mulucy
#1741 Post by mulucy » Fri Mar 20, 2020 11:25 pm
Angryunibrow wrote: Fri Mar 20, 2020 11:10 pm
mulucy wrote: Fri Mar 20, 2020 10:54 pm
ragico wrote: Fri Mar 20, 2020 9:55 pm @yusesope
Just made a .m2ts DV of Black Panther using your tool v.003 and the latest fork of tsmuxer posted on tsmuxer forum by @a5180007 that corrects the DV profile as per your observations. Mediainfo: HDR format Dolby Vision version 1.0, dvhe 04.06, BL+EL+RPU /SMPTE ST2086, HDR10 compatible
This plays perfectly in Shield TV 2019 on plex. It triggers Dolby Vision and Dolby Atmos.
Will try other movies tomorrow.
Thanks again for your great knowledge and efforts.
Does it mean the Shield Pro support the EL layer on top of the BL, all it discards the extended layer? I am really confused about the profile 04.06 and BL+EL+RPU part of it. I thought the new Shield TV Pro only supported profile 5, which means up to 10-bit input. But with EL it makes it up to 12-bit input signal.
2019 Shield supports Profile 4 MEL, 5 & 8
Out of curiosity, is Profile 4 with MEL produces a better picture than Profile 5 with BL only?
ragico
#1742 Post by ragico » Fri Mar 20, 2020 11:34 pm
Link to test build of tsmuxer, I don't have a github account.
https://mega.nz/#!9m4FDJjT!1276qfyWM_tU ... 5SqsVORvSg
Angryunibrow
#1743 Post by Angryunibrow » Fri Mar 20, 2020 11:36 pm
mulucy wrote: Fri Mar 20, 2020 11:25 pm
I do not know the answer to that in all honestly.
Right now we have done some comparisons of DV on the shield compared to the x700 & Native LG apps and the shield right now has a color issue with over saturation.
I do believe the files we are producing are correct, and this is something Nvidia needs to address.
They did chime in on there forums with the concern and have seen the samples and will be investigating the issue and hopefully can release a firmware update to be on par with what other devices are outputting.
Angryunibrow
#1744 Post by Angryunibrow » Fri Mar 20, 2020 11:38 pm
ragico wrote: Fri Mar 20, 2020 11:34 pm
Thank you kindly!
mulucy
#1745 Post by mulucy » Fri Mar 20, 2020 11:50 pm
Angryunibrow wrote: Fri Mar 20, 2020 11:36 pm
Thank you!
#1746 Post by shawnc22 » Sat Mar 21, 2020 3:40 am
@ragico
don't have an account on the other forum, but saw the question about gemini man. It's 04.09 exactly because of the 60fps. 24fps = *.06, 30fps = *.07, 48fps = *.08, and 60fps = *.09.
Grencola
#1747 Post by Grencola » Sat Mar 21, 2020 4:19 am
hey so for all us firestick 4k peeps stuck using mx player with our dv movies, they just added SMB SUPPORT to their new beta. see here: https://www.apkmirror.com/apk/mx-media- ... 2-release/
I've only tried it on my phone so far but it works great! this is huge considering the firestick doesn't natively support usb hdd's and its internal storage is far too small for any full movie.
ragico
#1748 Post by ragico » Sat Mar 21, 2020 10:52 am
shawnc22 wrote: Sat Mar 21, 2020 3:40 am @ragico
Thanks for clarification.
Mortenjorstad
#1749 Post by Mortenjorstad » Sat Mar 21, 2020 1:34 pm
box4m wrote: Fri Mar 20, 2020 9:33 pm
Mortenjorstad wrote: Wed Mar 18, 2020 1:39 pm I have know made M2ts files with hd audio on all my 56 DV movies. Every movie play perfect on shield 2019 with DV and Atmos/dts x sound.
