How do you play them if i may ask? With Plex? Or maybe MX Player?Mortenjorstad wrote: ↑Wed Mar 18, 2020 1:39 pmI have know made M2ts files with hd audio on all my 56 DV movies. Every movie play perfect on shield 2019 with DV and Atmos/dts x sound.
1 demux with eac3to Eac3to path to moviefolder 2:bl.hevc 3:el.hevc
2 tak the 2 files and import them into yuseope tool v02
3 use tsmuxer modified Version, mux file made by yuseope tool with audio from Blu-ray.
https://drive.google.com/uc?id=10zOr0IU ... t=download
I've been following this thread for a few days. Great work. I've looked through all 114 pages and I thing I understand the current workflow.
Extract the BL and EL
Use yuseope's v0.0.3 tool to combine BL and EL
Open the modified tsMuxerGUI.exe. (11f852a)
Open the backup disk main mpls playlist file.
Insert the newly created Shazam.hevc and select it with the check box.
Select TRUE-HD AC3 core+TRUE-HD 7.1 with the check box.
Uncheck everything else and then start demuxing as a ts file.
When I complete these steps I have an issue with playback.
My setup:
105 MB/s avg. throughput on gigabit Ethernet
Plex server (Plex Pass)
Shield 2019 with plex app (not pro)
Vizio PX75G1
Denon receiver with Atmos 5.1.2 speaker setup
When I play the ts file my TV shows Dolby Vision, my receiver shows Dolby Atmos/DSur and Plex lists it a AC3 5.1. However, about 9 seconds into the movie shudders and freezes. I can fast forward. It will jump ahead but it freezes up again. I also tried playback from an SD card on my streaming device. Same thing so I don't think it's network related.
I also ran the remuxing and created an m2ts file. This file plays smooth with great audio sync. However it appears that I loose the Dolby Vision indicator. My receiver shows Dolby Atmos and Plex lists it a TRUE HD 7.1
To run some further tests I gave Dolby's mp4muxer a try with the same BL EL hevc files and an AC3 5.1 audio track I extracted with the modified tsMuxerGUI.
This worked as others have reported. Dolby Vision indicator, smooth audio video but it has AC3 5.1
Any ideas on what might be going on? Below is the MediaInfo on the files.
Shazam.ts
Shazam.m2ts
Shazam.mp4
ffmpeg -i bluray:C:\Video\backup\SHAZAM -map 0:0 -c copy C:\Video\BL.hevc -map 0:1 -c copy C:\Video\EL.hevc
python src\bl_el_rpu_builder.py -bl C:\Video\BL.hevc -el C:\Video\EL.hevc -of C:\Video\bl_el_rpu_builder_v0.0.3\Shazam.hevc
My setup:
Vizio PX75G1
mp4muxer --dv-profile 7 --input-file C:\Video\BL.hevc --input-file C:\Video\EL.hevc --input-file C:\Video\00800.track_4353.ac3 --media-lang eng --output-file B:\Media\Calibration\Shazam_ver2.mp4
Shazam.ts
General
Complete name : B:\Media\Calibration\Shazam_Dolby_Vision_Atmos_Ver2_ts.ts
Format : MPEG-TS
File size : 77.0 GiB
Duration : 2 h 11 min
Overall bit rate mode : Variable
Overall bit rate : 83.7 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 79.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.398
Stream size : 72.8 GiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1351 cd/m2
Maximum Frame-Average Light Level : 384 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 448 kb/s
Maximum bit rate : 5 931 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 422 MiB (1%)
Language : English
Service kind : Complete Main
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
General
Complete name : B:\Media\Calibration\Shazam_Dolby_Vision_Atmos_Ver2_m2ts.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 78.7 GiB
Overall bit rate : 85.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 81.7 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.411
Stream size : 75.2 GiB (96%)
Audio
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 448 kb/s
Language : English
General
Complete name : B:\Media\Calibration\Shazam_ver2.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 71.1 GiB
