The latest version 1.6.2 (Win) still seems to fail with my disc that contains LPCM audio. It immediately stops after I press the convert-button and says "copy complete. 0 titles saved, 1 failed". The log doesn't say anything that looks usefull either:
"Saving 1 titles into directory D:/Video/UNNAMED_DISC
Failed to save title 0 to file D:/Video/UNNAMED_DISC/title00.mkv
						Converting DVD titles with LPCM 2/0 fails
				setarip_old
Re: Converting DVD titles with LPCM 2/0 fails
Hi!
1) What is the title and Region number of your original, commercial DVD?
2) Please submit a complete Debug Log
It's a recording from my dvd-recorder, but reauthored with DVDShrink. Here's the log:
Debug log started at Tue Oct 26 16:57:38 2010 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Morgan/MakeMKV_log.txt
003006:0000 Opening files on harddrive at D:/DIFF/VIDEO_TS/
003028:0000 Title #0 was added (1 cell(s), 0:25:19)
005014:0000 Saving 1 titles into directory D:/Video/UNNAMED_DISC
001003:0020 DEBUG: Code 4294967295 at IRA_H;]'tP~\ViBpg-3:29393999
001003:0020 DEBUG: Code 0 at 4[XX/VGo,o,itCCBLt{E:29394321
001003:0020 DEBUG: Code 278 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 0 to file D:/Video/UNNAMED_DISC/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Oct 26 16:58:09 2010
- Contact:
Can you please re-author to leave only few seconds of video, confirm that error still happens with MakeMKV and then send all files, both IFO and VOB to support@makemkv.com ?
Im getting exactly the same problem with "Ray Mears Bushcraft Series 1 Disc 1 DVD". I ripped the dvd using dvd decrypter (My collection was ripped long before makemkv appeared, so im just using it to stip tv shows into individual episodes). The dvd rip files play fine through VLC. The original DVD is All regions. In case its usefull the disc uses LPCM 2/0 audio. If i untick the audio track from this title it then rips OK.
Debug logging enabled, log will be saved as C:\Users\G/MakeMKV_log.txt
Opening files on harddrive at E:/ISO/TV/Ray Mears/Ray Mears Bushcraft Series 1, Disc 1/
Calculated BUP offset does not match one in IFO header.
Title #0 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1 was added (1 cell(s), 0:59:03)
Title #2 was added (2 cell(s), 0:59:06)
Title #3 was added (1 cell(s), 0:58:33)
Title #4 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/G/Desktop/TV MKV
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at 4[XX/VGo,o,itCCBLt{E:29394183
DEBUG: Code 1368978 at 4[XX/VGo,o,itCCBLt{E:29393309
Failed to save title 1 to file C:/Users/G/Desktop/TV MKV/title01.mkv
Really hoping u might have some suggestions. As i mentioned in my last post the dvd rips play fine and can be imported into other software fine (dvd remake pro) but when using makemkv it fails unless i untick the audio track (LPCM 2/0)
Please any help!!!
						Please any help!!!
