Mortenjorstad
Post by Mortenjorstad »
I have know made M2ts files with hd audio on all my 56 DV movies. Every movie play perfect on shield 2019 with DV and Atmos/dts x sound.
1 demux with eac3to Eac3to path to moviefolder 2:bl.hevc 3:el.hevc
2 tak the 2 files and import them into yuseope tool v02
3 use tsmuxer modified Version, mux file made by yuseope tool with audio from Blu-ray.
https://drive.google.com/uc?id=10zOr0IU ... t=download
planet_hoarder
Post by planet_hoarder »
yusesope wrote: Wed Mar 18, 2020 10:58 am
Arbigator wrote: Wed Mar 18, 2020 6:53 am What is it about a demuxed mkv rip that this tool doesn't like? Do you think it might be possible in the future?
UHD-BDs follow very precise rules: for example, the presence of NALu AUD between one frame and another is mandatory.
In remuxed files these rules are not always respected. It takes a lot of work to predict more or less anomalous behavior and I don't have time!
Ok, now it makes sense why my Rocketman_remux.mkv works with mp4muxer but not with your tool.
Mortenjorstad wrote: Wed Mar 18, 2020 1:39 pm 3 use tsmuxer modified Version, mux file made by yuseope tool with audio from Blu-ray.
Thank you!
Finally I can try with this modified version!
did you try yuseope's v0.0.3 tool
Mortenjorstad
planet_hoarder wrote: Wed Mar 18, 2020 1:57 pm
Thank you!
No, not tried v.003 since 002 works 100%
mulucy
Post by mulucy »
Mortenjorstad wrote: Wed Mar 18, 2020 1:39 pm I have know made M2ts files with hd audio on all my 56 DV movies. Every movie play perfect on shield 2019 with DV and Atmos/dts x sound.
Does it mean Shield support full 12-bit Single Track Double Layer with lossless Audio?
Post by shawnc22 »
yusesope wrote: Wed Mar 18, 2020 10:58 am This time it's not my fault :lol: !
There seems to be a little bit missing in the BL Layer: my program is in eternal expectation of a data that will never arrive! What is the title of the movie?
Ah odd that the temp version of the v2 tool worked and v3 did not. Was it just less stingy on the matching bits between layers? Maybe that missing bit was the reason why the audio desynced halfway through the movie :lol:. The movie is A Quiet Place, but I'm going to try and extract the layers with eac3to or ffmpeg and see if that makes a difference.
edit: so it looks like it might be issue with my decrypted backup. Both ffmpeg and eac3to had issues extracting the layers at around the 0:43:35 point :
eac3to:
[v03] [0:43:35] The source file seems to be damaged (transport error indicated).  <WARNING>
[v02] [0:43:35] The source file seems to be damaged (transport error indicated).  <WARNING>
[v03] [0:43:35] The source file seems to be damaged (sync byte missing).  <WARNING>
[v02] [0:43:35] The source file seems to be damaged (sync byte missing).  <WARNING>
[v02] [0:43:35] The source file seems to be damaged (discontinuity).  <WARNING>
[v03] [0:43:35] The source file seems to be damaged (discontinuity).  <WARNING>
Video track 2 contains 129801 frames.
Video track 3 contains 129802 frames.
ffmpeg:
time=00:43:34.11 bitrate=68500[mpegts @ 000001aa05fc91c0] PES packet size mismatch
Although I had no errors in makemkv when making the initial backup, I'm guessing it's some kind of defect on the original disk?
planet_hoarder
Mortenjorstad wrote: Wed Mar 18, 2020 2:52 pm
Thank you!
Can you please upload v0.0.2 as well?
I'd like to try and copy your setup.
mulucy wrote: Wed Mar 18, 2020 3:08 pm Does it mean Shield support full 12-bit Single Track Double Layer with lossless Audio?
No it does not. AFAIK, Single Track Double Layer is not 12-bit, it's 10-bit. Since no 12-bit TV's exist, we wouldn't see the difference.
I might be wrong.
Mortenjorstad
planet_hoarder wrote: Wed Mar 18, 2020 4:57 pm
Thank you!
I might be wrong.
V.0.0.2
https://drive.google.com/open?id=1HWf-l ... 4n70PDFeb-
eblackadder
Post by eblackadder »
Mortenjorstad wrote: Wed Mar 18, 2020 9:46 am
RESET_9999 wrote: Wed Mar 18, 2020 12:09 am Anyone tried 1917 ?