Overall bit rate : 77.3 Mb/s
Encoded date : UTC 2020-03-18 21:47:58
Tagged date : UTC 2020-03-18 21:47:58
Video #1
Format : HEVC
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 76.7 Mb/s
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.386
Stream size : 70.6 GiB (99%)
Default : Yes
Alternate group : 1
Codec configuration box : hvcC
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Bit rate : 62.0 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.001
Stream size : 58.4 MiB (0%)
Default : No
Alternate group : 1
Codec configuration box : hvcC+dvcC
Audio
Format : AC-3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Language : English
Default : Yes
Alternate group : 2
Not sure if this will fix your issue, but on first time playback of the TS file, you have to manually select the TRUEHD 7.1 audio track and not the AC3 5.1. Because of the AC3 core in the atmos track, plex will default to the ac3 5.1 track. Your video track is also not showing BL+EL+RPU, only BL+RPU. It might be the version of TSMuxer you're using. m2ts will also not work with DV+atmos, only TS will.Rufus wrote: ↑Thu Mar 19, 2020 1:26 amWhen I play the ts file my TV shows Dolby Vision, my receiver shows Dolby Atmos/DSur and Plex lists it a AC3 5.1. However, about 9 seconds into the movie shudders and freezes. I can fast forward. It will jump ahead but it freezes up again. I also tried playback from an SD card on my streaming device. Same thing so I don't think it's network related.
Thanks, I'll take a look at selecting the audio track in plex. A few pages back there's a link for a tsmuxer v0.0.2 at https://drive.google.com/open?id=1HWf-l ... 4n70PDFeb-shawnc22 wrote: ↑Thu Mar 19, 2020 4:04 amNot sure if this will fix your issue, but on first time playback of the TS file, you have to manually select the TRUEHD 7.1 audio track and not the AC3 5.1. Because of the AC3 core in the atmos track, plex will default to the ac3 5.1 track. Your video track is also not showing BL+EL+RPU, only BL+RPU. It might be the version of TSMuxer you're using. m2ts will also not work with DV+atmos, only TS will.Rufus wrote: ↑Thu Mar 19, 2020 1:26 amWhen I play the ts file my TV shows Dolby Vision, my receiver shows Dolby Atmos/DSur and Plex lists it a AC3 5.1. However, about 9 seconds into the movie shudders and freezes. I can fast forward. It will jump ahead but it freezes up again. I also tried playback from an SD card on my streaming device. Same thing so I don't think it's network related.
Ran everything through tsmuxer v0.0.2 and this time the ts file shows BL+EL+RPU. Below is the MediaData. I haven't had a chance yet to test it on my TV.
General
Complete name : B:\Media\Calibration\Shazam_11f852a.ts
Format : MPEG-TS
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Audio
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 448 kb/s
Language : English
With plex on shield 2019eblackadder wrote: ↑Wed Mar 18, 2020 10:20 pmHow do you play them if i may ask? With Plex? Or maybe MX Player?Mortenjorstad wrote: ↑Wed Mar 18, 2020 1:39 pmI have know made M2ts files with hd audio on all my 56 DV movies. Every movie play perfect on shield 2019 with DV and Atmos/dts x sound.
With plex you can see before you start the movie if subtitles is oneblackadder wrote: ↑Wed Mar 18, 2020 9:57 pmWhere do you have to turn it off?Mortenjorstad wrote: ↑Wed Mar 18, 2020 9:46 amHad same error on some movies, you must turn off pgs subtitles.RESET_9999 wrote: ↑Wed Mar 18, 2020 12:09 amAnyone tried 1917 ?
I'm testing @yusesope newest version of the tool but playback stops at exactly 1min16 on the shield (tried 3 times). BL+EL+RPU+Atmos
Fast forward also stop playback with the same error.
as usual , Dual layer TS + Atmos works like a charm on the x700. that movie looks amazing in DV btw.
