Yes i will connect it to tv aswell, but from where do u play the files? usb harddrive?Alldu wrote: Sun Mar 22, 2020 6:14 pmNot sure about the network, I connect my X700 straight to the TV. Also, mkv does not support DV, only HDR.box4m wrote: Sun Mar 22, 2020 6:07 pmis it possible to play m2ts, mkv, ts etc through network share on x700?Alldu wrote: Sun Mar 22, 2020 4:41 pm
Well, it's pretty simple. You just add your m2ts file into the tsMuxer, choose the BL and EL and the audio of your choosing. If you have sup subtitles - throw it in as well. Or if you have an alternate audio track, not found on the disc - you can add that too. Then just mux it into m2ts. That's it. Play it via Sony x700 and enjoy.
box4m
1000010
I took The Fog for my test case, because it has a pretty significant FEL (11 Mb/s). A short 50s clip made with mp4muxer worked without problems and triggered DV. Full movie muxed with tsMuxer with added Atmos track did not work, since the exoplayer reported it cannot play it and reverted to transcoding. This is not great, will try again by muxing only the video tracks with mp4muxer.yusesope wrote: Sun Mar 22, 2020 2:21 pm If it can help you (when you check the client logs), the Shield's hardware decoder isCode: Select all
OMX.Nvidia.DOVI.decode
I have attached the log files. I can attach the working server log file if you're interested in it as well, but I guess it doesn't matter.
- client_working_clip.txt
- (32.64 KiB) Downloaded 1404 times
- server_broken_movie.txt
- (87.88 KiB) Downloaded 1156 times
- client_broken_movie.txt
- (56.54 KiB) Downloaded 1266 times
Alldu
Yup, external hard drive via USB port.box4m wrote: Sun Mar 22, 2020 6:30 pmYes i will connect it to tv aswell, but from where do u play the files? usb harddrive?
I don't have the Fog personally, but I have tried a couple FEL movies, Black Panther(~3MB/s) and First Man(~6MB/s), and they both triggered DV/Atmos on the Shield with yusecope's v3 tool and tsmuxer. Whether or not the video data in the FEL is being fully utilized I guess is another question. Your videos reverting to transcoding, I suspect, may be a separate issue, unless the size of the FEL in the Fog is really the problematic source here.1000010 wrote: Sun Mar 22, 2020 6:32 pmI took The Fog for my test case, because it has a pretty significant FEL (11 Mb/s). A short 50s clip made with mp4muxer worked without problems and triggered DV. Full movie muxed with tsMuxer with added Atmos track did not work, since the exoplayer reported it cannot play it and reverted to transcoding. This is not great, will try again by muxing only the video tracks with mp4muxer.yusesope wrote: Sun Mar 22, 2020 2:21 pm If it can help you (when you check the client logs), the Shield's hardware decoder isCode: Select all
1000010
As I said, a short clip of the same movie worked. So either the tsmuxer is doing it wrong or exoplayer has a bug I suppose, since I have no idea why a clip of the whole movie would work. This is what I am trying to establish now.shawnc22 wrote: Sun Mar 22, 2020 6:43 pmI don't have the Fog personally, but I have tried a couple FEL movies, Black Panther(~3MB/s) and First Man(~6MB/s), and they both triggered DV/Atmos on the Shield with yusecope's v3 tool and tsmuxer. Whether or not the video data in the FEL is being fully utilized I guess is another question. Your videos reverting to transcoding, I suspect, may be a separate issue, unless the size of the FEL in the Fog is really the problematic source here.1000010 wrote: Sun Mar 22, 2020 6:32 pmI took The Fog for my test case, because it has a pretty significant FEL (11 Mb/s). A short 50s clip made with mp4muxer worked without problems and triggered DV. Full movie muxed with tsMuxer with added Atmos track did not work, since the exoplayer reported it cannot play it and reverted to transcoding. This is not great, will try again by muxing only the video tracks with mp4muxer.yusesope wrote: Sun Mar 22, 2020 2:21 pm If it can help you (when you check the client logs), the Shield's hardware decoder isCode: Select all
edit: forgot to mention but yusesope's tool did not return any errors
box4m
Using MXPlayer on the shield i havent got any method to work, ive tried several in this thread (all using yusesope tool), is it supposed to work? If so please teach me, i feel like theres 10 different TSMuxer mentioned and some mentioning mp4muxer instead (which is the correct version btw? i believe there are several different programs when u google mp4muxer)
Well with your short clip, you're not mixing in any atmos audio since you're using mp4muxer. When a video reverts to transcode on plex, it either can't handle the video or audio track. Since you've already established that a file without atmos works, then it's probably the atmos track that's causing the issue. How're you mixing in the atmos track with tsmuxer, and what does the resulting mediainfo look like?1000010 wrote: Sun Mar 22, 2020 6:47 pm As I said, a short clip of the same movie worked. So either the tsmuxer is doing it wrong or exoplayer has a bug I suppose, since I have no idea why a clip of the whole movie would work. This is what I am trying to establish now.
