makemkv fails on v16 discs
michal.soukromy
Post by michal.soukromy » Sat Oct 23, 2010 7:57 am
I paid you 50 EUR yesterday, tried makemkv on two discs and it didn't work.
In detail:
discs tried:
- 2012 (czech)
- Prince of Persia (czech)
- I have Ubuntu 10.04, aacskeys 0.4.0c, registered makemkv - all programs seem to be installed correctly
- makemkv ends with:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002440 to device 'SG:dev_11:0'
Backup failed
- When I try aacskeys directly, it writes:
ERROR: PROCESSMKB, errnr: -3
It seems that both discs use v16 coding, but in ProcessingDeviceKeysSimple.txt I have keys only up to v10.
How to solve it?
michal.soukromy
Re: makemkv fails on v16 discs
Post by michal.soukromy » Sat Oct 23, 2010 8:14 am
Minor update:
- I downloaded that dsall.svq that you recommended in Fox thread (didn't help)
- I noticed that Prince of Persia is v18 (and 2012 is v16)
crowfax
Post by crowfax » Sat Oct 23, 2010 6:02 pm
Post by mike admin » Mon Oct 25, 2010 6:29 am
Are you sure that you recompiled the oss part from 1.6.2 ? Can you by any chance boot windows on this machine and see if windows version works?
Jagaer
Post by Jagaer » Wed Oct 27, 2010 3:01 am
The following is performed on the same system, Gentoo Linux x86_64 native - Linux version 2.6.34-gentoo-r6 (gcc version 4.3.4 (Gentoo 4.3.4 p1.1, pie-10.1.5) )
Windows XP x32 in VMWare
C:\Program Files\MakeMKV>makemkvcon backup disc:0 U:\Blu-Ray\Working\Splice\ --decrypt
MakeMKV v1.6.2 win(x86-release) started
Backing up disc into folder "U:\Blu-Ray\Working\Splice\"
Linux x86_64, after running make clean, make, make install on both OSS and BIN
makemkvcon backup disc:0 /home/movies/Blu-Ray/Working/Splice/ --decrypt
MakeMKV v1.6.2 linux(x64-release) started
Backing up disc into folder "/home/movies/Blu-Ray/Working/Splice BD50/"
Evaluation version, 29 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E56E523853D4428F4EEAEF3E707AFE4AA3 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07FED6D62000274ABF0D2EAF7BFC6E95BED to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B93C9022B19E280C5B35846F7C927BB5DF to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0842D74953424981C90577CDFDED710E071 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07CD76B1933A80CA97A757672AEA9136453 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..035BF33854B00C9A88DF89DF156850A323A to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0992F42AA4E31BC4559BEE404952807F9C0 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08EC0A7F8E1EB09739210BCA782C6ADB70C to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07BBB5099040FDE06550324890F29595127 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02ECE20B8D99C424EACBBF41F1B68041112 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DDB2B3E4B496CCB53643E117BFB7454A76 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05D7BBCF512CB5D828900B0D9A51CD74786 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09554E5EF24A3DC67E06216F07B968F4DBE to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09947AEC57914FC313F1166EA2740A27240 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07EA681D8955EFA3AA0DFE9C835BA57E763 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02E67F1DA3B155AD8540F936CADC8373A39 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08CC664115E95F0E663A63FD3F45E77BD16 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C49860F060C137E7C0DABE64554646C6C5 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..097628119BA946F92309395CAEF2867CAD6 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B85DEF9FDDE2A493CCF31499FA9C04A43B to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01F56F2A070C4179BDBFC22134429EBCCF7 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06DFB4700391385FB838F0BC2731356287C to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04C594DA8EBC40993DEDF87F016CA024D12 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..062349892F513F600BCE5B7911C95029A15 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CF774D03C526F2277976BDDF9816BA3244 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C7C3FB6605CE33856A4C4222667F0DAAC8 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CF41CE223945D3BBB6B675DBA842EA5EF5 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02A373487BB506F68AA4979050C916C5A6A to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09D6E90854EF91A65A7E1AC646CBAACC902 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0556C5509AC6990404D3E6C58265C6B6B1D to device 'SG:dev_11:0'
Backup failed
Backup failed
Post by mike admin » Fri Oct 29, 2010 9:01 am
Did you check oss version? If you launch GUI, what is displayed in about box? Looks like you still have oss code compiled from 1.6.0
Jagaer
Post by Jagaer » Sun Oct 31, 2010 8:44 pm
rachel
Post by rachel » Thu Nov 11, 2010 10:37 am
I just had this on a v15 disc (Last Chance to See disc 2 - disc 1 had been fine). makemkv 1.6.2 on linux (ubuntu maverick) 64-bit.
I rebooted, all the while thinking, there's no good reason to expect this to work, but it did. Disc is now ripping. :-)
if there is a good reason, it's probably that the drive got a proper reset command?
setarip_old
Post by setarip_old » Thu Nov 11, 2010 3:16 pm
@rachel
Over the years, I've learned that regardless of the reason, more often than not, a simple reboot "cures what ails" a system that's been up and running for a while ;>}
michal.soukromy
Post by michal.soukromy » Sat Nov 13, 2010 6:08 pm
I had to return those 2 original discs the next day, so I cannot retry it.
But for your question: I have 1.6.2 paid version.
But I bought another disc - The Dark Knight (czech version) and it behaves the same (doesn't rip). It writes:
MakeMKV v1.6.2 linux(x86-release) started
Backing up disc into folder "/x/video-new/BluRay/backup/THE DARK KNIGHT"
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..04B3F2BEF1CC6553CCF9C6270609BF0BBF4 to device 'SG:dev_11:0'
... lots of pages...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..088AECE4DE970D92EFEF1D3BDAD8133A427 to device 'SG:dev_11:0'
Backup failed
I'll try to mail you the details.
setarip_old
Post by setarip_old » Sat Nov 13, 2010 8:02 pm
@michal.soukromy
Hi!
For future reference, please be advised that discussions at the MakeMKV forum are limited to only discs that you own - and not regarding discs you "had to return"...
michal.soukromy
Post by michal.soukromy » Mon Nov 15, 2010 9:51 pm
Ok, I'll try to respect that.
But for your information - I believe it's absolutelly legal in Europe to borrow a disc, play it using makemkv and then return it.
setarip_old
Post by setarip_old » Sun Nov 28, 2010 6:21 am
@michal.soukromy
The rules of the MakeMKV Forum (and many other similar forums) are not limited only to the laws of various countries.
Thank you.