I'm testing @yusesope newest version of the tool but playback stops at exactly 1min16 on the shield (tried 3 times). BL+EL+RPU+Atmos
Fast forward also stop playback with the same error.
as usual , Dual layer TS + Atmos works like a charm on the x700. that movie looks amazing in DV btw.
Had same error on some movies, you must turn off pgs subtitles.
Where do you have to turn it off?
eblackadder
How do you play them if i may ask? With Plex? Or maybe MX Player?
Rufus
Post by Rufus »
I've been following this thread for a few days. Great work. I've looked through all 114 pages and I thing I understand the current workflow.
Extract the BL and EL
ffmpeg -i bluray:C:\Video\backup\SHAZAM -map 0:0 -c copy C:\Video\BL.hevc -map 0:1 -c copy C:\Video\EL.hevc
Use yuseope's v0.0.3 tool to combine BL and EL
python src\bl_el_rpu_builder.py -bl C:\Video\BL.hevc -el C:\Video\EL.hevc -of C:\Video\bl_el_rpu_builder_v0.0.3\Shazam.hevc
Open the modified tsMuxerGUI.exe. (11f852a)
Open the backup disk main mpls playlist file.
Insert the newly created Shazam.hevc and select it with the check box.
Select TRUE-HD AC3 core+TRUE-HD 7.1 with the check box.
Uncheck everything else and then start demuxing as a ts file.
When I complete these steps I have an issue with playback.
My setup:
105 MB/s avg. throughput on gigabit Ethernet
Plex server (Plex Pass)
Shield 2019 with plex app (not pro)
Vizio PX75G1
Denon receiver with Atmos 5.1.2 speaker setup
When I play the ts file my TV shows Dolby Vision, my receiver shows Dolby Atmos/DSur and Plex lists it a AC3 5.1. However, about 9 seconds into the movie shudders and freezes. I can fast forward. It will jump ahead but it freezes up again. I also tried playback from an SD card on my streaming device. Same thing so I don't think it's network related.
I also ran the remuxing and created an m2ts file. This file plays smooth with great audio sync. However it appears that I loose the Dolby Vision indicator. My receiver shows Dolby Atmos and Plex lists it a TRUE HD 7.1
To run some further tests I gave Dolby's mp4muxer a try with the same BL EL hevc files and an AC3 5.1 audio track I extracted with the modified tsMuxerGUI.
mp4muxer --dv-profile 7 --input-file C:\Video\BL.hevc --input-file C:\Video\EL.hevc --input-file C:\Video\00800.track_4353.ac3 --media-lang eng --output-file B:\Media\Calibration\Shazam_ver2.mp4
This worked as others have reported. Dolby Vision indicator, smooth audio video but it has AC3 5.1
Any ideas on what might be going on? Below is the MediaInfo on the files.
Shazam.ts
General
Complete name                            : B:\Media\Calibration\Shazam_Dolby_Vision_Atmos_Ver2_ts.ts
File size                                : 77.0 GiB
Duration                                 : 2 h 11 min
Overall bit rate                         : 83.7 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 79.1 Mb/s
Bits/(Pixel*Frame)                       : 0.398
Stream size                              : 72.8 GiB (95%)
Maximum Content Light Level              : 1351 cd/m2
Maximum Frame-Average Light Level        : 384 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 5 931 kb/s
Stream size                              : 422 MiB (1%)
Number of dynamic objects                : 15
Shazam.m2ts
General
Complete name                            : B:\Media\Calibration\Shazam_Dolby_Vision_Atmos_Ver2_m2ts.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 78.7 GiB
Overall bit rate                         : 85.5 Mb/s
Video
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 81.7 Mb/s
Bits/(Pixel*Frame)                       : 0.411
Stream size                              : 75.2 GiB (96%)
Audio
Codec ID                                 : 131
Shazam.mp4
General
Complete name                            : B:\Media\Calibration\Shazam_ver2.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 71.1 GiB
Overall bit rate                         : 77.3 Mb/s
Encoded date                             : UTC 2020-03-18 21:47:58
Tagged date                              : UTC 2020-03-18 21:47:58
Video #1
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 76.7 Mb/s
Bits/(Pixel*Frame)                       : 0.386
Stream size                              : 70.6 GiB (99%)
Codec configuration box                  : hvcC
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Bit rate                                 : 62.0 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.001
Stream size                              : 58.4 MiB (0%)
Audio
Codec ID                                 : ac-3
Alternate group                          : 2
Post by shawnc22 »
Rufus wrote: Thu Mar 19, 2020 1:26 am When I play the ts file my TV shows Dolby Vision, my receiver shows Dolby Atmos/DSur and Plex lists it a AC3 5.1. However, about 9 seconds into the movie shudders and freezes. I can fast forward. It will jump ahead but it freezes up again. I also tried playback from an SD card on my streaming device. Same thing so I don't think it's network related.
