Does anyone know which playlist/segment map to use for the Charlies Angels 2019 Blu-Ray from redbox?
Charlies Angels 2019 Blu-Ray playlist/segment map for RB?
Re: Charlies Angels 2019 Blu-Ray playlist/segment map for RB?
You would have better luck posting this in the Blu-Ray discs section.
On my disc the mpls (segment) options are 356 (357), 369 (1,357), 370 (356,357), 371 (1,357) nd 372 (356,357) where segment 1 is the Sony Intro Logo, segment 356 is the China Films Introp logo and segment 357 is the feature film. So I'm using mpls 369 (Sony logo + Feature Film). This is for the standard purchase disc from Amazon but I suspect the same pattern would be used for Red Box.
Can you share how you are reviewing the content of each of those mpls (segments)? Do you have a tool other than MakeMKV? Thank you!JayWalker wrote: ↑Wed Mar 11, 2020 4:03 pm
Make a decrypted backup with MakeMKV and you can yiew each stream segment with VLC.
Good Luck
Just curious if you have any idea what the difference between 369 and 371 are?JayWalker wrote: ↑Wed Mar 11, 2020 4:03 pmOn my disc the mpls (segment) options are 356 (357), 369 (1,357), 370 (356,357), 371 (1,357) nd 372 (356,357) where segment 1 is the Sony Intro Logo, segment 356 is the China Films Introp logo and segment 357 is the feature film. So I'm using mpls 369 (Sony logo + Feature Film). This is for the standard purchase disc from Amazon but I suspect the same pattern would be used for Red Box.
Does anyone have correct mpls file for RB version?
