Spies in Disguise...
jellegard
Post by jellegard »
What is the correct playlist for Spies in Disguise RB version?
Thx.
mdeguzman
Re: Spies in Disguise...
Post by mdeguzman »
Same question...
Given the releasing studio, if you want English, you would use 00800.mpls.
mdeguzman
Post by mdeguzman »
Thank you.
omk1980
Post by omk1980 »
I watched it today. Had a weird cut at 80 mins in. A character says "let's get weird" and then immediately cuts to the climactic set-piece.
Not sure if that was how the movie was made or if makemkv cut out a scene.
Can anyone confirm?
omk1980 wrote: Fri Mar 20, 2020 12:05 am I watched it today. Had a weird cut at 80 mins in. A character says "let's get weird" and then immediately cuts to the climactic set-piece.
Can anyone confirm?
Don't know as I haven't seen it yet.
You could give GetMPLS a try. Use the search function to look up "GetMPLS" and you will find the thread for it.
TheBatman7465
Post by TheBatman7465 »
I checked the actual disc in my player... that cut seems to be normal if you're saying it was
"Let's get weird" and then the Wil Smith character busts through a door...
So there's two versions of the movie you can watch... there's one that's called Super Undercover version or something... stuff pops up explaining things in the movie... I'm taking that's the 801 version... more to come after I rip!
omk1980
Post by omk1980 »
Awesome. Thanks for confirming.
gpdmike
Post by gpdmike »
Just wanted to chime in and confirm the playlists for the Redbox version.
The correct playlist for English is 800.mpls, 801.mpls is a foreign language version where the main difference is the title card at ~10 minutes in that reads "Espions Icognito" instead of "Spies in Diguise".
The Undercover version w/ the extra features is 857.mpls.
