fake playlist / Doctor Who : Tom Baker - Complete Season Seven (8 DISC)
phillip9
#1 Post by phillip9 » Thu Mar 19, 2020 1:57 am
I'm trying to make a backup of this 8 blu-ray disc set
If the log file does not help, can you please give me step-by-step instructions for what to do next?
thank you & stay safe
Debug log started at Thu Mar 19 01:53:09 2020 , written by MakeMKV v1.15.0 win(x64-release)
001005:0000 MakeMKV v1.15.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Phill/MakeMKV_log.txt
No SDF v06d: hp_BDDVDRW_CH28N_ED3F_20120905123456_B2IE3P4098695
SDF id v06d: hp_BDDVDRW_CH28N_ED3F_20120905123456_B2IE3P4098695
005050:0000 Evaluation version, 25 day(s) out of 30 remaining
No auto SDF v06d: hp_BDDVDRW_CH28N_ED3F_20120905123456_B2IE3P4098695
DEBUG: Code 0 at -X^_?N#8L2!>=v5=9:29395540
DEBUG: Code 0 at sMvU$A}zJ$@KgUtt:213141599
DEBUG: Code 0 at Ol~"E_@BEikMd^~p:29401014
DEBUG: Code 2147483648 at sMvU$A}zJ$@KgUtt:213132974
DAFD=PAAAADAAAAEABDQkEHwEBAQ==
DCE=/69WOnNw2EzvmIMg3BgcL8PCQK0576ENOta+bLKMow0iiyVhoO1sX2DqZkUEzjRXfcuiRamRvh3lI4dkY0if32Yxk8cE77A5r9W1vc/DYkKYtUG92yhmOIZYEWo24OrklMexfUy3luHNXzpbvPlCBb498vWF3nFHCQ==
DCE=fdY5e2pYJsWfkYlL4ha0ZxLzQxfO6xNzz6AOtR9vNVo2/v27WoNOdPdas0gtlbKWi3OD9gcWC4dizRJkelRSfkiPMkQi7MIfNFT+eM4WarPLiYLL7FxY5HsSirmaHylexny2Nk+8Y8VCfuA183DT2Ux8+g4ySBULig==
DISCID=CF643EB921E32E4487191757C909D98700E5C48D
003307:0000 File 00022.mpls was added as title #0
003307:0000 File 00023.mpls was added as title #1
003307:0000 File 00028.mpls was added as title #2
003307:0000 File 00029.mpls was added as title #3
003307:0000 File 00030.mpls was added as title #4
003307:0000 File 00031.mpls was added as title #5
003307:0000 File 00033.mpls was added as title #6
003307:0000 File 00034.mpls was added as title #7
003309:0000 Title 00017.mpls is equal to title 00028.mpls and was skipped
003309:0000 Title 00018.mpls is equal to title 00029.mpls and was skipped
003307:0000 File 00021.mpls was added as title #8
003309:0000 Title 00027.mpls is equal to title 00030.mpls and was skipped
003309:0000 Title 00032.mpls is equal to title 00031.mpls and was skipped
003025:0000 Title #00005.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00028.m2ts was added as title #9
003025:0000 Title #00029.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00030.m2ts was added as title #10
003025:0000 Title #00037.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00040.m2ts was added as title #11
003307:0000 File 00041.m2ts was added as title #12
003307:0000 File 00042.m2ts was added as title #13
003025:0000 Title #00043.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at 0OG1MuV89W91yjl0A7GVTjWd:0
Application exited at Thu Mar 19 01:54:31 2020
Re: fake playlist / Doctor Who : Tom Baker - Complete Season Seven (8 DISC)
#2 Post by Woodstock » Thu Mar 19, 2020 3:37 am
The BBC doesn't use what is generically referred to as "fake play list", at least not to the extent that Lionsgate does. If they did, there would be hundreds of files to chose from. :( All of the DW sets I've ripped were just episodes, nothing "fake".
If you're doing a BACKUP (saving the contents as a Bluray file structure, so as to maintain all menu stuff), you should NOT click the big "Open" button, and most of what is in your log would not be there. Insert the disk, click the (smaller) Backup button, decide where you want the result to be put, and whether or not you want MakeMKV to decrypt it for you.
To make individual MKV files, you get to select which titles you want converted, and assign them names, then let MakeMKV do its job.