Not sure if this will fix your issue, but on first time playback of the TS file, you have to manually select the TRUEHD 7.1 audio track and not the AC3 5.1. Because of the AC3 core in the atmos track, plex will default to the ac3 5.1 track. Your video track is also not showing BL+EL+RPU, only BL+RPU. It might be the version of TSMuxer you're using. m2ts will also not work with DV+atmos, only TS will.
Rufus
Post by Rufus »
shawnc22 wrote: Thu Mar 19, 2020 4:04 am
Thanks, I'll take a look at selecting the audio track in plex. A few pages back there's a link for a tsmuxer v0.0.2 at https://drive.google.com/open?id=1HWf-l ... 4n70PDFeb-
Ran everything through tsmuxer v0.0.2 and this time the ts file shows BL+EL+RPU. Below is the MediaData. I haven't had a chance yet to test it on my TV.
General
Complete name                            : B:\Media\Calibration\Shazam_11f852a.ts
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Audio
Codec ID                                 : 131
Mortenjorstad
eblackadder wrote: Wed Mar 18, 2020 10:20 pm
With plex on shield 2019
Mortenjorstad
eblackadder wrote: Wed Mar 18, 2020 9:57 pm
With plex you can see before you start the movie if subtitles is on
eblackadder
Hi all,
I'm a little confused. I heard/read that it was not possible to use Dolby Vision/Atmos with M2TS files but Mortenjorstad wrote that he made 56 dv movies.
So i tried it too with the movie 1917 and played it on the shield tv pro. My tv is the Lg Oled C7 and it triggers dv. My receiver is the Denon 4300h and shows Atmos.
When i look to the info file it looks good.
Algemeen
Volledige naam : D:\4k Movies\1917.m2ts
Formaat : BDAV
Formaat/Info : Blu-ray Video
Bestandsgrootte : 71,8 GiB
Duur : 1 h 58 min
Totale bitratemodus : Variabel
Totale bitrate : 86,4 Mb/s
Maximale Totale bitrate : 35,5 Mb/s
Video
Menu-ID : 1 (0x1)
Formaat : HEVC
Formaat/Info : High Efficiency Video Coding
Formaatprofiel : Main 10@L5.1@High
HDR_Format/String : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec-ID : 36
Duur : 1 h 58 min
Bitrate : 82,5 Mb/s
Breedte : 3 840 pixels
Hoogte : 2 160 pixels
Beeldverhouding : 16:9
Framerate : 23,976 (24000/1001) FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0 (Type 2)
BitDepth/String : 10 bits
Bits/(Pixel*Frame) : 0.415
Stroomgrootte : 68,6 GiB (96%)
colour_range : Limited
colour_primaries : BT.2020
transfer_characteristics : PQ
matrix_coefficients : BT.2020 non-constant
MasteringDisplay_ColorPrimaries : Display P3
MasteringDisplay_Luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
MaxCLL : 1000 cd/m2
MaxFALL : 168 cd/m2
Audio
Menu-ID : 1 (0x1)
Formaat : AC-3 MLP FBA 16-ch
Formaat/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Format_Commercial_IfAny : Dolby TrueHD with Dolby Atmos
Muxingmodus : Stream extension
Codec-ID : 131
Duur : 1 h 58 min
Bitrate-modus : Variabel
Bitrate : 448 kb/s
Maximale bitrate : 7 158 kb/s
Kanaal(en) : 8 kanalen
ChannelLayout : L R C LFE Ls Rs Lb Rb
Samplerate : 48,0 kHz
Framerate : 31,250 FPS (1536 SPF)
Video vertraging : 17 ms
Stroomgrootte : 381 MiB (1%)
Taal : Engels
ServiceKind/String : Complete Main
NumberOfDynamicObjects : 11
BedChannelCount/String : 1 kanaal
BedChannelConfiguration : LFE
Is this good or not good?
