Disk backup
Unibrowser
Disk backup
#1 Post by Unibrowser » Tue Mar 24, 2020 6:23 pm
I sent a dump file for 1917 UHD. While I wait, i did my first "encrypted disk backup". Once the key is available to decrypt it, how do I make a MKV from this backup folder?
This is the way
Re: Disk backup
#2 Post by SamuriHL » Tue Mar 24, 2020 7:31 pm
Just do a file, open, and select your folder backup. From there you can create the MKV.
Unibrowser
Re: Disk backup
#3 Post by Unibrowser » Tue Mar 24, 2020 8:45 pm
Thanks I figured it out finally. You have to select the bmvd index or whatever it was called :D
This is the way