1000010
I'm muxing it with tsmuxer as I always do, it worked so far for all atmos tracks I tried. but simply put, I take the generated hevc file and original m2ts file as inputs, but select only the atmos track in m2ts input. Finishes without errors.shawnc22 wrote: Sun Mar 22, 2020 6:56 pmWell with your short clip, you're not mixing in any atmos audio since you're using mp4muxer. When a video reverts to transcode on plex, it either can't handle the video or audio track. Since you've already established that a file without atmos works, then it's probably the atmos track that's causing the issue. How're you mixing in the atmos track with tsmuxer, and what does the resulting mediainfo look like?1000010 wrote: Sun Mar 22, 2020 6:47 pm As I said, a short clip of the same movie worked. So either the tsmuxer is doing it wrong or exoplayer has a bug I suppose, since I have no idea why a clip of the whole movie would work. This is what I am trying to establish now.
Full movie made with mp4muxer and no audio works, but it crashed the first time I played it. mediainfo for full movie with DTS-HD MA track that's not working (thought it was Atmos initially):
Format : MPEG-TS
File size : 50.3 GiB
Duration : 1 h 29 min
Overall bit rate mode : Variable
Overall bit rate : 80.1 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 24.000 FPS
Color space : YUV
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Audio
Menu ID : 1 (0x1)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Muxing mode : Stream extension
Codec ID : 134
Bit rate mode : Variable
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Delay relative to video : 3 s 0 ms
yusesope
From the client_broken_movie.txt file:1000010 wrote: Sun Mar 22, 2020 7:09 pmI'm muxing it with tsmuxer as I always do, it worked so far for all atmos tracks I tried. but simply put, I take the generated hevc file and original m2ts file as inputs, but select only the atmos track in m2ts input. Finishes without errors.shawnc22 wrote: Sun Mar 22, 2020 6:56 pmWell with your short clip, you're not mixing in any atmos audio since you're using mp4muxer. When a video reverts to transcode on plex, it either can't handle the video or audio track. Since you've already established that a file without atmos works, then it's probably the atmos track that's causing the issue. How're you mixing in the atmos track with tsmuxer, and what does the resulting mediainfo look like?1000010 wrote: Sun Mar 22, 2020 6:47 pm As I said, a short clip of the same movie worked. So either the tsmuxer is doing it wrong or exoplayer has a bug I suppose, since I have no idea why a clip of the whole movie would work. This is what I am trying to establish now.
- the problem is the audio track.
[VideoUtils] MediaCodec found (OMX.Nvidia.DOVI.decode) for video/dolby-vision [ExoPlayer][EventLogger] decoderEnabled [0.88, 0.00, window=0, video] [ExoPlayer][EventLogger] decoderEnabled [0.89, 0.00, window=0, audio] [ExoPlayer][EventLogger] tracksChanged [0.89, 0.00, window=0, [ExoPlayer][EventLogger] Renderer:1 [ [ExoPlayer][EventLogger] Group:0, adaptive_supported=N/A [ [ExoPlayer][EventLogger] [X] Track:0, id=0, mimeType=video/dolby-vision, codecs=dvhe.04.06, res=3840x2160, fps=24.0, supported=YES [ExoPlayer][EventLogger] ] [ExoPlayer][EventLogger] Metadata [ [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 117 bytes) [ExoPlayer][EventLogger] scantype_progressive: (Value: 1 Buffer: 0 bytes) [ExoPlayer][EventLogger] ] [ExoPlayer][EventLogger] ] [ExoPlayer][EventLogger] Renderer:3 [ [ExoPlayer][EventLogger] Group:0, adaptive_supported=N/A [ [ExoPlayer][EventLogger] [X] Track:0, id=1, mimeType=audio/vnd.dts, bitrate=0, codecs=dts, channels=0, sample_rate=0, supported=YES [ExoPlayer][EventLogger] ] [ExoPlayer][EventLogger] Metadata [ [ExoPlayer][EventLogger] block_align: (Value: 0 Buffer: 0 bytes) [ExoPlayer][EventLogger] channel_layout: (Value: 0 Buffer: 0 bytes) [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 