield is able to play these since it's been mentioned in that past that profile 6 is not supported. As far as my eyes can tell, there is no discerning difference between the profile 6 vs 4 DV remuxes. Not sure what the best step is moving forward, since profile 6 has pretty much been deprecated? I had to go back to a 2016 version of the dolby profiles pdf to even find a mention of it.
- Profile 4: BL+EL+RPU, SDR or (Unspecified colorspace)
- Profile 5: BL+RPU, (Unspecified colorspace)
- Profile 6: BL+EL+RPU, HDR10/+ compatible
- Profile 7: track 1 HDR10/+ compatible, track 2 HDR10 compatible
- Profile 8: BL+RPU, HDR10/+ or HLG or SDR compatible
Edit: Dolby are cutting all compatibility with other HDR formats, so indeed they don't advertise compatibility with former profile 6. And profile 8 is already in "Annex I: Profiles not supported for new applications" in the latest DolbyVisionProfilesLevels_v1_3_2_2019_09_16.pdf
mulucy
Post by mulucy »
jcdr428 wrote: Mon Mar 30, 2020 7:42 pm
I am sure others have reported this, but using the "yusecope tool 0.0.3 rev01 -mode 2" with the Tsmuxer 11f852a version produces profile 08.06 in TS container. I was expecting to get a Profile 5.
edit:
It has nothing to do with the Yusecope tool or revision ( experimented a little more ). It's the Tsmuxer, it defaults to profile 4 with a dual-layer and profile 8 with a single layer. Is there a way to choose the profile level before remuxing it? BTW, when playing the profile 4 Black Panther on my Apple 4K ( it only supports the profile 5 AFAIK ), it plays the file as HDR10. I thought the Profile 4 only had backward compatibility with SDR only.
badrobot
Post by badrobot »
If we have to choose BL+RPU format to rip UHD Blyray disks, I think Profile 5 is a better choice, because apple tv 4k only supports Profile 5, the DVDFab also produces Profile 5 when user chooses BL+RPU.
If we choose Profile 8, maybe only shield tv 2019 support this Profile?
I am not a native English speaker.
Sorry for my bad English.
Angryunibrow
jcdr428 wrote: Mon Mar 30, 2020 7:35 pm
Can also confirm the 2019 shield and LG C8 plays the Profile 6 files just fine. I did not watch an entire movie but testing 2 movies worked just fine.
Edit: 1917 studders on the LG C8 but plays fine on the shield. (profile 6)
Now if we can just get Nvidia to fix the color issues on the shield playing back Dolby Vision we might get somewhere :)
Post by shawnc22 »
Angryunibrow wrote: Tue Mar 31, 2020 2:03 am
Ah I guess we did speak too soon. I just tried 1917 as well and it is indeed still stuttering on the LG internal player (fine on the Shield still). For what it's worth, the stuttering when compared to the DV prof 4 video does not seem as severe?
