I'm having trouble flashing my drive; It's a BH16NS58 inside a BRXL-16U3.
MakeMKV reports:
Product: BD-RE BH16NS58
Revision: 1.02
Serial number: KLIJA7H5741
Firmware date: 2119-02-23 09:35
Bus encryption flags: 1F
Highest AACS version: 64
I removed the drive from the USB enclosure and attached using SATA
I've tried the LG crossflash NS50 patched flasher with:
* DE_HL-DT-ST_BD-RE_BH16NS58_1.00
* HL-DT-ST-BD-RE_BH16NS58-1.01-NM00500-211711161545
And get:
Write DRAM NG
05/26/03
I've tried ASUS_ODD_FW_Changer_(Modified) with
And get:
Updating Failure #4
I tried dosflash but my motherboard doesn't do IDE for SATA so no luck there.
Any advice?
Trouble flashing BH16NS58
Re: Trouble flashing BH16NS58
flash WH16NS60 1.02 mk
It worked! Thanks for the quick reply!
Thank you for all the job done.
I bought a used BH16NS58, then flashed it using "HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin" and SDFtool flasher.
It worked smoothly.
Just to let you know it works with the next version too.
Now I got this:
Informations lecteur
Nom du lecteur SE : E:
Fabricant : HL-DT-ST
Produit : BD-RE WH16NS60
Révision : 1.03
Numéro de série : KL1L9EG5452
Date micrologiciel : 2120-05-08 10:10
Marqueurs d'encryptage bus : 17
Firmware version: 1.03
It worked smoothly.
Now I got this:
Révision : 1.03
Libredrives: HLDS BH16NS58 (ext. enclosure), HLDS BH14NS58
Other: Pioneer BDR-UD03
CaelThunderwing
sorry to 2 year necro but i got this same drive in an Buffalo Enclosure, for 20$ at a flea market just got off my keister to flash to Libre Flashing to 1.02 wouldnt let me flash ths BH16NS58 specific MK Firmware, the WH16NS60 1.03 did, is it better to stay on the 1.01 LibreFW for this Specific drive or flash the Modified WH16NS60 1.03 FW back on it?