0 bytes) [ExoPlayer][EventLogger] ] [ExoPlayer][EventLogger] ] [ExoPlayer][EventLogger] ] [Player][ExoPlayer] Setting initial track selection... [Player][ExoPlayer] Switching video surface to use MediaCodec surface. [Player] onSurfaceChangeRequested [ExoPlayer][EventLogger] surfaceSizeChanged [1.02, 0.00, window=0, 0, 0] [ExoPlayer][EventLogger] timelineChanged [1.02, 0.00, window=0, periodCount=1, windowCount=1, reason=DYNAMIC [ExoPlayer][EventLogger] period [5406.46] [ExoPlayer][EventLogger] window [5406.46, true, false] [ExoPlayer][EventLogger] ] [Player][ExoPlayer] onTimelineChanged (Position: 0 ms) [ExoPlayer][EventLogger] decoderInitialized [1.02, 0.00, window=0, video, OMX.Nvidia.DOVI.decode] [ExoPlayer][EventLogger] decoderInputFormatChanged [1.02, 0.00, window=0, video, id=0, mimeType=video/dolby-vision, codecs=dvhe.04.06, res=3840x2160, fps=24.0] [ExoPlayer][EventLogger] decoderInitialized [1.02, 0.00, window=0, audio, OMX.google.raw.decoder] [ExoPlayer][EventLogger] decoderInputFormatChanged [1.02, 0.00, window=0, audio, id=1, mimeType=audio/vnd.dts, bitrate=0, codecs=dts, channels=0, sample_rate=0] [DisplayBehaviour] Mode switching has been disabled, as Dolby Vision is playing.Code: Select all
[ExoPlayer][EventLogger] playerFailed [1.14, 3.00, window=0] An exception occurred: com.google.android.exoplayer2.r: com.google.android.exoplayer2.s0.q$a: Unsupported channel count: 0 Stacktrace: com.google.android.exoplayer2.r: com.google.android.exoplayer2.s0.q$a: Unsupported channel count: 0
The good news is that the Dolby Vision decoder is being successfully initialized.
At this point I assume that the FEL stream is correctly decoded.
The DTS-MA track could definitely be the issue. One last thing you might want to try is create a TS file with TSMuxer with only the video tracks. If that works, then it's probably the DTS track causing the issue.
edit: oops yusecope beat me to it!
1000010
I figured that, muxing it now with LPCM. Weird though, mediainfo looks good. And also the original file with the same audio track works fine.yusesope wrote: Sun Mar 22, 2020 7:16 pmFrom the client_broken_movie.txt file:1000010 wrote: Sun Mar 22, 2020 7:09 pmI'm muxing it with tsmuxer as I always do, it worked so far for all atmos tracks I tried. but simply put, I take the generated hevc file and original m2ts file as inputs, but select only the atmos track in m2ts input. Finishes without errors.shawnc22 wrote: Sun Mar 22, 2020 6:56 pm
the problem is the audio track.Code: Select all
yusesope
From the client_working_clip.txt file:
Are you sure you have set the --dv-profile switch with the value 4 in mp4muxer?
The Shield received a track with profile dvhe.05.
Track:0, id=0, mimeType=video/dolby-vision, bitrate=65110539, codecs=dvhe.05.06, res=3840x2160, fps=24.0, supported=YESThe Shield received a track with profile dvhe.05.
Have you also tried using makemkv to just make a HDR10/DTS-MA mkv file to see how that plays? The only disk I have with DTS-MA is planet earth 2 (no DV unfortunately), and the mkvs I've made out of those play just fine in DTS on plex. The mediainfo for the audio tracks looks just like yours also:
If the mkv you make works, then TSMuxer may be doing something funky with the audio track, or it may be a combination of a DV track and DTS audio in the same container that Plex doesn't like.
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Codec ID : A_DTS
Duration : 53 min 4 s
Bit rate : 2 301 kb/s
Bit depth : 16 bits
Stream size : 873 MiB (5%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
1000010
I used profile 5 and it still triggered DV. Tried now with 4 and got the same result.yusesope wrote: Sun Mar 22, 2020 7:28 pm From the client_working_clip.txt file:Are you sure you have set the --dv-profile switch with the value 4 in mp4muxer?Code: Select all
variant
A .ts file of the Shining triggered DV and the DTS track worked just fine on the shield’s internal player.
