WH14NS40
Re: WH14NS40
TheLoonyRebel wrote: Sun Mar 29, 2020 8:38 pm I have this HS14NS40 can I use LibreDrive firmware with this one?
OS device name: H:
Product: BD-RE WH14NS40
Revision: 1.03
Serial number: K98F2EB1648
Firmware date: 2114-03-26 11:05
Highest AACS version: 65
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 1.03
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
No it's to old sorry if you flash it,it will be bricked
aloha
Re: WH14NS40
Post by aloha »
Hello:
@SamuriHL, Not trying to be combative, but...
SamuriHL wrote: Sun Mar 15, 2020 12:54 pm 1.00 vs 1.02mk... if you're on a version of a firmware that requires an mk version in order to downgrade, then 1.02mk is going to be recommended. If you're on a version of a firmware that allows straight downgrading or cross flashing, 1.00 is going to be recommended. It's really that simple.
… is really not that simple. Case in point. I just received a LG WH16NS40 - NS:50 with factory firmware of 1.04, build date of 12/2019 and when I tried to use DE -1.00 firmware, but it would not flash. Then I tried flashing to 1.02MK, yet it still would not flash. Previous models (WH16NS40 - NS:50, 12/2019, FW:1.04) purchased with the same date code, same NS code, AND same factory firmware of 1.04 flashed without incident. This time however, "BH14NS40_N1.00-A4_patched.exe" kept giving an error code (also tried via sdftool, it also gave error code) and would not flash, didn't write it down but Googled it at the time, and the result lead me back to the MakeMKV forum. The forum suggested to 1st flash to "HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin" - a 1.04MK firmware ( I'm guessing from a different family model 1.04MK vs 1.02MK AND NS55 vs NS50) completely and from there I could re-flash to my desired end flash (in my case "DE_LG_WH16NS60_1.00.bin"). No where did the post ever suggest to initially flash using 1.02MK FWIR.
Lesson I learned... Thank goodness for the gurus of the Libre board section! Read what the gurus have posted and follow what they have to say! Totally saved my butt!!! AND, sometimes 1.02MK is NOT the way to get to DE - 1.00 firmware.
Simple... no, not really IMHO!
Regards,
A
Re: WH14NS40
aloha wrote: Sun Mar 29, 2020 10:41 pm
Regards,
A
Every desktop drive I have ever gotten with 1.04, WH16NS60 1.02mk has always worked
aloha
Re: WH14NS40
Post by aloha »
Hello:
Billycar11 wrote: Sun Mar 29, 2020 10:46 pm
Regards,
A
That was the weird part. Same was true for me, until this last drive. Not going to lie, it was a "pucker" moment as I thought LG changed something within the factory 1.04 firmware (for the WH16NS40 - NS:50) to make it more difficult to re-flash. I had to jump through some hoops to be able to cross flash it (as explained above) to a WH16NS60 - 1.00, but I eventually got it thanks to the help of this forum.
If I could not get it, I was definitely going to contact you and utilize your services (always nice to know there is a safety net)!
Regards,
A
jonghotti
Re: WH14NS40
Post by jonghotti »
No it cannot.
I am happy to sell you one that can. My info in my signature below.
jonghotti
Re: WH14NS40
Post by jonghotti »
Never mind I’m a bit late on that reply lol.
TheLoonyRebel
Re: WH14NS40
Post by TheLoonyRebel »
Billycar11 wrote: Sun Mar 29, 2020 9:11 pmNo it's to old sorry if you flash it,it will be bricked
I had a feeling but it's better to ask. Thanks for confirming. Time to hunt down a new drive that can support UHD discs perhaps?
aloha
Re: WH14NS40
Post by aloha »
Hello:
jonghotti wrote: Mon Mar 30, 2020 12:10 am No it cannot.
It cannot what? Please explain.
jonghotti
Re: WH14NS40
Post by jonghotti »
aloha wrote: Mon Mar 30, 2020 1:04 am Hello:
I should have quoted what I was replying to and that was the gentleman's question about flashing a drive with the 1939 chip on it.
Librewhat
Re: WH14NS40
Post by Librewhat »
Just joined, be kind, until 2 days ago I didn't know what a Libredrive was. Anyway, I think I have the same set up as the first person posting and would like to make mine a Libredrive too. Is mine also compatible, looks like only the firmware is different.
Revision: 1.03
Serial number: M65J21B3303
Firmware date: 2117-11-21 16:58
Highest AACS version: 72
I found and downloaded the MK firmware zip file but I am not able to find any instructions on how to flash. Would someone be willing to help point me in the right direction?
Also, reading the posts left me unsure what firmware to flash, the 1.04MK or 1.0? Then finally I see where someone said to back up your old firmware and reading through that I got lost. How important is this step? If important, is there any instructions for tech challenged?
Re: WH14NS40
Librewhat wrote: Mon Jun 01, 2020 10:16 pm Just joined, be kind, until 2 days ago I didn't know what a Libredrive was. Anyway, I think I have the same set up as the first person posting and would like to make mine a Libredrive too. Is mine also compatible, looks like only the firmware is different.
Revision: 1.03
Yeah flash to WH16NS60 1.02mk
molebdynum
Re: WH14NS40
Post by molebdynum »
Hi guys. I just joined the Forum. I have an older WH14NS40. Is it too old to use? Here's the drive info:
Current profile: CD-R
Revision: 1.00
Serial number: K83C7GB5458
Firmware date: 2112-06-16 18:28
Firmware version: 1.00
BD raw metadata read: Partial
Is says the status is enabled? What to do next?
Re: WH14NS40
Nothing more to do, really. Your drive is too old to do UHD, but you have the other benefits of LibreDrive.
molebdynum
Re: WH14NS40
Woodstock wrote: Tue Aug 11, 2020 1:17 pm Nothing more to do, really. Your drive is too old to do UHD, but you have the other benefits of LibreDrive.
Thank-you Woodstock.
coastman49
Re: WH14NS40
Post by coastman49 »
I flashed my LG WH14NS40 successfully, but now get no disc inserted wwhen I insert any kind of disc. What did I do wrong?
OS device name: K:
Revision: 1.02
Serial number: SIK98E59F351
Firmware date: 2115-12-11 15:03
Firmware version: 1.02
