Opening multiple instances of MakeMKV on Win10
glonch
Post by glonch »
I have 8 optical drives in my system and MakeMKV does an awesome job ripping DVDs and BDs from them.
Is there a way to run a batch file (or similar) to have Windows 10 open 8 MakeMKV GUI instances, each assigned to a unique drive?
Vincont
Re: Opening multiple instances of MakeMKV on Win10
Post by Vincont »
I have not tried to see if this works for multiple drives but you can open multiple instances of the software by going to your MKV shortcut and adding -launch in the "Target" section of the shortcut properties.
Should look something like:
"C:\Program Files (x86)\MakeMKV\makemkv.exe" -launch
glonch
Post by glonch »
Thanks - I tried added the -launch and there was no difference on how the app responded.
glonch wrote:
Tue Mar 24, 2020 12:30 am
view>preferences>IO>check single drive mode
glonch
Post by glonch »
Thanks - I have already had that checked and has been working as designed.
I just want to have a batch file (or the like) to open 8 distinct instances of MakeMKV and have each instance assigned to a unique drive.
Would be a nice feature to have it done automatically vs manually opening 8 instances and assigning drives to each.
I did a quick scan of the executable, and there doesn't seem to be a command line switch to select which drive to associate an instance to.
glonch
Post by glonch »
Thanks for the heads up!
Vincont
Post by Vincont »
Did you use the shortcut to open a second instance of the app?
sgjumper82
Post by sgjumper82 »
This is exactly what i am looking for. Is there a way this can be added on the next software revision?
Considering that you've tagged onto a 4+ year old topic and it still isn't implemented, I don't really think it's coming.
Once you turn on "ask for single drive mode" in the Properties->IO box, you can turn single-drive mode on whenever you want, and assign a drive to the current instance when you start it. Once it's on, you'll be asked any time there is the POSSIBILITY of assigning individual drives, like when you plug in a USB drive that you don't normally use.
