Maxoumax6
#1891 Post by Maxoumax6 » Sun Mar 29, 2020 9:11 pm
yusesope wrote:
Tue Mar 24, 2020 12:17 pm
It would be interesting to see how another software would handle the matter.
I am therefore trying to modify at bit level the .ts files produced by FFmpeg.
I did some experiments using THIS file and HERE you can find the results.
If your device plays the original file, test the files I edited.
If there is a positive response (I have my doubts but there is no harm in trying!), I will explain what and how I did it.
Thank you.
Hey everyone,
I've been following the topic for a long time now. You guys are doing such a great job. I'm amazed by that, it's so cool!! :D
I get through the process and only obtained stuttering .mp4 :roll: on my C8.
But, the mp4.ts you did, works smoothly on my C8. You are a magician Yusesope :lol: but the only question is : how did you do this? :twisted:
Thanks again guys.
jcdr428
#1892 Post by jcdr428 » Sun Mar 29, 2020 9:31 pm
Angryunibrow wrote:
Sun Mar 29, 2020 3:59 pm
Thank you for the link, and maybe I miss spoke but I thought there were 2 versions of tsmuxer and the GitHub "version" was the one we needed over the version that says"PayPal" in the corner.
Are they the same now?
The version that says "PayPal" in the corner is 2.6.12 / proprietary. The versions on github are opensource, under active development with UHD/HDR/DV.
Angryunibrow wrote:
Sun Mar 29, 2020 6:08 pm
It appears, unless i'm doing something wrong the LG Plex app can't play back a Dolby Vision .ts file created.
I made a Profile 7 just using the 640kb core audio so I know it would direct play but the TV does not trigger Dolby Vision, just HDR
Only thing I noticed was tsmuxer makes it Profile 7.05, while mp4muxer makes it 7.06
Not sure if that is the reason, or its just the the TV needs an .mp4 file instead of .ts - but the file did play just only in HDR
Maybe the TV does not read HDMV descriptors, as opposed to the BD players. As stated previously, I had pushed the standard HEVC video descriptors for DV, but was asked to come back to HDMV descriptors due to PGS, ac3+thd and ac3+eac3 BD tracks not working anymore.
I understand that the Shield reads only DV marked as profile 5. However Blu-ray profile 7 dual tracks changed to single tracks should be profile 8 and not profile 5, as the BL is BT.2100 and not Dolby IPT colorspace. The Shield SoC seems to be able to read any DV as long as it is marked profile 5, so this is something that should be addressed by NVidia in a firmware rather than allowing to disseminate non-compliant DV files.
pargo
#1893 Post by pargo » Sun Mar 29, 2020 9:47 pm
planet_hoarder wrote:
Wed Mar 18, 2020 8:40 am
Arbigator wrote:
Wed Mar 18, 2020 6:53 am
What is it about a demuxed mkv rip that this tool doesn't like? Do you think it might be possible in the future?
Also would be my question, since Dolby's mp4muxer works perfectly (well at least mp4muxer_64bit.exe works) with extracted bl, el tracks from mkv-files. Watched couple of DV movies on LG Oled that way.
Edit I found the 64bit version of mp4muxer and my TV still doesn't active DV when I play the output file.
I have Shield 2019, using tsmuxer-11f852a to demux Annihilation remux MKV, and repackage the BL and EL with the AC3 layer using mp4muxer 64 bit. But the Shield through plex always shows HDR. Any ideas what I'm missing? Would really appreciate it.
#1894 Post by shawnc22 » Sun Mar 29, 2020 10:14 pm
I think the Shield is good with reading single track+dual layer dv profile 4, and single track+single layer profile 5 and 8 videos. Dual track+dual layer profile 7 videos have always been the problem, hence yusecope's tool to merge the tracks but keep the layers still separate (or the -mode 2 option to also merge the layers). The issue somebody was having was with an Apple TV 4k not reading a ST+SL file in prof 8, but when the same video track is remuxed in 5, it'd work perfectly. Probably an issue with the Apple TV not supporting prof 8
Angryunibrow
#1895 Post by Angryunibrow » Sun Mar 29, 2020 10:58 pm
Do you know what the last version was before the change that you think might work, I'm looking for an easier way to do profile 7. mp4muxer takes to long
mulucy
#1896 Post by mulucy » Mon Mar 30, 2020 1:19 am
Apple TV 4K only supports Profile 5. Apparently, the all-new Shield TV supports Profile 4 and 5. And with Profile 4, you get both: single track dual layer and single track single layer and all with lossless audio and ATMOS/DTS-X.
Grencola
#1897 Post by Grencola » Mon Mar 30, 2020 2:37 am
Just gotta lower the Red and Green sliders in your TV's color settings and you're all set :wink:
jcdr428
#1898 Post by jcdr428 » Mon Mar 30, 2020 6:22 am
To clarify the profiles:
Profile 4 is SDR BL with DV IPT EL -therefore backward compatible with SDR, not HDR10.
Profile 5 is DV IPT colorspace BL, not backward compatible with SDR or HDR10, i.e. will not give correct colors on a non-DV TV.
Profile 7 is dual track HDR10 BL with DV IPT colorspace EL, backward compatible with HDR10.
Profile 8 is SDR or HDR BL with DV metadata, backward compatible with SDR or HDR.
