Did anyone ever find a fix for the stutter problems using Grencola's tool?
I haven't been able to get a single working file with that tool, they all stutter like crazy on my LG B9.
are you using mkv remux or m2ts? had a few remuxes that stuttered, all m2ts have been fine though. I don't own a B9 but many others who do have no problems. you can try yusesope's tool and make a bl+el-rpu hevc then run that through mp4 muxer via profile 7.
I've also been having stuttering issues.
Tested on a OLED C7 and C9 with Emby/Plex. Also tested on Nvidia shield (2019)
My goal would be to have DV work on devices that can fully support it, otherwise fallback to HDR. I'm fully aware that Atmos will not work on WebOS client and I'm ok with it.
I used Joker for testing.
So:
I'd like to avoid having to make a mp4 and a ts version of each movie depending of the source.
MediaInfo:
So:
- On C7 WebOS, It should play DV, AC3 5.1 Core
- On C9 WebOS, It should play DV, AC3 5.1 Core
- On Nvidia Shield it should play DV, Atmos
- ffmpeg to decode the BL + EL layer
ffmpeg -i bluray:H:\ -map 0:0 -c copy D:\output\BL.hevc -map 0:1 -c copy D:\output\EL.hevc - yusesope's script to merge the layers (all counters to 100%)
python src\bl_el_rpu_builder.py -bl D:\output\BL.hevc -el D:\output\EL.hevc -of D:\output\Full.hevc - tsmuxer to remux the new hevc + truehd atmos to TS
- If I pick the TrueHD file, Emby goes into direct streaming (downgrade the sound) and HDR shows up
- If I pick the Core AC3 file, black screen
- If I pick the TrueHD file, Emby goes into direct streaming (downgrade the sound) and HDR shows up (e-ARC doesn't work as it should, but that's a known issue)
- If I pick the Core AC3 file, Dolby Vision shows up, but it stutters really really bad
- If I pick the TrueHD file, HDR is triggered (direct play) on C7, Dolby Vision on C9. Only Plex works.
- If I pick the Core AC3 file, HDR is triggered (direct play) on C7, Dolby Vision on C9. Only Plex works.
Not sure why the result would be different between the C7 and the C9 while running on Shield though...
MediaInfo:
General
Complete name : \\192.168.0.200\movies\Movies\Joker (2019)\Joker (2019) - UHD.ts
Format : MPEG-TS
File size : 48.6 GiB
Duration : 2 h 1 min
Overall bit rate mode : Variable
Overall bit rate : 57.1 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 53.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.270
Stream size : 45.7 GiB (94%)
Language : English
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primar : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 992 cd/m2
Maximum Frame-Average Light Le : 120 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 7 158 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 558 MiB (1%)
Language : English
Service kind : Complete Main
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
I really appreciate it. Thank you.
It's a cursed movie. It is the only explanation.shawnc22 wrote: ↑Thu Mar 19, 2020 10:35 pmSo one last thing with that problematic movie. I stripped out the BL layer from the mkv that I made out of the original disk, and it surprisingly mixed successfully (equal AUDs) with the EL layer I had extracted prior from the decrypted M2TS. But once muxed back into the TS container with the Atmos audio, there was definitely a hiccup in the video at the 0:43:35 mark and the audio became desynced thereafter. Odd that there was no hiccup in playback of the mkv file though at the same point, so the EL is seemingly the problematic source even though the original BL was the one with the missing AUD.
Yes, it was exactly what I meant.shawnc22 wrote: ↑Thu Mar 19, 2020 10:35 pmI just commented out that entire conditional block with the "Duallayers" variable and simply forced the DV profile to 4 (bitWriter.putBits(7,4))
Triggers DV on the shield and looks pretty much the same as the profile 8 video. Again, I know what I did was very hacky as I was just curious if changing the DV profile would do anything. Perhaps after the devs take a look at it and implement a real change, there will be some noticeable differences.
