Hi, the video nitrate reports as 0kb because the Oppo can’t decode the video stream, it can’t even determine the length of the movie, the exact same file plays fine on shield2019 pro, and in HDR10 on shield 2017.yusesope wrote: Sat Mar 28, 2020 6:16 pmI'm sorry but at the moment I don't have any other ideas.DaMacFunkin wrote: Sat Mar 28, 2020 7:35 am Hi, can confirm this mux of 1917 that didn’t work on the Oppo works in Dolby Vision and Atmos on 2019 shield pro, shame I will have to have 2 muxes of some FEL movies till it’s sorted, particularly because the Oppo is a better picture, the Colours are more balanced.
Is there any other way to try and mux so we get a file that works on both?
Regards.
The strange thing is that the video bit rate of 1917 is 0kbps.
If the cobination of my tool + tsMuxeR worked for Mission Impossible, it may also work for other FEL titles.
You should make some attempts.
I thank those who have tried the files that I modified (by patching the output of FFmpeg ) but at the moment the whole process consumes too much time (so it is useless).
I can’t find the words to put this technically but I wonder if on some FEL movies one layer needs to be first... and by this I refer back to MVC where you had right eye mux and left eye mux, do you know what I mean?
