Back up greyed out
Anametureenthisiast
Back up greyed out
#1 Post by Anametureenthisiast » Sat Mar 28, 2020 4:10 pm
Hi
I am trying to back up some of my bluray movie disks and a few makemkv doesn't give me the option to back up which is strange. Are there unknown limits to making decrypted backups?
a few of the discs are LOTR FOTR special features and appendices.
xr200
Re: Back up greyed out
#2 Post by xr200 » Sat Mar 28, 2020 5:33 pm
Double check that you didn't try to back up a DVD (instead of a Blu-Ray Disc).
#3 Post by Woodstock » Sat Mar 28, 2020 6:04 pm
Many commercial BD sets come with DVD versions of the extras.
Anametureenthisiast
#4 Post by Anametureenthisiast » Sat Mar 28, 2020 6:50 pm
Hi
Thanks for the help, its definitely bluray the disk size is over 30gb, and this set is specifically a bluray set (google the middle earth saga)
when I open the disk it says in the log something like- multiple (something) to scan will take a while. would this have an effect?
any ideas would be great
Grauhaar
#5 Post by Grauhaar » Sat Mar 28, 2020 7:08 pm
Anametureenthisiast wrote: Sat Mar 28, 2020 6:50 pm when I open the disk
The backup option is only available if the disc is not "open"!!
Good Luck :)
#6 Post by Woodstock » Sat Mar 28, 2020 10:39 pm
If that message was like this, that's a DVD, because BDs do not have VOBUs.
Complex multiplex encountered - 1 cells and 1803 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
A quote from an Amazon review:
To be clear, this review is for the Lord of the Rings trilogy bluray 15-disc extended edition box set. The movies themselves are blu-ray, but the extra features are DVD discs, by design, which is ok.
Anametureenthisiast
#7 Post by Anametureenthisiast » Sun Mar 29, 2020 12:41 pm
Woodstock wrote: Sat Mar 28, 2020 10:39 pm If that message was like this, that's a DVD, because BDs do not have VOBUs.
Thanks for this, so I looked at the disc and your right, the extras with the hobbit trilogy are Bluray (hence makemkv had no issues) but the extras for LOTR are dvd format.
Is there an easy way to back up the files of a dvd disk like I was doing for the bluray disks with the hobbit?
Thanks for the help
#8 Post by Woodstock » Sun Mar 29, 2020 2:27 pm
If your reason for using backup is to preserve menus and such, the "best" way to do a DVD is to save an ISO of it, preferably with the encryption removed. Players can then treat it just like you'd inserted the DVD itself. I've used a program called "BDLot" in the past, which hasn't been updated in a decade or so, but it's still available from several sites for download.
That, of course, is a bit wasteful of space, because there's at least 20% overhead in that, versus creating MKV files, AND you can post-process the MKV files with tools like handbrake to reduce their space requirements.
Some people don't worry about space, but... I have 70TB available, and I just had to do some clean-up to get back down to 35TB in use, so I still worry about space.