Levels are only about bitrate and HEVC profile.
MastaG
#1899 Post by MastaG » Mon Mar 30, 2020 10:27 am
Just gave the 1917 movie a shot.
First using yusesope's v0.0.3 rev 1 tool:
python src/bl_el_rpu_builder_v0.0.3_rev_1.py -bl ./BL.hevc -el ./EL.hevc -of 1917.hevc
BL_ANALYSIS: 100.0%  EL_ANALYSIS: 100.0%  BL_EL_RPU WRITING: 100.0%  (BL AUDs: 171176  EL AUDs: 171176)
ELAPSED TIME: 09m 08s
Press a button to exit
And afterwards I remuxed the 1917.hevc along with the TrueHD+ac3 core track from the bluray disc into a .ts file with the latest TsMuxer (built from source).
For the record, I didn't use mp4muxer in the process...
Here's the output file:
mediainfo 1917.ts
General
Complete name                            : 1917.ts
File size                                : 70.3 GiB
Overall bit rate                         : 84.6 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 79.9 Mb/s
Bits/(Pixel*Frame)                       : 0.402
Stream size                              : 66.4 GiB (95%)
Maximum Frame-Average Light Level        : 168 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 158 kb/s
Stream size                              : 381 MiB (1%)
As you can see it reports: 04.06.
Shouldn't it report profile 05 instead?
Because your PR has been merged: https://github.com/justdan96/tsMuxer/pull/264 and I built the latest rev, which should include your fix.
badrobot
#1900 Post by badrobot » Mon Mar 30, 2020 11:38 am
mediainfo 1917.ts
General
Video
Audio
Codec ID                                 : 131
When you use yusesope's v0.0.3 rev 1 tool, you MUST add a parameter -mode 2,then you will get a DoVi Profile 5 hevc video, without this parameter, the default mode produces a DoVi Profile 4 hevc video.
I am not a native English speaker.
Sorry for my bad English.
MastaG
#1901 Post by MastaG » Mon Mar 30, 2020 1:44 pm
mediainfo 1917.ts
General
Video
Audio
Codec ID                                 : 131
Well now both 1917 and Gemini Man will stutter every one or two seconds..
This is on my LG C8 btw.
So either the change from yusecope's 0.0.3 to 0.0.3 rev1 caused this. (Was using mode 1 for both versions)
Or the updated tsmuxer could be the cause.
Since the previous revision was showing profile 8..
Either one of two is upsetting my TV.
1000010
#1902 Post by 1000010 » Mon Mar 30, 2020 1:58 pm
could you explain what you did? I'm really interested in figuring out why some movies don't work on the Shield.
Mortenjorstad
#1903 Post by Mortenjorstad » Mon Mar 30, 2020 2:12 pm
mediainfo 1917.ts
General
Video
Audio
Codec ID                                 : 131
You have to edit the the youscope tool
open up the .bat file in notepad and add -mode 2 to the end of the single line of text in there and save it.
python-3.7.6.amd64\python src\bl_el_rpu_builder_v0.0.3.py -mode 2
If you do that you will have a dolby vision 05.06 file
jcdr428
#1904 Post by jcdr428 » Mon Mar 30, 2020 2:18 pm
So your have hacked the Blu-ray dual tracks to move the second track to an EL layer in the first track. The resulting single track is BL+EL (which should be profile 4) with HDR10 (which should be profile 8 ), but is definitely not profile 5 (which is DV IPT without EL). You should ask Dolby to create a new profile :)
Edit: I don't really know how I should classify the profiles for your hacked files, but I've pushed the following to tsMuxer:
    // cf. "DolbyVisionProfilesLevels_v1_3_2_2019_09_16.pdf"
    int profile = 0;
    if (!isDVBL)  // dual HEVC track
        profile = 7;
    else if (m_hdr->isDVEL)
        profile = 4;
    else if (m_sps->colour_primaries == 2 && m_sps->transfer_characteristics == 2 &&
             m_sps->matrix_coeffs == 2)  // DV IPT color space
        profile = 5;
    else
        profile = 8;
Edit 2: according to https://forum.blu-ray.com/showpost.php? ... tcount=645 , a single track BL+EL with HDR10 is actually profile 6 ! However the latest DV document DolbyVisionProfilesLevels_v1_3_2_2019_09_16.pdf states "These profiles are not supported for new applications" (profiles 0, 1, 2, 3 and 6).
pargo
#1905 Post by pargo » Mon Mar 30, 2020 2:30 pm
Edit I found the 64bit version of mp4muxer and my TV still doesn't activate DV when I play the output file, only HDR.
I have Shield 2019, using nightly tsmuxer to demux Annihilation bluray remux MKV, and repackage the BL and EL with the AC3 layer using mp4muxer 64 bit. But the Shield playing via plex always shows HDR. Any ideas what I'm missing? Would really appreciate it.
Bumping this because my edit got buried - any ideas why mp4muxer isn't working for me?
I've now tried with Annihilation and Aquaman remuxes. Could it be because I'm starting with the remuxed MKV? But I know other people on this forum have said they were able to rip BL/EL from a remux MKV with no problems (as long as they were using mp4muxer and not yuseopoe tool).
Thanks everyone for your work on this project. I've read through pretty much everything and its been extremely helpful.
