Distorted or no audio on ripped movies
baward
Post by baward » Sat Mar 14, 2020 7:52 pm
While the video tracks are fine, the audio track for several of my MakeMKV rips is grossly pitched-shifted down by about three octaves and distorted.
This is from a Bluray that I created and finalised with a Panasonic DMR-BWT850 recorder. 4 movies from this disc actually ripped fine, but 4 more had these problems. I have ripped movies successfully many times before with no issues, so it's puzzling why this is happening now.
Many thanks!
Re: Distorted or no audio on ripped movies
Post by Woodstock » Sat Mar 14, 2020 10:14 pm
The most likely suspect is an audio codec that your system does not support. Are you having the issues playing through a TV, a player like VLC, or ???
baward
Post by baward » Sun Mar 15, 2020 3:53 pm
Thanks. I have tested the disc with two different Bluray players, and there are no errors. The problems are only with the computer; Blu-Ray Pro by Macgo plays back half the movies correctly, but with either missing or very out of sync audio. VLC has the most problems, as I outlined before. Bizarrely, playing back one of the movies in VLC leads to it acquiring the soundtrack from another movie!
