ASUS BC-12D2HT
SoulSurvivor
ASUS BC-12D2HT
Post by SoulSurvivor » Fri Mar 20, 2020 4:45 pm
Hello all,
I was able to flash my BDROM with the firmware "ASUS-BC-12D2HT-3.11-WM00300-211902271319" with the "ASUS_ODD_FW_Changer_(Modified)". I have the information below from makemkv program :
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number: KL4JALB4707
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Highest AACS version: 66
Firmware version: 3.11
But when I insert a UHD or even a BD disc, it's searching but find no disc.
I'm hitting my head against the wall, so if someone could help this would be super nice ! :)
Many thanks,
Gabriel
Re: ASUS BC-12D2HT
Post by Billycar11 » Fri Mar 20, 2020 6:54 pm
What's the build date on the outside of the drive.
SoulSurvivor
Re: ASUS BC-12D2HT
Post by SoulSurvivor » Fri Mar 20, 2020 8:27 pm
Manufactured : October 2019
Re: ASUS BC-12D2HT
Post by Billycar11 » Fri Mar 20, 2020 11:52 pm
SoulSurvivor wrote: Fri Mar 20, 2020 8:27 pm Hello,
hmm strange does a dvd work?
and does windows see the disc?
SoulSurvivor
Re: ASUS BC-12D2HT
Post by SoulSurvivor » Sat Mar 21, 2020 12:48 pm
A DVD don't work.
Windows see the drive but not the disc.
FYI there is a very small image like 2mm each of two guys with a green t-shirt on the icon of this drive that there is not on the others.
Re: ASUS BC-12D2HT
Post by Billycar11 » Sat Mar 21, 2020 9:01 pm
SoulSurvivor wrote: Sat Mar 21, 2020 12:48 pm A DVD don't work.
How is this drive hooked up?
SoulSurvivor
Re: ASUS BC-12D2HT
Post by SoulSurvivor » Sun Mar 22, 2020 6:59 am
1. He is plugged Sata, and the controller on the bios is on AHCI. I've tried also on another pc that have the controller in IDE but this is the same.
2,Nevertheless and if this could help, I have the same problem with another drive, the LG WH16NS60 but the difference is that he is able to see at least the CD (but not the DVD, BD and UHDBD). Important information, I was able to see a 4k UHD disk! "When Big Meet Bigger", I've started the ripping, but in the middle of the operation he put me a reading error. I stopped the process and I remove the disk, I cleaned it, re-enter the disk... He never showed me again the 4k disc....
I received this LG WH16NS60 drive with the firmware 1.02. I had to crossflash with a few other firmwares, included some Asus before being able to flash him with a "good one". So I was able to put your 1.02 mk firmware, also tried with the firmware DE 1.00, both don't work. I was so so desesperate that I even tried with the Dvdfab downgrade method, same results...
Re: ASUS BC-12D2HT
Post by Billycar11 » Sun Mar 22, 2020 10:11 am
SoulSurvivor wrote: Sun Mar 22, 2020 6:59 am 1. He is plugged Sata, and the controller on the bios is on AHCI. I've tried also on another pc that have the controller in IDE but this is the same.
something is wrong but i have no idea what.
i would investigate why your drive shows a green t shirt on the in the file explorer.
SoulSurvivor
Re: ASUS BC-12D2HT
Post by SoulSurvivor » Sun Mar 22, 2020 11:01 am
Thank you very very much! I hope to find a way to thank you in return soon !
FYI it's this kind of "two guys with a green t-shirt" :
