#1756 Post by shawnc22 » Sat Mar 21, 2020 7:02 pm
yusesope wrote:
Sat Mar 21, 2020 6:36 pm
PS:
It's just me, or Dolby has blocked access to the official documentation with a nice login.
Does that mean we guessed it right? :mrgreen:
I noticed that too, but I was thinking it might've been some patent troll who took over the site. I did find a mirror here:
http://docplayer.net/44473907-Dolby-vis ... evels.html
Could be an older version of the doc though
agentreza
#1757 Post by agentreza » Sat Mar 21, 2020 10:54 pm
So with this current method, do we no longer have the same issues we were having with dvdfab's conversion?
I was able make rhe new fantastic beasts work on the shield but have no idea if this is "correct"? Thanks for the hard work peepz :)
variant
#1758 Post by variant » Sun Mar 22, 2020 12:00 am
As an alternative to plex on shield:
I Made a .ts file following instructions here. I was able to play the file on the shield’s built in video player and it triggered DV on my Vizio TV. It appeared to also bitstream audio to my receiver. I didn’t test it with an Atmos track because the movie I used didn’t have one. I just opened the file in x-plore from usb and selected “video player.” I was able to fast forward and pause in short increments with no issues but if you skip ahead really far in the movie it doesn’t resume correctly.
Anyone have an Atmos file they can test to see if the internal player passes Atmos? I assume the player matches your output settings in the general shield audio settings.
DaMacFunkin
#1759 Post by DaMacFunkin » Sun Mar 22, 2020 9:21 am
variant wrote:
Sat Mar 21, 2020 5:21 pm
1000010 wrote:
Sat Mar 21, 2020 1:53 pm
does this conversion with yusesope script work if EL is FEL? I'm guessing if it does the Shield won't play it properly according to the diagram posted previously, so the conversion wouldn't make sense, because it won't improve HDR at all. is this correct?
also, how do you differentiate between MEL or FEL in a bluray?
This link to a blu-ray.com forum post lists whether many discs are FEL or MEL.
https://forum.blu-ray.com/showthread.php?t=276448
Hi, is it possible to create file with fel and Atmos that will play on shield, even if that is only 10bit?
And will that file then play on Oppo 203?
Willing to try if someone has some pointers, I’ve already created mel and Atmos that play fine on Shield 2019 and Oppo 👍🏼
yusesope
#1760 Post by yusesope » Sun Mar 22, 2020 10:45 am
Hi, I assume you used my tool + tsMuxer. Am I wrong?
As for movies with a FEL Layer, @ragico, a few posts ago, reported a success with the movie of Black Panther (FEL - 3.41 Mb/s).
You should try and then report your experience here on the forum.
The procedure is identical to that used for a movie with a MEL Layer.
Use my tool (v0.0.3) and THIS version of tsMuxer posted by @ragico (replace "tsMuxer.exe" with the one you will download)
Since you own an OPPO 203, could you do me this favour: while playing a movie (my tool + tsMuxer, please try both a FEL and an MEL movie), can you press the "info" button and take a screenshot (both for the Multimedia information section and for the HDMI output information section)?
It is important, however, that in the player settings, Color Space and Color depth (Video Output Setup) are set to AUTO.
Help yourself with this video (19:24):
https://youtu.be/Pqg8Ky6T7vc?t=1164
Thank you
1000010
#1761 Post by 1000010 » Sun Mar 22, 2020 11:22 am
just tried your method with with MEL and FEL on Shield and it works like magic. Hats off to you sir. I can even do it on linux.
It makes me a bit confused though, I thought Shield does not support decoding of FEL, which means it should skip DV pipeline according to the diagram from one of your previous posts. Any idea what might be happening there? Is there any way I can check? going to take a look client logs later, I already deleted all my test files.
mulucy
#1762 Post by mulucy » Sun Mar 22, 2020 11:46 am
This is exactly what I have been wondering about lately. I would appreciate it if you could update your post later to see what's happening with the FEL. Thanks in advance!
yusesope
#1763 Post by yusesope » Sun Mar 22, 2020 2:21 pm
I think what I wrote: according to the official documents if the hardware is not able to handle a FEL stream (by instantiating a secondary HEVC decoder), it should fall back on HDR10/SDR.