Hi all,
I'm a little confused. I heard/read that it was not possible to use Dolby Vision/Atmos with M2TS files but Mortenjorstad wrote that he made 56 dv movies.
So i tried it too with the movie 1917 and played it on the shield tv pro. My tv is the Lg Oled C7 and it triggers dv. My receiver is the Denon 4300h and shows Atmos.
When i look to the info file it looks good.
Algemeen
Volledige naam : D:\4k Movies\1917.m2ts
Formaat : BDAV
Formaat/Info : Blu-ray Video
Bestandsgrootte : 71,8 GiB
Duur : 1 h 58 min
Totale bitratemodus : Variabel
Totale bitrate : 86,4 Mb/s
Maximale Totale bitrate : 35,5 Mb/s
Video
Menu-ID : 1 (0x1)
Formaat : HEVC
Formaat/Info : High Efficiency Video Coding
Formaatprofiel : Main 10@L5.1@High
HDR_Format/String : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec-ID : 36
Duur : 1 h 58 min
Bitrate : 82,5 Mb/s
Breedte : 3 840 pixels
Hoogte : 2 160 pixels
Beeldverhouding : 16:9
Framerate : 23,976 (24000/1001) FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0 (Type 2)
BitDepth/String : 10 bits
Bits/(Pixel*Frame) : 0.415
Stroomgrootte : 68,6 GiB (96%)
colour_range : Limited
colour_primaries : BT.2020
transfer_characteristics : PQ
matrix_coefficients : BT.2020 non-constant
MasteringDisplay_ColorPrimaries : Display P3
MasteringDisplay_Luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
MaxCLL : 1000 cd/m2
MaxFALL : 168 cd/m2
Audio
Menu-ID : 1 (0x1)
Formaat : AC-3 MLP FBA 16-ch
Formaat/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Format_Commercial_IfAny : Dolby TrueHD with Dolby Atmos
Muxingmodus : Stream extension
Codec-ID : 131
Duur : 1 h 58 min
Bitrate-modus : Variabel
Bitrate : 448 kb/s
Maximale bitrate : 7 158 kb/s
Kanaal(en) : 8 kanalen
ChannelLayout : L R C LFE Ls Rs Lb Rb
Samplerate : 48,0 kHz
Framerate : 31,250 FPS (1536 SPF)
Video vertraging : 17 ms
Stroomgrootte : 381 MiB (1%)
Taal : Engels
ServiceKind/String : Complete Main
NumberOfDynamicObjects : 11
BedChannelCount/String : 1 kanaal
BedChannelConfiguration : LFE
Is this good or not good?
Algemeen
Formaat : BDAV
Duur : 1 h 58 min
Video
Menu-ID : 1 (0x1)
Formaat : HEVC
Codec-ID : 36
Duur : 1 h 58 min
Bitrate : 82,5 Mb/s
ColorSpace : YUV
MaxCLL : 1000 cd/m2
MaxFALL : 168 cd/m2
Audio
Menu-ID : 1 (0x1)
Codec-ID : 131
Duur : 1 h 58 min
Bitrate : 448 kb/s
Taal : Engels
Ah my fault, that does look good. It was earlier on in the process that people weren’t able to get m2ts working and only ts, maybe that’s changed in the more recent versions of tsmuxer and just that nobody has tried. Did you experience the same playback issues that RESET_999 was having?eblackadder wrote: ↑Thu Mar 19, 2020 12:18 pmHi all,
Algemeen
Formaat : BDAV
Duur : 1 h 58 min
Video
Menu-ID : 1 (0x1)
Formaat : HEVC
Codec-ID : 36
Duur : 1 h 58 min
Bitrate : 82,5 Mb/s
ColorSpace : YUV
MaxCLL : 1000 cd/m2
MaxFALL : 168 cd/m2
Audio
Menu-ID : 1 (0x1)
Codec-ID : 131
Duur : 1 h 58 min
Bitrate : 448 kb/s
Taal : Engels
@Shawnc22
I still have to try with subs but without subs it kept playing although i let it only play for a few minutes. I am going to try it with subs as well.
