DaMacFunkin
Post by DaMacFunkin »
DaMacFunkin wrote:
Thu Mar 26, 2020 7:21 pm
yusesope wrote:
Tue Mar 24, 2020 12:17 pm
DaMacFunkin wrote:
Sun Mar 22, 2020 9:17 pm
Hi, Following the guide can't get FEL to work on the oppp, the file does work in HDR10 on the 2017 shield, can't check on the 2019 shield as it is at my weekend address (won't be there again till Friday)…
Thanks for trying.
If you have time, could you please try what follows with a MEL movie?
yusesope wrote:
Sun Mar 22, 2020 10:45 am
Since you own an OPPO 203, could you do me this favour: while playing a movie (my tool + tsMuxer, please try both a FEL and an MEL movie), can you press the "info" button and take a screenshot (both for the Multimedia information section and for the HDMI output information section)?
It is important, however, that in the player settings, Color Space and Color depth (Video Output Setup) are set to AUTO.
Help yourself with this video (19:24):
https://youtu.be/Pqg8Ky6T7vc?t=1164
Thank you
Hi Yusesope, here are the shots from the Oppo, 1917 that won’t play and reports as 8bit output, which makes sense and Missin Impissibke Fallout which plays fine, both are supposed to be FEL.
Here are the Mission Impossible Fallout pics
tr000
Post by tr000 »
1917 worked great after ripping the BL, EL with TSMuxer, and using Profile 5 with MP4Muxer. It was, hands down, the best visual experience I've had in terms of Dolby Vision. Everyone that has DV needs to see it.
DaMacFunkin
tr000 wrote:
Sat Mar 28, 2020 1:16 am
I agree, I calibrated my LG c9 last weekend and I wasn’t too sure about the Dolby Vision profile that Calman autocal created, till I watched 1917... brilliantly graded.
DaMacFunkin
Thanks for trying.
Thank you
Hi, can confirm this mux of 1917 that didn’t work on the Oppo works in Dolby Vision and Atmos on 2019 shield pro, shame I will have to have 2 muxes of some FEL movies till it’s sorted, particularly because the Oppo is a better picture, the Colours are more balanced.
Is there any other way to try and mux so we get a file that works on both?
Regards.
NiCE77
Post by NiCE77 »
Hi! Can anyone explain the correct steps for the Nvidia Shield 2019?
Many thanks!
tr000
Post by tr000 »
DaMacFunkin wrote:
Sat Mar 28, 2020 7:10 am
Yep, that scene with the blue morning sky…beautiful.
jcdr428
Post by jcdr428 »
shawnc22 wrote:
Thu Mar 26, 2020 7:02 pm
unfortunately I don't understand the subject enough to know what really goes into differentiating between a profile 5 and 8 video. This is definitely not a permanent solution, but maybe @jcdr can consider implementing a user defined dv-profile parameter in a future version of tsmuxer similar to mp4muxer?
I prefer to leave the profile selection as automatic.
I understood that profile 8 is when there is backward compatibility with non-DV players (eg HDR10, SDR...), which is the case with the Blu-ray base layer. However the Blu-ray DVs muxed to single track DV are not fully compliant with profile 8 because of the chroma sample location, which might explain why the player chokes on these. I will push a fix to tsMuxer to change to profile 5.
Edit: Pull request pending merge.
kazuma
Post by kazuma »
what are the steps to play this on my lg C9?
Post by shawnc22 »
Much appreciated for the hard work @jcdr428!
@DaMacFunkin, if you have the Oppo, can’t you just play things straight from a decrypted folder backup/iso? That’ll give you DV and Atmos without having to bother with any remuxing, no?
Angryunibrow
Post by Angryunibrow »
jcdr428 wrote:
Sat Mar 28, 2020 1:14 pm
Would someone be so kind to link the complete file so I can do some testing
DaMacFunkin
shawnc22 wrote:
Sat Mar 28, 2020 3:29 pm
Yes, that works fine, but not on Shield, I’m after a solution that works on both so I don’t need 2 rips of the same disk.
Post by shawnc22 »
DaMacFunkin wrote:
Sat Mar 28, 2020 5:12 pm
Ah got it. Just out of curiosity for the titles that's worked with both methods, have you noticed any difference in DV picture quality when playing the folder backup vs the ts remux(on shield & oppo)?
yusesope
Post by yusesope »
DaMacFunkin wrote:
Sat Mar 28, 2020 7:35 am
Regards.
I'm sorry but at the moment I don't have any other ideas.
The strange thing is that the video bit rate of 1917 is 0kbps.
If the cobination of my tool + tsMuxeR worked for Mission Impossible, it may also work for other FEL titles.
You should make some attempts.
I thank those who have tried the files that I modified (by patching the output of FFmpeg ) but at the moment the whole process consumes too much time (so it is useless).
Angryunibrow
Could someone post the new tsmuxer modified for profile 5, I have no idea how to use github and download anything
ragico
Post by ragico »
yusesope wrote:
Sat Mar 28, 2020 6:16 pm
Regards.
@yusesope
I did 1917.m2ts DV using your tool and tsmuxer.
It plays perfectly in Shield 2019 and this is the mediainfo:
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate : 82.6 Mb/s
