Your drive does not have the 3.10 mk firmware. It's the OEM 3.10 firmware which is not libredrive compatible. Flash the 3.10 mk firmware.
I get this "device doesnot exist error" at the end of this note after successfully flashing with 3.1. What could be causing this error?
Firmware version: 3.10
Disc Information
Label: Crossroads 2013 Disc 2
Timestamp: 2013-10-12 12:37:48
Data capacity: 39.62 Gb
Disc type: BD-ROM
Number of layers: 2
Error Message:
MakeMKV v1.15.0 win(x64-release) started
Backing up disc into folder "D:/Movies/STEVIE_WONDER/Crossroads 2013 Disc 2"
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '230682624'
Backup failed
Disc Information
Disc type: BD-ROM
Number of layers: 2
Error Message:
Backup failed
Could be a read error but I'd probably try rebooting the machine and seeing if the error still occurs.
I rebooting the machine several times and tried different disks. Any other recommendations?
Nope, I'm afraid I don't. It's not likely the drive as it looks to be flashed correctly. Something with MakeMKV and your OS not playing well together but I've no idea what.
Hi guys, I just got a new LG WH14NS40 and planned to fix the firmware for UHD, it's currently at 1.04.
This is the process I'm planning:
use the patching tool - "BH14NS40_N1.00-A4_patched.exe" to flash MK firmware - HL-DT-ST-BD-RE_WH14NS40-NS50-1.04-NM01201-211901041351.bin.
Should this be enough or should I then downgrade?
If you use makemkv flash WH16NS60 1.02mkMacen wrote: Fri Mar 20, 2020 4:28 pm Hi guys, I just got a new LG WH14NS40 and planned to fix the firmware for UHD, it's currently at 1.04.
Nice, will try it Billycar11. Thanks for the reply!
I've got an WH14NS40 with V1.00 FW dated 2015/08/18. I know it is UHD friendly and what I have read says that V1.04 needs to be flashed to a lower FW for it to work with UHD discs. Since it is already at V 1.00 I'm not sure that is something I need to do in this case.
I've not had the need to try and rip a UHD disc because until last month I didn't have a 4K TV to play it on. Now I do - so I borrowed a copy of Dark Phoenix in 4K and proceeded to make a backup copy. That worked fine with no delays, stoppages or glitches. I thought I could then open the disccat.dat file in MakeMKV and then rip that way as I have done that for regular BD discs. That didn't work as I get a "failed to open disc" error. Since there is no actual disc I don't know if that means my backup copy is bad or if it is something else. I am using the most current version of MakeMKV 1.15.0.
So my questions are what did I do wrong and how do I fix it and if I have to flash the drive what should it go to?
I just received my LG BH16NS55 drive today. I had already received my Lantec NexStar DX USB 3 external drive case from Amazon last week and put them together. I put in a standard Bluray disk to test functionality and all went well. Now on to the fun stuff.
I fired up MakeMKV and checked the drive info:
It showed LibraDrive Information as posible with patched firmware with my current firmware version as 1.04
I fired up the ASUS)_ODD_FW_Changer_(Modified) program and selected the firmware under the BHi6NS55 folder which was:
HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.BIN
and clicked on Start. The drive ejected and the firmware update started and was completed in approx 45 seconds.
I cycled power to the drive and restarted MakeMKV, and now see under LibreDrive Information Status is now set to enabled and firmware shows as patched and version is still 1.04.
I am now curently ripping my first 4K Ultra HD. Fingers crossed.
Update:
45 minutes later, one successfully ripped 4K bluray
Big thank you and kudos to Billycar11 and his comrade's
Decibel
Update:
Decibel
please I need help I just buy ASUS BW-16D1HT, here is link for picture from MakeMKV + Photo of the burner (https://imgur.com/a/9cei5Y5), is it possible to rip 4k and which version should I download (and flash) to rip 4K please, because right now I found a lot of versions of manuals and I am not sure which is the best and best verison for my ASUS burner. Which tutorial is newest what should I do please?
Thank you very much
Thank you very much
Assblaster1979
Wow thank you man for saying the Asus firm ware worked on the drive . I also have the Lg 60 drive . Flashed it you made me so happey now UHD rips he we come man
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: MDCG5LB0421
Firmware date: 2115-04-22 15:17
Highest AACS version: 72
svc ns50
Firmware version: 1.00
I keep getting "Updating Failure #5"
i'm following the guide step by step and keep getting the same error.
please help
Revision: 1.00
svc ns50
please help
Umm your drive is alread libredrive enabled what are you trying to do?dp5081 wrote: Mon Apr 06, 2020 9:47 pm Drive Information
Revision: 1.00
svc ns50
please help
oooooh, interesting so how come i can't see uhds on it then?