Changing the profile does not affect the visual quality (
In the case of an MPEG-2 TS it is important that a Registration Descriptor with the value 0x0504444F5649 is created (
you can search for these 6 bytes in your ts files with any hex editor like HxD) and that the DOVI_video_stream_descriptor (the part of the program you edited) is constructed with a precise semantics.
In the official document it says that "The el_present_flag set according to the profile. Note that certain profiles defined in Signaling Dolby Vision Profiles and Levels do not include an EL."
Profile 8 does not have the EL layer, 4 does.
As for the DVCompatibility value, it was used to choose between profile 8 and 5 (the part of the program you excluded).
In the case of a profile 4, according to the guidelines, cross-compatibility should be set to SDR (DVCompatibility = 2). My files are reported as compatible with HDR10: tsMuxeR correctly manages the VUIs (0,9,16,9,2) while my file is slightly out of standard (as it is derived from a UHD-BD). But the behavior of the decoder is not dependent on these Dolby Vision defined crosscompatibility IDs, so we're safe!
Everything seems OK to me.Deihnyx wrote: ↑Fri Mar 20, 2020 7:44 amI used the method described in the past threads.
ffmpeg -i bluray:H:\ -map 0:0 -c copy D:\output\BL.hevc -map 0:1 -c copy D:\output\EL.hevc- yusesope's script to merge the layers (all counters to 100%)
python src\bl_el_rpu_builder.py -bl D:\output\BL.hevc -el D:\output\EL.hevc -of D:\output\Full.hevc- tsmuxer to remux the new hevc + truehd atmos to TS
To try to understand where the problem lies, I recommend you:
Download version_0.0.3_revision_1 of my tool and start it with the command:
python bl_el_rpu_builder_v0.0.3_rev_1.py -bl D:\output\BL.hevc -el D:\output\EL.hevc -of D:\output\New_Full.hevcIf everything was ok, I recommend, before using tsMuxeR, to test only the video with mp4muxer (HERE) by trying both profile 4 and profile 7 (it takes some time).
mp4muxer -i D:\output\New_Full.hevc --dv-profile 4 -o D:\output\New_Full_dvhe04.mp4Code: Select all
mp4muxer -i D:\output\New_Full.hevc --dv-profile 7 -o D:\output\New_Full_dvhe07.mp4If that doesn't work, try creating a BL + RPU file by adding the "-mode 2" switch to my script.
python bl_el_rpu_builder_v0.0.3_rev_1.py -mode 2 -bl D:\output\BL.hevc -el D:\output\EL.hevc -of D:\output\BL_RPU.hevcRe: Dolby Vision now possible through MP4 Mux.
So if I understand correctly, by muxing the hevc file first into mp4 container with dolby's mp4muxer, it will get the correct profile (eg 04 or 07).yusesope wrote: ↑Fri Mar 20, 2020 10:58 amTo try to understand where the problem lies, I recommend you:
Download version_0.0.3_revision_1 of my tool and start it with the command:It is important that all the counters reach 100%, that the total number of BL AUDs is equal to those of EL Layer and that the program ends with the invitation to "press a button to exit".Code: Select all
If everything was ok, I recommend, before using tsMuxeR, to test only the video with mp4muxer (HERE) by trying both profile 4 and profile 7 (it takes some time).Code: Select all
mp4muxer -i D:\output\New_Full.hevc --dv-profile 4 -o D:\output\New_Full_dvhe04.mp4If the video is displayed correctly on your devices then add the audio with tsMuxeR (as you did previously).Code: Select all
If that doesn't work, try creating a BL + RPU file by adding the "-mode 2" switch to my script.Code: Select all
So this is like a workaround when muxing the hevc file directly using TSMuxeR's causing profile 08 to be set?
No, it's only for testing purpose.
why dvdfab isn't work well anymore? is this because the new updates? i have problems with 1917 and more others. i have a black screen on my lg c9. anyone else?