On MX Player it runs fine when you start, also with subs.(HW decoder) When you set it on pause and continue then there's no problem but when you stop the movie and want to continue then it gets to HW+ and it shows hdr10 plus stereo. When i want togo back to HW i get the message that HW isn't supported. That's of course strange because when you start the movie it plays perfect.
I just tried PGS subs with plex and then i get the message that it can't process the subs well and it continues without subs.
v0.0.2 was bugged: for this reason has been replaced by version 0.0.3 (which has instead identified the problem)
The "The source file seems to be damaged" is quite explanatory.
I also took a look at the tsMuxeR code and I think I have identified the reason why your .ts files are marked with the profile dvhe.08 (the profile dvhe.04 should be the right one since dvhe.08 does not have the Enhancement Layer).
I believe the problem occurs HERE: all Single Track Double Layer files are treated as Single Track Single Layer files.
Examples:
- THIS LG demo (dvhe.04) is remuxed in a dvhe.05 file
- Joker's BL + EL + RPU raw stream that I uploaded some time ago (HERE) is flagged as dvhe.08 (like your remuxes).
The presence of EL should be used to distinguish a Double Layer file from a Single Layer file.
If any of you attend the tsMuxeR developer forum, could you please report it?
So they can check if I said a nonsense or not
Wow, so much activity recently. Great job on the progress.
As far as X700 goes, is there anything this new tool from yusesope adds over a tsMuxer remux?
Sony X700 -> Onkyo TX-RZ830 -> LG C8
I have posted it on the forum for youyusesope wrote: ↑Thu Mar 19, 2020 7:03 pmv0.0.2 was bugged: for this reason has been replaced by version 0.0.3 (which has instead identified the problem)
Examples:
The choice of the profile is due to the value of "DVCompatibility"
So they can check if I said a nonsense or not![]()
Hy guys, anybody know what's the best way to embed sub/idx or ass subtitles into the DV mp4? I play my DV files via X700 and for some reason it can't read ass subs properly and sub/idx at all, if I put them in the same folder as DV mp4. Thanks!
You don't have to use the MP4 container anymore with the x700. You can remux your UHD bluray disc directly to .TS or .M2TS using this tsMuxer:
https://drive.google.com/file/d/1IWYPO4 ... sp=sharing
DV, Atmos and subs will work.
So one last thing with that problematic movie. I stripped out the BL layer from the mkv that I made out of the original disk, and it surprisingly mixed successfully (equal AUDs) with the EL layer I had extracted prior from the decrypted M2TS. But once muxed back into the TS container with the Atmos audio, there was definitely a hiccup in the video at the 0:43:35 mark and the audio became desynced thereafter. Odd that there was no hiccup in playback of the mkv file though at the same point, so the EL is seemingly the problematic source even though the original BL was the one with the missing AUD.yusesope wrote: ↑Thu Mar 19, 2020 7:03 pmv0.0.2 was bugged: for this reason has been replaced by version 0.0.3 (which has instead identified the problem)
Examples:
Anyways moving on, I wanted to test out your theory with the tsmuxer code but didn't really want to dig through the whole logic with DVCompatibility (nor do I really understand it), so I just commented out that entire conditional block with the "Duallayers" variable and simply forced the DV profile to 4 (bitWriter.putBits(7,4)). After compiling this small change in a5180007's latest build, i retested the Joker BL+EL+RPU file and out came with this:
General
Complete name : Z:\TS\Joker_BL_EL_RPU_PROF4.ts
Format : MPEG-TS
File size : 93.8 MiB
Duration : 23 s 607 ms
Overall bit rate : 33.1 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Duration : 23 s 648 ms
Bit rate : 31.5 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.158
Stream size : 88.8 MiB (95%)
Maximum Content Light Level : 992 cd/m2
Maximum Frame-Average Light Level : 120 cd/m2