The hardware of the new Shield is very performing, it is not unlikely that it is also able to manage FEL streams.
The confirmation can only come from you: my tool has been downloaded hundreds of times but few people have posted their feedback.
If it can help you (when you check the client logs), the Shield's hardware decoder is
OMX.Nvidia.DOVI.decode
If @DaMacFunkin answers my previous question, it would also be interesting if he could compare the output video quality of the OPPO with that of the new Shield
#1764 Post by shawnc22 » Sun Mar 22, 2020 2:35 pm
Some further good reads on FEL vs MEL:
https://forum.blu-ray.com/showpost.php? ... stcount=94
https://forum.blu-ray.com/showpost.php? ... tcount=119
Just taking a wild guess here, but if it’s true that the shield is only capable of supporting prof 4 MEL as mentioned by a user here: viewtopic.php?f=12&t=18602&p=86086#p86086, then maybe the shield is treating the FEL like an MEL during playback (i.e. discarding the extra video information and only reading the dynamic metadata). As yusecope mentioned, some comparisons between playback of FEL movies on the oppo (and x700?) vs shield would definitely help clear things up.
yusesope
#1765 Post by yusesope » Sun Mar 22, 2020 2:47 pm
It is a behavior not reported in the official documentation
always remembering that the Shield adds "an extra touch of red" as we have seen by comparing a Netflix movie reproduced on the Shield and on the Sony X700 (HERE)!
deadchip12
#1766 Post by deadchip12 » Sun Mar 22, 2020 3:31 pm
Mortenjorstad wrote:
Sat Mar 21, 2020 1:34 pm
You need
Eac3to 3.34
Tsmuxer
Yusesope tool v.0.0.3
First you have to make bl.hevc and el.hevc
Eac3to path to folder with DV movie 2:bl.hevc 3:el.hevc
Know you have made 2 files bl.hevc and el.hevc
Start yusesope tool and drop first bl.hevc and then el.hevc
This will make a new hevc fIle
Start tsmuxerGui
Add the file you made With yusesope tool
Add Blu-ray movie and just select the soundtrack
Mux the files together in Ts.
You will know have a movie that is DV with Atmos that will play on shield 2019
I followed the exact same steps but the final file only has 1 video stream (hdr10).
Alldu
#1767 Post by Alldu » Sun Mar 22, 2020 3:42 pm
RESET_9999 wrote:
Thu Mar 19, 2020 10:24 pm
Alldu wrote:
Thu Mar 19, 2020 9:44 pm
Hy guys, anybody know what's the best way to embed sub/idx or ass subtitles into the DV mp4? I play my DV files via X700 and for some reason it can't read ass subs properly and sub/idx at all, if I put them in the same folder as DV mp4. Thanks!
You don't have to use the MP4 container anymore with the x700. You can remux your UHD bluray disc directly to .TS or .M2TS using this tsMuxer:
https://drive.google.com/file/d/1IWYPO4 ... sp=sharing
DV, Atmos and subs will work.
Wow, thanks so much! Everything seems to be working like a charm - and so much easier than everything else! God bless ya, laddy :D
kazuma
#1768 Post by kazuma » Sun Mar 22, 2020 4:06 pm
how is this process going? what are the steps? i've downloaded the edited tsmuxer in the link. i have a DV m2ts file of matrix.
Alldu
#1769 Post by Alldu » Sun Mar 22, 2020 4:41 pm
Well, it's pretty simple. You just add your m2ts file into the tsMuxer, choose the BL and EL and the audio of your choosing. If you have sup subtitles - throw it in as well. Or if you have an alternate audio track, not found on the disc - you can add that too. Then just mux it into m2ts. That's it. Play it via Sony x700 and enjoy.
kazuma
#1770 Post by kazuma » Sun Mar 22, 2020 4:45 pm
sorry, what is BL and EL?