I may be wrong but I don't believe that the "AC3 core" is an actual track that can be played. You'd either have to convert that truehd track into LPCM like you'd do for the mp4 method or include one of the other non-truehd tracks from the original disk into the TS container.Deihnyx wrote: ↑Fri Mar 20, 2020 7:44 amHello,
So:
Right, I saw that part and started to backtrack the code to see how I can correctly change DualLayers and m_hdr->isHDR10 to fall into the other side of the conditional and choose profile 4 on its own, but it eventually got too much for my understanding of the subject and hence the hacky change
Hi all, so I registered to the forum, as it will certainly be more efficient than members notifying of discussions from here on the tsMuxer forum (thanks @baker99). By the way I am far from being a 'real dev'...shawnc22 wrote: ↑Fri Mar 20, 2020 3:38 pmRight, I saw that part and started to backtrack the code to see how I can correctly change DualLayers and m_hdr->isHDR10 to fall into the other side of the conditional and choose profile 4 on its own, but it eventually got too much for my understanding of the subject and hence the hacky change. I'll leave it up the real devs to make the correct changes
Patch for tsMuxer profile 4 / single track double layer has been pushed here.
@yusesope, according to the DV profile & level document, profile 4 is normally limited to BL signal cross-compatibility ID 2 = SDR with VUI BL 0, 1, 1, 1, 0 EL 1, 2, 2, 2, 0. Your profile 4 single track files created from Blu-ray double tracks have VUI BL & EL 0, 9, 16, 9, 2. I don't have any DV hardware to test lecture of the files, should I keep BL signal cross-compatibility ID to 6, or change it to 2 ?
oldirtydog
with eactogui i create a 1.hevc 2.hevc and 3.ac3 but when i trying to make it in 1 i had error ac3 something... http://alfa.kachi-snimka.info/vij.php?i ... 8992o.jpeg
care to explain the steps and commands u use for this?Mortenjorstad wrote: ↑Wed Mar 18, 2020 1:39 pmI have know made M2ts files with hd audio on all my 56 DV movies. Every movie play perfect on shield 2019 with DV and Atmos/dts x sound.
1 demux with eac3to Eac3to path to moviefolder 2:bl.hevc 3:el.hevc
2 tak the 2 files and import them into yuseope tool v02
3 use tsmuxer modified Version, mux file made by yuseope tool with audio from Blu-ray.
https://drive.google.com/uc?id=10zOr0IU ... t=download
would appriciate alot
@yusesope
Just made a .m2ts DV of Black Panther using your tool v.003 and the latest fork of tsmuxer posted on tsmuxer forum by @a5180007 that corrects the DV profile as per your observations. Mediainfo: HDR format Dolby Vision version 1.0, dvhe 04.06, BL+EL+RPU /SMPTE ST2086, HDR10 compatible
This plays perfectly in Shield TV 2019 on plex. It triggers Dolby Vision and Dolby Atmos.
Will try other movies tomorrow.
Thanks again for your great knowledge and efforts.
Does it mean the Shield Pro support the EL layer on top of the BL, all it discards the extended layer? I am really confused about the profile 04.06 and BL+EL+RPU part of it. I thought the new Shield TV Pro only supported profile 5, which means up to 10-bit input. But with EL it makes it up to 12-bit input signal.ragico wrote: ↑Fri Mar 20, 2020 9:55 pm@yusesope
Angryunibrow
Link to test build of tsmuxer, I don't have a github account.ragico wrote: ↑Fri Mar 20, 2020 9:55 pm@yusesope
Last edited by Angryunibrow on Fri Mar 20, 2020 11:13 pm, edited 2 times in total.
Angryunibrow
2019 Shield supports Profile 4 MEL, 5 & 8mulucy wrote: ↑Fri Mar 20, 2020 10:54 pmDoes it mean the Shield Pro support the EL layer on top of the BL, all it discards the extended layer? I am really confused about the profile 04.06 and BL+EL+RPU part of it. I thought the new Shield TV Pro only supported profile 5, which means up to 10-bit input. But with EL it makes it up to 12-bit input signal.ragico wrote: ↑Fri Mar 20, 2020 9:55 pm@yusesope
