DaMacFunkin wrote: ↑Thu Mar 26, 2020 7:21 pmHere are the Mission Impossible Fallout picsyusesope wrote: ↑Tue Mar 24, 2020 12:17 pmThanks for trying.DaMacFunkin wrote: ↑Sun Mar 22, 2020 9:17 pmHi, Following the guide can't get FEL to work on the oppp, the file does work in HDR10 on the 2017 shield, can't check on the 2019 shield as it is at my weekend address (won't be there again till Friday)…
If you have time, could you please try what follows with a MEL movie?Hi Yusesope, here are the shots from the Oppo, 1917 that won’t play and reports as 8bit output, which makes sense and Missin Impissibke Fallout which plays fine, both are supposed to be FEL.yusesope wrote: ↑Sun Mar 22, 2020 10:45 amSince you own an OPPO 203, could you do me this favour: while playing a movie (my tool + tsMuxer, please try both a FEL and an MEL movie), can you press the "info" button and take a screenshot (both for the Multimedia information section and for the HDMI output information section)?
It is important, however, that in the player settings, Color Space and Color depth (Video Output Setup) are set to AUTO.
Help yourself with this video (19:24):
https://youtu.be/Pqg8Ky6T7vc?t=1164
Thank you
DaMacFunkin
- 699D3365-24A1-42DF-8FD6-28F06588EBE0.jpeg (2.96 MiB) Viewed 24846 times
- D493221A-41F0-4E2E-A9B7-5DC2AB70FF14.jpeg (2.48 MiB) Viewed 24846 times
- 8CC14F00-3083-4BF4-BD63-59822F2F0D01.jpeg (2.94 MiB) Viewed 24846 times
1917 worked great after ripping the BL, EL with TSMuxer, and using Profile 5 with MP4Muxer. It was, hands down, the best visual experience I've had in terms of Dolby Vision. Everyone that has DV needs to see it.
DaMacFunkin
I agree, I calibrated my LG c9 last weekend and I wasn’t too sure about the Dolby Vision profile that Calman autocal created, till I watched 1917... brilliantly graded.
DaMacFunkin
DaMacFunkin wrote: ↑Thu Mar 26, 2020 7:21 pmHi, can confirm this mux of 1917 that didn’t work on the Oppo works in Dolby Vision and Atmos on 2019 shield pro, shame I will have to have 2 muxes of some FEL movies till it’s sorted, particularly because the Oppo is a better picture, the Colours are more balanced.yusesope wrote: ↑Tue Mar 24, 2020 12:17 pmThanks for trying.DaMacFunkin wrote: ↑Sun Mar 22, 2020 9:17 pmHi, Following the guide can't get FEL to work on the oppp, the file does work in HDR10 on the 2017 shield, can't check on the 2019 shield as it is at my weekend address (won't be there again till Friday)…
Thank you
Is there any other way to try and mux so we get a file that works on both?
Regards.
Hi! Can anyone explain the correct steps for the Nvidia Shield 2019?
Many thanks!
Many thanks!
Yep, that scene with the blue morning sky…beautiful.DaMacFunkin wrote: ↑Sat Mar 28, 2020 7:10 amI agree, I calibrated my LG c9 last weekend and I wasn’t too sure about the Dolby Vision profile that Calman autocal created, till I watched 1917... brilliantly graded.
I prefer to leave the profile selection as automatic.shawnc22 wrote: ↑Thu Mar 26, 2020 7:02 pmunfortunately I don't understand the subject enough to know what really goes into differentiating between a profile 5 and 8 video. This is definitely not a permanent solution, but maybe @jcdr can consider implementing a user defined dv-profile parameter in a future version of tsmuxer similar to mp4muxer?
I understood that profile 8 is when there is backward compatibility with non-DV players (eg HDR10, SDR...), which is the case with the Blu-ray base layer. However the Blu-ray DVs muxed to single track DV are not fully compliant with profile 8 because of the chroma sample location, which might explain why the player chokes on these. I will push a fix to tsMuxer to change to profile 5.
Edit: Pull request pending merge.
what are the steps to play this on my lg C9?
Much appreciated for the hard work @jcdr428!
@DaMacFunkin, if you have the Oppo, can’t you just play things straight from a decrypted folder backup/iso? That’ll give you DV and Atmos without having to bother with any remuxing, no?
Angryunibrow
Would someone be so kind to link the complete file so I can do some testingjcdr428 wrote: ↑Sat Mar 28, 2020 1:14 pmI prefer to leave the profile selection as automatic.shawnc22 wrote: ↑Thu Mar 26, 2020 7:02 pmunfortunately I don't understand the subject enough to know what really goes into differentiating between a profile 5 and 8 video. This is definitely not a permanent solution, but maybe @jcdr can consider implementing a user defined dv-profile parameter in a future version of tsmuxer similar to mp4muxer?
DaMacFunkin
Yes, that works fine, but not on Shield, I’m after a solution that works on both so I don’t need 2 rips of the same disk.
Ah got it. Just out of curiosity for the titles that's worked with both methods, have you noticed any difference in DV picture quality when playing the folder backup vs the ts remux(on shield & oppo)?DaMacFunkin wrote: ↑Sat Mar 28, 2020 5:12 pmYes, that works fine, but not on Shield, I’m after a solution that works on both so I don’t need 2 rips of the same disk.
I'm sorry but at the moment I don't have any other ideas.DaMacFunkin wrote: ↑Sat Mar 28, 2020 7:35 amHi, can confirm this mux of 1917 that didn’t work on the Oppo works in Dolby Vision and Atmos on 2019 shield pro, shame I will have to have 2 muxes of some FEL movies till it’s sorted, particularly because the Oppo is a better picture, the Colours are more balanced.
Regards.
The strange thing is that the video bit rate of 1917 is 0kbps.
If the cobination of my tool + tsMuxeR worked for Mission Impossible, it may also work for other FEL titles.
You should make some attempts.
I thank those who have tried the files that I modified (by patching the output of FFmpeg ) but at the moment the whole process consumes too much time (so it is useless).
Angryunibrow
Could someone post the new tsmuxer modified for profile 5, I have no idea how to use github and download anything
@yusesopeyusesope wrote: ↑Sat Mar 28, 2020 6:16 pmI'm sorry but at the moment I don't have any other ideas.DaMacFunkin wrote: ↑Sat Mar 28, 2020 7:35 amHi, can confirm this mux of 1917 that didn’t work on the Oppo works in Dolby Vision and Atmos on 2019 shield pro, shame I will have to have 2 muxes of some FEL movies till it’s sorted, particularly because the Oppo is a better picture, the Colours are more balanced.
Regards.
I did 1917.m2ts DV using your tool and tsmuxer.
It plays perfectly in Shield 2019 and this is the mediainfo:
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate : 82.6 Mb/s
