#511 Post by SamuriHL » Thu Mar 19, 2020 12:50 pm
Your drive does not have the 3.10 mk firmware. It's the OEM 3.10 firmware which is not libredrive compatible. Flash the 3.10 mk firmware.
maxrotor
#512 Post by maxrotor » Thu Mar 19, 2020 2:47 pm
I get this "device doesnot exist error" at the end of this note after successfully flashing with 3.1. What could be causing this error?
Firmware version: 3.10
Disc Information
Label: Crossroads 2013 Disc 2
Timestamp: 2013-10-12 12:37:48
Data capacity: 39.62 Gb
Disc type: BD-ROM
Number of layers: 2
Error Message:
MakeMKV v1.15.0 win(x64-release) started
Backing up disc into folder "D:/Movies/STEVIE_WONDER/Crossroads 2013 Disc 2"
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '230682624'
Backup failed
#513 Post by SamuriHL » Thu Mar 19, 2020 3:11 pm
Could be a read error but I'd probably try rebooting the machine and seeing if the error still occurs.
maxrotor
#514 Post by maxrotor » Thu Mar 19, 2020 5:55 pm
I rebooting the machine several times and tried different disks. Any other recommendations?
#515 Post by SamuriHL » Thu Mar 19, 2020 6:01 pm
Nope, I'm afraid I don't. It's not likely the drive as it looks to be flashed correctly. Something with MakeMKV and your OS not playing well together but I've no idea what.
Macen
#516 Post by Macen » Fri Mar 20, 2020 4:28 pm
Hi guys, I just got a new LG WH14NS40 and planned to fix the firmware for UHD, it's currently at 1.04.
This is the process I'm planning:
use the patching tool - "BH14NS40_N1.00-A4_patched.exe" to flash MK firmware - HL-DT-ST-BD-RE_WH14NS40-NS50-1.04-NM01201-211901041351.bin.
Should this be enough or should I then downgrade?
#517 Post by Billycar11 » Fri Mar 20, 2020 6:55 pm
Macen wrote: Fri Mar 20, 2020 4:28 pm Hi guys, I just got a new LG WH14NS40 and planned to fix the firmware for UHD, it's currently at 1.04.
If you use makemkv flash WH16NS60 1.02mk
Macen
#518 Post by Macen » Fri Mar 20, 2020 10:07 pm
Billycar11 wrote: Fri Mar 20, 2020 6:55 pm
Nice, will try it Billycar11. Thanks for the reply!
The_AVB
#519 Post by The_AVB » Sun Mar 22, 2020 1:15 am
I've got an WH14NS40 with V1.00 FW dated 2015/08/18. I know it is UHD friendly and what I have read says that V1.04 needs to be flashed to a lower FW for it to work with UHD discs. Since it is already at V 1.00 I'm not sure that is something I need to do in this case.
I've not had the need to try and rip a UHD disc because until last month I didn't have a 4K TV to play it on. Now I do - so I borrowed a copy of Dark Phoenix in 4K and proceeded to make a backup copy. That worked fine with no delays, stoppages or glitches. I thought I could then open the disccat.dat file in MakeMKV and then rip that way as I have done that for regular BD discs. That didn't work as I get a "failed to open disc" error. Since there is no actual disc I don't know if that means my backup copy is bad or if it is something else. I am using the most current version of MakeMKV 1.15.0.
So my questions are what did I do wrong and how do I fix it and if I have to flash the drive what should it go to?
Decibel
#520 Post by Decibel » Mon Mar 30, 2020 1:37 am
I just received my LG BH16NS55 drive today. I had already received my Lantec NexStar DX USB 3 external drive case from Amazon last week and put them together. I put in a standard Bluray disk to test functionality and all went well. Now on to the fun stuff.
I fired up MakeMKV and checked the drive info:
It showed LibraDrive Information as posible with patched firmware with my current firmware version as 1.04
I fired up the ASUS)_ODD_FW_Changer_(Modified) program and selected the firmware under the BHi6NS55 folder which was:
HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.BIN
and clicked on Start. The drive ejected and the firmware update started and was completed in approx 45 seconds.
I cycled power to the drive and restarted MakeMKV, and now see under LibreDrive Information Status is now set to enabled and firmware shows as patched and version is still 1.04.
I am now curently ripping my first 4K Ultra HD. Fingers crossed.
Update:
45 minutes later, one successfully ripped 4K bluray
Big thank you and kudos to Billycar11 and his comrade's
Decibel
vojta272
#521 Post by vojta272 » Wed Apr 01, 2020 10:55 am
please I need help I just buy ASUS BW-16D1HT, here is link for picture from MakeMKV + Photo of the burner (https://imgur.com/a/9cei5Y5), is it possible to rip 4k and which version should I download (and flash) to rip 4K please, because right now I found a lot of versions of manuals and I am not sure which is the best and best verison for my ASUS burner. Which tutorial is newest what should I do please?
Thank you very much
Assblaster1979
#522 Post by Assblaster1979 » Sat Apr 04, 2020 4:18 am
Wow thank you man for saying the Asus firm ware worked on the drive . I also have the Lg 60 drive . Flashed it you made me so happey now UHD rips he we come man
dp5081
#523 Post by dp5081 » Mon Apr 06, 2020 9:47 pm
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: MDCG5LB0421
Firmware date: 2115-04-22 15:17
Highest AACS version: 72
svc ns50
Firmware version: 1.00
I keep getting "Updating Failure #5"
i'm following the guide step by step and keep getting the same error.
please help
#524 Post by Billycar11 » Tue Apr 07, 2020 12:06 am
dp5081 wrote: Mon Apr 06, 2020 9:47 pm Drive Information
Revision: 1.00
svc ns50
please help
Umm your drive is alread libredrive enabled what are you trying to do?
dp5081
#525 Post by dp5081 » Tue Apr 07, 2020 1:18 am
oooooh, interesting so how come i can't see uhds on it then?