1 demux with eac3to Eac3to path to moviefolder 2:bl.hevc 3:el.hevc
2 tak the 2 files and import them into yuseope tool v02
3 use tsmuxer modified Version, mux file made by yuseope tool with audio from Blu-ray.
https://drive.google.com/uc?id=10zOr0IU ... t=download
care to explain the steps and commands u use for this?
would appriciate alot
You need
Eac3to 3.34
Tsmuxer
Yusesope tool v.0.0.3
First you have to make bl.hevc and el.hevc
Eac3to path to folder with DV movie 2:bl.hevc 3:el.hevc
Know you have made 2 files bl.hevc and el.hevc
Start yusesope tool and drop first bl.hevc and then el.hevc
This will make a new hevc fIle
Start tsmuxerGui
Add the file you made With yusesope tool
Add Blu-ray movie and just select the soundtrack
Mux the files together in Ts.
You will know have a movie that is DV with Atmos that will play on shield 2019
1000010
#1750 Post by 1000010 » Sat Mar 21, 2020 1:53 pm
does this conversion with yusesope script work if EL is FEL? I'm guessing if it does the Shield won't play it properly according to the diagram posted previously, so the conversion wouldn't make sense, because it won't improve HDR at all. is this correct?
also, how do you differentiate between MEL or FEL in a bluray?
#1751 Post by RESET_9999 » Sat Mar 21, 2020 2:04 pm
jcdr428 wrote: Fri Mar 20, 2020 7:30 pm Hi all, so I registered to the forum, as it will certainly be more efficient than members notifying of discussions from here on the tsMuxer forum (thanks @baker99). By the way I am far from being a 'real dev'...
Patch for tsMuxer profile 4 / single track double layer has been pushed here.
@yusesope, according to the DV profile & level document, profile 4 is normally limited to BL signal cross-compatibility ID 2 = SDR with VUI BL 0, 1, 1, 1, 0 EL 1, 2, 2, 2, 0. Your profile 4 single track files created from Blu-ray double tracks have VUI BL & EL 0, 9, 16, 9, 2. I don't have any DV hardware to test lecture of the files, should I keep BL signal cross-compatibility ID to 6, or change it to 2 ?
Hi, thank's a lot for the updated tsMuxer and welcome to the forum :)
baker99
#1752 Post by baker99 » Sat Mar 21, 2020 2:28 pm
Mortenjorstad wrote: Sat Mar 21, 2020 1:34 pm
You need
Eac3to 3.34
Tsmuxer
Start tsmuxerGui
Is there any advantage using eac3to over ffmpeg for extracting layers?
Mortenjorstad
#1753 Post by Mortenjorstad » Sat Mar 21, 2020 3:01 pm
baker99 wrote: Sat Mar 21, 2020 2:28 pm
You need
Eac3to 3.34
Tsmuxer
Start tsmuxerGui
No don´t think so, I have just used Eac3to never used ffmpeg
variant
#1754 Post by variant » Sat Mar 21, 2020 5:21 pm
1000010 wrote: Sat Mar 21, 2020 1:53 pm does this conversion with yusesope script work if EL is FEL? I'm guessing if it does the Shield won't play it properly according to the diagram posted previously, so the conversion wouldn't make sense, because it won't improve HDR at all. is this correct?
This link to a blu-ray.com forum post lists whether many discs are FEL or MEL.
https://forum.blu-ray.com/showthread.php?t=276448
yusesope
#1755 Post by yusesope » Sat Mar 21, 2020 6:36 pm
First of all thank you for your work.
As for your question, we were talking about it here on the forum the other day.
Here is what I wrote:
yusesope wrote: Fri Mar 20, 2020 10:58 am In the case of a profile 4, according to the guidelines, cross-compatibility should be set to SDR (DVCompatibility = 2). My files are reported as compatible with HDR10: tsMuxeR correctly manages the VUIs (0,9,16,9,2) while my file is slightly out of standard (as it is derived from a UHD-BD). But the behavior of the decoder is not dependent on these Dolby Vision defined crosscompatibility IDs, so we're safe!
Unfortunately, like you, I don't own a device that can play movies with DV tracks either.
For now we leave the cross-compatibility ID at 6.
If there is a need to set DVCompatibility = 2 in the future, I'll let you know!
PS:
It's just me, or Dolby has blocked access to the official documentation with a nice login.
Does that mean we guessed it right? :mrgreen:
